riffeljl(at)gmail.com Guest
Posted: Sun Apr 20, 2008 6:44 pm Post subject: Oil Cutter CHEAP |
I fab'd one from a pipe cutter, some homeDepot angle-iron, 4 bolts/washers/nuts and some plywood. It's Really Ugly, but it works and it's cheap. Been using it for about 8 years.
Cut the angle iron so you make a square that 'holds' a oil filter and bolt it together. Cut the pipe cutter in half and bolt the adjustable part to one side of the angle-iron so you can adjust it to cut into the edge of the filter. I put "thick" plywood inside the angle-iron square with a hole for the filter pipe fitting to fit thru (so I could hold everything flat on the bench when I cut the filter)
To operate, I just put a socket wrench on the filter and turn it while I adjust the pipe cutter enough to cut thru the 'can' around the filter.
Good Luck
"Jerry"
BAGSTERJR(at)msn.com Guest
Posted: Mon Apr 21, 2008 7:16 am Post subject: Oil Cutter CHEAP |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Thanks, but a photo would be worth a thousand words......
Bill 7A
av8or(at)cox.net Guest
Posted: Mon Apr 21, 2008 7:56 am Post subject: Oil Cutter CHEAP |
Ditto.....
