VHMUM(at)bigpond.com Guest
Posted: Tue May 06, 2008 1:31 am Post subject: Door seal adhesive |
Has anyone tried proseal on the door seals. Not having any luck with
silicone
regerds Chris.
Cant find the 3m silicone over here.
Posted: Tue May 06, 2008 4:30 am Post subject: Door seal adhesive |
Go to a good auto parts store ( I assume you do have those???) and get
3M door seal adhesive. It's nasty stuff (like proseal) but made to glue
down rubber seals.
Linn
Chris and Susie McGough wrote:
<VHMUM(at)bigpond.com>
silicone
regerds Chris.
roadmaps
Posted: Wed May 07, 2008 4:44 am Post subject: Door seal adhesive |
I got door seal adhesive from Brown Aircraft supply in Fla. 904-396-6601
-worked great with their seal.
John Testement
jwt(at)roadmapscoaching.com
40321
Richmond, VA
Painting
--> <VHMUM(at)bigpond.com>
silicone
regerds Chris.
Checked by AVG.
11:22 AM
Posted: Wed May 07, 2008 1:02 pm Post subject: Door seal adhesive |
I take it this means no one has used proceal. Will give it a try . Thanks
for all the replies we are in AUS so no Brown tool etc etc here but thats
fine will just try the black stuff.
regards Chris
msausen
Posted: Wed May 07, 2008 5:41 pm Post subject: Door seal adhesive |
Chris,
Did you try checking with an auto paint shop or your local paint supply house. They are almost certainly going to have a suggestion and supplier local to you.
Michael
wvu(at)ameritel.net Guest
Posted: Wed May 07, 2008 6:33 pm Post subject: Door seal adhesive |
Sorry for chiming in late. I used Permatex Clear RTV Adhesive 66BR in a tube
from local auto stores. Seems to work fine.
Anh
N591VU-flying
