nuckolls.bob(at)cox.net Guest
Posted: Tue Apr 29, 2008 11:56 am Post subject: Hand-held antenna adapter |
At 08:14 AM 4/29/2008 -0700, you wrote:
| Quote: | Below is the result of your inquiry. It was submitted by
Hank Eilts (eilts(at)ti.com) on Tuesday, April 29, 2008 at 08:14:03
Comments/Questions: Hello Bob,
I believe that I saw an article on your website describing how to wire a
jack into the panel for connecting a handheld comm to the external
aircraft antenna. I believe you advocated a 1/4 phone jack with a
switching function on the jack for the panel. However, now I cannot find
the article and I wonder if you may have pulled the article due to
operational problems with the technique.
Yes, the quality of close-circuit phone jacks available to
the task was pretty poor. Failure of the jack's switch
would disable the panel-mounted radio. Here's a photo
of the DIY project:
http://www.aeroelectric.com/Pictures/Antenna/CommTap-Jack.jpg
ICOM offers a hand-held adapter with the same technology
http://www.aeroelectric.com/Pictures/Antenna/ICOM_Hand_Held_Adapter_1.jpg
http://www.aeroelectric.com/Pictures/Antenna/ICOM_Hand_Held_Adapter_2.jpg
| Quote: | I work in electronics and can wire up the panel mod without problems, but
I'm wondering if normal panel vibration can make/break the switch when a
handheld in not installed, causing problems for the main radio.
Given the lead lengths for the commercial off the shelf
device from ICOM, you probably couldn't do much worse!
How about CK7000 series switch with a bnc chassis
mount connector mounted right next to each other.
http://www.aeroelectric.com/Pictures/Switches/7301P3YZQE.jpg
Bring ship's antenna and transmitter coaxes up to
the back and assemble with shortest practical leads
to toggle antenna between hand-held and panel-mounted
transceivers.
In fact, I've been considering a product consisting
of a 2 pole switch that terminates the panel-mounted
radio into a dummy load when the hand-held is being
serviced by the antenna.
However you decide to go, I don't recommend the 1/8"
closed circuit jack.
( IF one wishes to be "world class" at )
( anything, what ever you do must be )
( exercised EVERY day . . . )
( R. L. Nuckolls III )
