Martin Pohl
Joined: 30 Jan 2006 Posts: 118 Location: CH-8645 Jona SG, Switzerland
Posted: Mon Apr 21, 2008 4:18 am Post subject: Zodiac XL - Maneuvering Speed |
My instrument panel is going to be finished soon. For the installation of the mandatory "Maneuvering Speed" placard, I am trying to find out which is the "official" maneuvering speed for the CH601XL.
Different sources indicate different va's: 80 kts, 82 kts, 88 kts, even 90 kts... What is the official speed that Chris used for his XL-calculations?
Thank you for any information!
Cheers Martin
_________________ Martin Pohl
Zodiac XL QBK
8645 Jona, Switzerland
http://www.pohltec.ch/ZodiacXL/Main.html |
amyvega2005(at)earthlink. Guest
Posted: Mon Apr 21, 2008 5:14 am Post subject: Zodiac XL - Maneuvering Speed |
maauvering speeds and V speeds are posted on the cover of your PLans. Manauvering speed is 103 mph.
Juan
notsew_evets(at)frontiern Guest
Posted: Mon Apr 21, 2008 6:04 am Post subject: Zodiac XL - Maneuvering Speed |
I guess I messed something.. I dont recall ever seeing a placarded
manuvering speed....
How is it marked on your glass ?? Mine is green to 130 and then goes yellow
to 150 then RED line.....
SW
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Mon Apr 21, 2008 8:25 am Post subject: Re: Zodiac XL - Maneuvering Speed |
Maneuvering speed is not marked on the ASI. I suspect that European regs may require a placard - FAA does not.
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
Martin Pohl
Martin Pohl
Posted: Mon Apr 21, 2008 11:37 am Post subject: Re: Zodiac XL - Maneuvering Speed |
Sabrina, thank you for the info. I didn't know that...
Nevertheless here in Europe (or at least in Switzerland), we have to install this VA-placard before showing it to the aviation authority.
Cheers Martin
Zodiac XL QBK
bryanmmartin
Posted: Mon Apr 21, 2008 11:53 am Post subject: Zodiac XL - Maneuvering Speed |
The information I received from ZAC was 110 mph (96 kts) but mine is an
early kit, that information may be for the original gross weight of 1400
lbs. The maneuvering speed goes down with decreasing weight.
In the U.S. there is no placard required tor maneuvering speed, it just
must be included in the pilot's operating handbook.
Cheers Martin
Bryan Martin
Zenith 601XL N61BM
Ram Subaru, Stratus redrive
_________________ --
Bryan Martin
do not archive. |
Gig Giacona
Posted: Mon Apr 21, 2008 12:02 pm Post subject: Re: Zodiac XL - Maneuvering Speed |
Strange... Looking at the front page of my planes there is no maneuvering speed called out. Just Top, Cruise, Stall and Vne.
1st Edition 04/02.
601XL Under Construction
Tim Juhl
Posted: Mon Apr 21, 2008 12:41 pm Post subject: Re: Zodiac XL - Maneuvering Speed |
Either a operating manual or placards may be used to provide data such a maneuvering speed. The manner of compliance is specified by the type certificate. For example, the Cessna 172 only calls for displaying maneuvering speed starting with 1971 models, stating: This airplane must be operated in compliance with the operating limitations stated
in the form of placards, markings, and manuals.
MAXIMUMS
Normal Category
Maneuvering speed (CAS) 122 mph (106 knots)
Gross weight 2300 lbs.
I don't know if it was on a placard or in the manual after 1971. My 1968 172 had it only in the manual.
The attached info is from the XL plans dated 3/06.
Description: |
Filesize: |
78.54 KB |
Viewed: |
517 Time(s) |
CFII
Champ L16A flying
jmaynard
Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
Posted: Mon Apr 21, 2008 8:18 pm Post subject: Zodiac XL - Maneuvering Speed |
On Mon, Apr 21, 2008 at 03:54:35PM -0400, Bryan Martin wrote:
Quote: | In the U.S. there is no placard required tor maneuvering speed, it just
Okkay, dumb question time. I'd always thought that maneuvering speed was the
top of the white arc on the airspeed indicator. Is this not correct?
Jay Maynard, K5ZC http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (FRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC (ordered 17 March, delivery 2 June)
_________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Mon Apr 21, 2008 10:56 pm Post subject: Zodiac XL - Maneuvering Speed |
Not a dumb question, Jay.
I often forget what the white arc is for. Fortunately, the 1st page in the
plans gives the definition--the white arc covers the speed range between
the stall speed with flaps extended and the max flap extend speed. My 601
dwg, 6-X-1, gives Vs0 and Vfe as 44 and 80 mph from while Va, the
maneuvering speed is 103 mph.
Terry
At 11:15 PM 4/21/2008 -0500, you wrote:
Quote: | > In the U.S. there is no placard required tor maneuvering speed, it just
Jay Maynard, K5ZC
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons
are done; working on the wings
http://www.mykitlog.com/N47TP/
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
Posted: Tue Apr 22, 2008 5:16 am Post subject: Zodiac XL - Maneuvering Speed |
Nope.
Tim Juhl
Posted: Tue Apr 22, 2008 9:20 am Post subject: Re: Zodiac XL - Maneuvering Speed |
Maneuvering speed is not depicted on the ASI. It varies with weight, actually decreasing as the weight of the aircraft decreases. In my 1968 C172, maneuvering speed at gross was 122 mph. Funny thing is, the airplane's cruise speed was less. Such was not the case with my 182 which had a maneuvering speed of 126 mph but cruised at 155.
In the case of the XL, you'll want to slow down when it gets bumpy
CFII
Champ L16A flying
psm(at)att.net Guest
Posted: Tue Apr 22, 2008 10:56 am Post subject: Zodiac XL - Maneuvering Speed |
At 09:15 PM 4/21/2008, you wrote:
Quote: | Okkay, dumb question time. I'd always thought that maneuvering speed was the
I thought the top of the white arc was the flap extended speed, Vfe.
I think I've seen a yellow line crossing the green that reflects Va,
but Va varies a great deal with changes in actual aircraft weight.
Paul
XL fuselage
bryanmmartin
Posted: Tue Apr 22, 2008 5:17 pm Post subject: Zodiac XL - Maneuvering Speed |
The top of the white arc is the maximum operating speed with full flaps
(Vfe). Maneuvering speed is not a standard marking on the ASI. It is
usually found in the POH for gross weight and decreases with decreasing
weight of the airplane.
Bryan Martin
Zenith 601XL N61BM
Bryan Martin
do not archive. |
bryanmmartin
Bryan Martin
Zenith 601XL N61BM
Bryan Martin
do not archive. |
