jlsk1(at)frontiernet.net Guest
Posted: Thu Apr 17, 2008 4:23 am Post subject: 582 muff Brackets |
John H, Richard Pike, And anyone else that has , or had a 582 on a MK-3C, how have you guys mounted your mufflers & with what type of brackets without a Bracket cracking problem? (If any) Have you mounted them above the exhaust manifold, with angle alum. like the 503 plans in the MK-3 manual? ( If so , what thickness & dimensions) ??
Or with the brackets that LEAF & Lockwood sell that bolt to the side of the engine under the exhaust manifold, & if so, can you do that & the muff still clear the wing gap seal? (which I will still fly with)
Thanks, Jim, Cookeville, TN,
Self grounded ' til I eliminate this problem.
(I don`t do Crack)
Posted: Thu Apr 17, 2008 4:42 am Post subject: 582 muff Brackets |
Jim K:
I used whatever came in the kit for muffler mount on the 582. Think it was a 4130 system designed and manufactured by old Kolb that bolted to the side of the engine. Been to long to get a clear picture in my mind.
_________________ John Hauck
Titus, Alabama |
Posted: Thu Apr 17, 2008 10:12 am Post subject: 582 muff Brackets |
Thanks!
Steve Boetto
Posted: Thu Apr 17, 2008 10:20 am Post subject: 582 muff Brackets |
Jim, call Bryan at 606 682 3388. He makes a very nice aluminum plate system.
steve
In a message dated 4/17/2008 8:24:02 A.M. Eastern Standard Time, jlsk1(at)frontiernet.net writes:
Quote: | John H, Richard Pike, And anyone else that has , or had a 582 on a MK-3C, how have you guys mounted your mufflers & with what type of brackets without a Bracket cracking problem? (If any) Have you mounted them above the exhaust manifold, with angle alum. like the 503 plans in the MK-3 manual? ( If so , what thickness & dimensions) ??
Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos.
Posted: Thu Apr 17, 2008 11:02 am Post subject: 582 muff Brackets |
Steve, I just talked to Bryan, he didn`t have anything, nor info for me, only dealing with 912's
Thanks anyway, Jim
planecrazzzy Guest
Posted: Thu Apr 17, 2008 1:57 pm Post subject: Re: 582 muff Brackets |
Here's a style I made for mine.... Made outa Stainless Steel
It's flown about 3 seasons now.... Just made one fer somebody else too.
Gotta Fly...
Mike & "Jaz" in MN
RN-KMA
Description: |
Filesize: |
61.19 KB |
Viewed: |
429 Time(s) |
Description: |
Filesize: |
61.95 KB |
Viewed: |
435 Time(s) |
Description: |
Filesize: |
60.1 KB |
Viewed: |
412 Time(s) |
Steve Boetto
Posted: Thu Apr 17, 2008 2:29 pm Post subject: 582 muff Brackets |
Sorry, I just figured out that you were talking about a 582.
steve
In a message dated 4/17/2008 3:03:36 P.M. Eastern Daylight Time, jlsk1(at)frontiernet.net writes:
[quote] Steve, I just talked to Bryan, he didn`t have anything, nor info for me, only dealing with 912's
Thanks anyway, Jim
Steven Green
Posted: Thu Apr 17, 2008 5:32 pm Post subject: 582 muff Brackets |
Jim,
This was the muffler mount that came from Kolb for the 582 muffler. The rubber bushings between the red brackets and the muffler bracket were good for about 100 to 150 hours.
[img]cid:D18A7F13212548FE8BD205DA92D916D4(at)GreensPC[/img]
[img]cid:38EEA90D8C5842C4B92C25D2B29CA09D(at)GreensPC[/img]
Steven Green
Etowah, TN
Description: |
Filesize: |
79.78 KB |
Viewed: |
398 Time(s) |
Description: |
Filesize: |
117.48 KB |
Viewed: |
411 Time(s) |
_________________ Steven Green |
Posted: Thu Apr 17, 2008 6:21 pm Post subject: 582 muff Brackets |
Thanks!!
Description: |
Filesize: |
79.78 KB |
Viewed: |
392 Time(s) |
Description: |
Filesize: |
117.48 KB |
Viewed: |
375 Time(s) |
