pbuttles(at)charter.net Guest
Posted: Tue Apr 08, 2008 3:31 pm Post subject: 914 wiring install |
hello im puting a 914 in a 701,the books says not to put the control box and waste gate servo in the engine compartment.
can I unhook the cotroler box and install under panel?
has anyone put them under cowl?
any other helpful hints for that install??
Posted: Wed Apr 09, 2008 12:56 am Post subject: 914 wiring install |
Hi! Tracy,
I have put an insulated box on the P1 Footwell and the Waste Gate Servo
together with the Regulator box are installed there. I have a 3/4" cold
air bleed off from the intake cooling air feeding into the insulated box
which is allowed to leek out against the footwell. I haven't ever seen
more than 35 deg C soon after parking so make a point of opening the
cowl top rad and oil filler hatches. In flight the temps are not giving
any concern.
This location is best suited to the least curve of the waste gate
control cable.
Bob Harrison G-PTAG Europa MK1 Trike re-engined with a 914 c/w
intercooler in place of a Jabiru 3300.
Posted: Wed Apr 09, 2008 3:12 am Post subject: 914 wiring install |
Tracy a écrit :
Tracy,
Indeed, you should.
The TCU control box comes in the crate, and is connected to the engine
with an easy to disconnect connector.
| Quote: | has anyone put them under cowl?
The 914 turbo releases a lot of heat under the cowl, so you may want to
install it as per the manual.
| Quote: | any other helpful hints for that install??
Some info on Contrails.
Best regards,
Gilles
http://contrails.free.fr
