a.s.elliott(at)cox.net Guest
Posted: Sun May 04, 2008 8:17 pm Post subject: Help with Harbor Freight riveter? |
I just purchased a Central Pneumatic brand air/hydraulic riveter, #93458, from Harbor Freight. According to the instructions, it needs to be serviced with hydraulic fluid before use. The same instructions explain how to removed the bottom cover and add the fluid.
BUT, I am completely unable to get the bottom cover off, even after using some PB Blaster and my 1/2" breaker bar on the 15/16" hex part provided. Does anyone know if there is some trick to this? I can see any locking pin or similar problem in the drawing.
Is there a different way to add the fluid? Any other ideas?
Andy Elliott, Mesa, AZ
N601GE (reserved)
601XL/TD, Corvair, building...
Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Sun May 04, 2008 9:04 pm Post subject: Help with Harbor Freight riveter? |
Hi Andy
I have the same tool, and, for me, the instructions were not very helpful.
I used it without a proper priming for a year before I got it working
right. Now, it's great.
The cylinder cap for the pneumatic cylinder is sealed with an O-ring, and
does not need to be very tight. I am able to loosen mine with the supplied
spanner, with a counterclockwise turn. Once you remove the cylinder cap and
the piston assembly, the important thing (I now realize ) is to fill
the central cylinder of the handle with oil (I used pneumatic oil from
Lowes). I misunderstood the instructions and thought they were talking
about filling the top of the pneumatic cylinder with oil, up to the top of
the "frame." So I failed to fill the cylinder in the handle. As a result
the rivet gun required 2 or 3 cycles to pop a rivet. Now, with the proper
oil fill, it pops on the first pull. Ah, wisdom. Once it's properly
primmed, I believe that just putting 4 or 5 drops of oil into the air inlet
a the start of a work session will keep the oil level up. It's a good tool.
The instructions were not very helpful.
I don't know what to advise if the spanner will not loosen the cylinder
cap. Mine comes off easily.
Terry
At 09:14 PM 5/4/2008 -0700, you wrote:
| Quote: | I just purchased a Central Pneumatic brand air/hydraulic riveter, #93458,
N601GE (reserved)
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons
are done; working on the wings
http://www.mykitlog.com/N47TP/
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
sonar1@cox.net
Joined: 02 Oct 2007 Posts: 55 Location: Santa Barbara, Ca
Posted: Sun May 04, 2008 9:18 pm Post subject: Re: Help with Harbor Freight riveter? |
I got a riveter from harbor freight 5 years ago, and have pulled 20,000 rivets with very few problems. Did not add any oil, except a few drops in the air hole every once in a while. Perhaps they have changed, but why not try it as is?????...................Fred.........N9701.....N9601......Ca
ernieth(at)gmail.com Guest
Posted: Mon May 05, 2008 4:32 am Post subject: Help with Harbor Freight riveter? |
Andy,
I had the same problem. I did not follow the instructions and only oiled the air inlet. Seems to work ok.
The first one did not work though and I sent it back.
Ernie
Do Not Archive.
On Sun, May 4, 2008 at 9:14 PM, Dr. Andrew Elliott <a.s.elliott(at)cox.net (a.s.elliott(at)cox.net)> wrote:
[quote] I just purchased a Central Pneumatic brand air/hydraulic riveter, #93458, from Harbor Freight. According to the instructions, it needs to be serviced with hydraulic fluid before use. The same instructions explain how to removed the bottom cover and add the fluid.
N601GE (reserved)
wjones(at)brazoriainet.co Guest
Posted: Mon May 05, 2008 4:52 am Post subject: Help with Harbor Freight riveter? |
Hey Andy .I had the same problem .The spanner tool that they send is much too weak .I locked mine up in a vise and got very rough with it .It will come loose .
Wade Jones South Texas
601XL plans building
Cont. 0200
Posted: Mon May 05, 2008 5:01 am Post subject: Help with Harbor Freight riveter? |
Oh ,Andy I reread your post .Do nothing about adding oil before the first use .These instructions should not be there ,the gun is ready for use right out of the box.You can tell when oil is needed by how bad the riveter is pulling the rivets .Again ready for use out of the box ,no need for priming .The only oil you need to add is a few drops into the air inlet before each use .
Cont. 0200
n85ae
Posted: Mon May 05, 2008 7:54 am Post subject: Re: Help with Harbor Freight riveter? |
Harbor Freight rivet gun maintenance .... Whazzat???
I've been using mine for two planes now .... I always assumed
maintenance was replacing it when it quit working ... Mine still hasn't
quit. Despite drop testing it, etc.
Ok, I do occasionally drop some oil in the air inlet.
Jeff
kmccune
Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
Posted: Mon May 05, 2008 10:22 am Post subject: Re: Help with Harbor Freight riveter? |
Mine wouldn't come off ether. I used a vice and a large pipe wrench. When I got it open, it had oil in it already! Well now it looks like I took a pipe wrench to an aluminum cover! Try it, if it works use it. If you want put oil in the air inlet, just to be sure of lubrication
Kevin
_________________ “Always do what you are afraid to do.”
R.W. Emerson (1803-1882)
Dorothy McCune |
