jpiavis(at)microsoft.com Guest
Posted: Tue Apr 15, 2008 7:01 am Post subject: Tail Nav Light Ground |
I’m wiring up the tail nav/ strobe light in the lower fiberglass rudder fairing for an RV-7. Is there any reason I can’t tie the nav light ground to the strobe ground? For the tail light, this seems to be the easiest option but wasn’t sure about the voltage running through the strobe. It’s either that or run a wire into the aft fuselage to a local ground.
Jim
nuckolls.bob(at)cox.net Guest
Posted: Tue Apr 15, 2008 7:57 am Post subject: Tail Nav Light Ground |
At 07:55 AM 4/15/2008 -0700, you wrote:
| Quote: | I m wiring up the tail nav/ strobe light in the lower fiberglass rudder
fairing for an RV-7. Is there any reason I can t tie the nav light ground
option but wasn t sure about the voltage running through the strobe. It s
You don't want to cause an unbalance of currents
to flow inside the twisted trio of strobe wires.
The physics that make this wire an effective constraint
on coupling of noise depends on integrity of combination
of balanced currents and shielding.
The separate ground wire is called for.
Posted: Tue Apr 15, 2008 8:35 am Post subject: Tail Nav Light Ground |
I just faced the same issue. I chose to run a separate ground from the Adel clamp holding the rudder cable.
It also took a bit more effort than expected to get a single lug #4 platenut in there to hold the Whelan. But it worked well.
Jim Piavis wrote: [quote] <![endif]--> <![endif]-->
Jim
| [b]
