jb92563
Joined: 23 Mar 2007 Posts: 314 Location: Southern California
Posted: Thu Apr 03, 2008 12:02 pm Post subject: Spark Plugs |
Has anyone ever had the tip of the spark plug unscew in flight and lose ignition?
I have noticed that these things like to unscrew themselves if you spark plug cap in not gripping it very tight.
I am wondering if there is a way people have been preventing that.
I guess the plugs that don't have the screw cap is an obvious answer if you can find them...?
High temp Lock-Tite might work?
I had a Lazair with twin Rotax 185's that required a "Plug terminal Check" before every flight.
And I noticed it happening a couple evenings ago on My UltraStar while testing the engine & CHT probes.
I took the Vice Grip to it and cranked it on as tight as I dared go.
_________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
olendorf
Joined: 06 Jul 2006 Posts: 140 Location: Schenectady, NY USA
Posted: Thu Apr 03, 2008 12:57 pm Post subject: Re: Spark Plugs |
I use the solid cap plug. You can get either one at the auto parts store. Just check them before you buy them. They seem to show up on the computer with the same part # but they appear on two separate lines. One may have a different description or something. I have them bring both to the counter.
With the screw on caps I "crimp" them with diagonal cutting pliers so they can't turn.
_________________ Scott Olendorf
Original Firestar, Rotax 447, Powerfin prop
Schenectady, NY
http://sites.google.com/site/kolbfirestar/ |
herbgh(at)nctc.com Guest
Posted: Thu Apr 03, 2008 1:01 pm Post subject: Spark Plugs |
Ray
Take the little cap off of the plug and then squeeze it together
just a wee bit... Creates a distorted nut so to speak.. Will hold then.. Herb
At 03:02 PM 4/3/2008, you wrote:
loose ignition?
Ray
Moni MotorGlider
Riverside County, CA
http://forums.matronics.com/viewtopic.php?p=174627#174627
aoldman(at)xtra.co.nz Guest
Posted: Thu Apr 03, 2008 3:54 pm Post subject: Spark Plugs |
I always lock tight these on. Have had one come off on an inverted engine
once but was above airport at the time so was no problem.
Tony
Downunder
WhiskeyVictor36(at)aol.co Guest
Posted: Thu Apr 03, 2008 5:21 pm Post subject: Spark Plugs |
In a message dated 4/3/2008 4:05:18 P.M. Eastern Daylight Time, jb92563(at)yahoo.com writes:
Quote: | I have noticed that these things like to unscrew themselves if you spark plug cap in not gripping it very tight.
Ray,
Here's how I did it. Remove the cap. Lay the threaded end of the plug on a vise (or some other solid surface) and then lightly hammer the threads so as to deform them slightly. Now screw the cap back on. It will have resistance, like a self locking nut. Don't over do it or you might break the ceramic. You can experiment on how much to smash the threads to get a workable resistance. I now use the NGK plugs that have solid caps.
Bill Varnes
Original Kolb FireStar
Audubon NJ
Planning your summer road trip? Check out AOL Travel Guides.
Dana
Posted: Thu Apr 03, 2008 5:32 pm Post subject: Spark Plugs |
At 04:02 PM 4/3/2008, jb92563 wrote:
Quote: | I guess the plugs that don't have the screw cap is an obvious answer if
I asked about the solid tip plugs at the local auto parts store but they
said they couldn't get them from their distributor. However, you can mail
order them from, I know CPS sells only the solid plugs, probably the other
aircraft suppliers do the same.
You can also get a spark plug cap that presses onto the threaded part with
the screw cap removed.
-Dana
War doesn't determine who's right but who's left.
olendorf
Posted: Fri Apr 04, 2008 5:06 am Post subject: Re: Spark Plugs |
aoldman(at)xtra.co.nz wrote: | I always lock tight these on. Have had one come off on an inverted engine
Tony
Downunder
I was under the impression that you do not want to put any goop on the threads. It may prevent a good electrical connection.
Schenectady, NY
Tom Jones
Posted: Fri Apr 04, 2008 5:25 am Post subject: Re: Spark Plugs |
I ordered BR8ES spark plugs from Aircraft Spruce a couple months ago and they sent me the screw top plugs. I was POed. An aircraft parts supplier should know better. When I made a large parts order of stuff to replace with my condition inspection this month I ordered from CPS. They sent the right plugs...solid top.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
lucien
Joined: 03 Jun 2007 Posts: 721 Location: santa fe, NM
Posted: Fri Apr 04, 2008 7:38 am Post subject: Re: Spark Plugs |
Tom Jones wrote: | I ordered BR8ES spark plugs from Aircraft Spruce a couple months ago and they sent me the screw top plugs. I was POed. An aircraft parts supplier should know better. When I made a large parts order of stuff to replace with my condition inspection this month I ordered from CPS. They sent the right plugs...solid top. |
These NGK plugs are _not_ aircraft parts - says so on the little box the plug comes in, note the little quicksilver with the circle/strikeout over it.
Yes, the solid top plug has the same little struck-out ultralight on it.
If you need the solid tops, you probably have to explicitly order them (though I don't see a part no on a/c spruce).
The screw-on caps are fine _IF_ your wire end caps are in good shape. They should be a tight fit on the plug and a struggle, or at least a firm pull, to remove.
If they come off easily they're worn out and need to be replaced - good caps will hold the screw-on tops in place with no tendency to unscrew (unless they're just slap loose to begin with).
The NGK parts are the same as the rotax ones but are about 10% of the price.
LS
_________________ LS
Titan II SS |
pj.ladd(at)btinternet.com Guest
Posted: Fri Apr 04, 2008 8:27 am Post subject: Spark Plugs |
I am wondering if there is a way people have been preventing that.>>
Hi,
on the Challenger with an inverted 503 I just wound a bungee around the
lead ends, there are plenty of places to hook on. Worked fine.
Cheers
Pat
lucien
Posted: Fri Apr 04, 2008 8:38 am Post subject: Re: Spark Plugs |
pj.ladd(at)btinternet.com wrote: | I am wondering if there is a way people have been preventing that.>>
Hi,
Cheers
Pat |
By the way, this is the primary diagnostic that you have bad wire-end caps - even on an inverted installation the caps should still stay firmly attached to the plugs and no tie-wrapping or other extra securing should be necessary to keep them on.
You should still end up cussing a bit pulling the caps off, even on an inverted motor. Replace at first sign they're pulling off more easily than when new.....
LS
Titan II SS |
Ralph B
Posted: Fri Apr 04, 2008 1:29 pm Post subject: Re: Spark Plugs |
I use the screw on type spark plugs. I install the plug and use a small channel lock pliers to tighten the cap. It knurls up the cap a little and provides better holding inside the spark plug cap. I always use a long cable tie over the plug and it keeps the plugs from moving around. I've never had a cap loosen up.
Ralph
_________________ Ralph B
Kolb Kolbra 912uls
N20386
550 hours |
Dana
Posted: Fri Apr 04, 2008 1:48 pm Post subject: Spark Plugs |
At 09:25 AM 4/4/2008, Tom Jones wrote:
Quote: | I ordered BR8ES spark plugs from Aircraft Spruce a couple months ago and
I emailed CPS a few weeks ago before ordering other stuff as well as some
plugs, and they confirmed that they sell only the solid tip plugs. On the
ACS website, it explicitly says that the NGK plugs are "not for aircraft
use". Liability, I know, but...
-Dana
It feels great to wake up and not know what day it is, doesn't it?
Posted: Sat Apr 05, 2008 9:39 am Post subject: Spark Plugs |
or other extra securing should be necessary to keep them on.>>
Hi,
I have no idea if it was `necessary` or not. The leads never fell off or
even felt loose. With an engine the right way up I should not have bothered
but on an inverted one tieing them on just seemed a sensible belt and
braces precaution
Cheers
Pat
Posted: Sat Apr 05, 2008 10:06 am Post subject: spark plugs |
I also like the large, sturdy looking electrodes on the NGKs. I
tried the flimsy platinum wire Bosches
and they were ok but didn't seem to perform as well. My imagination
perhaps.
My boot type connectors stay on ok but then they are leaning into the
wind.
-for the curious, the fan is for slow taxiing behind slowpokes if I
go to a flyin. I manually switch it
but a thermoswitch would be nice. Stock yamaha ventura radiator.
BB
DSCN0916.JPG copy
Description: |
Filesize: |
69.51 KB |
Viewed: |
537 Time(s) |
Posted: Sat Apr 05, 2008 11:02 am Post subject: spark plugs |
Regarding your radiator, what engine size was the Yamaha Vetura?? I have a snowmobile radiator on
my GEO. I can't remember the make, but IIRC, the size of the engine it cooled was about 650-700cc.
Have you ever really needed the electric fan, or is on there "just in case"?
Mike Welch
More immediate than e-mail? Get instant access with Windows Live Messenger.
http://www.windowslive.com/messenger/overview.html?ocid=TXT_TAGLM_WL_Refresh_instantaccess_042008
Posted: Sat Apr 05, 2008 1:22 pm Post subject: spark plugs |
Mike, the ventura started out as a 1200 cc and was later sold as 1300.
The key to a radiator is more air flow than size. If you locate it
near the prop you
will be better off on the ground. Mine is a mile away hence the fan.
Sitting on the ground on a hot day you will need some kind of
enhancement.
A couple years ago I popped a coolant hose inflight and my oil cooler
saved the day.
I reported at the time that I heard a scraping sound when I hand
turned the prop
before the completion of my journey. -That turned out to be the ONLY
bolt that wasn't
safety wired, a water pump bolt that worked its way out to scrape on
the back of the
pulley. In my defense, it was not a very noticeable or accessible
location.
I can actually watch my temp gauge go back down when I flick the switch.
BB
On 5, Apr 2008, at 2:59 PM, Mike Welch wrote:
Quote: |
in case"?
Mike Welch
Messenger.
Posted: Sat Apr 05, 2008 1:43 pm Post subject: spark plugs |
Hi Bob,
I'm going to run out to the shop and measure my radiator size. Back in sec......
Okay, here's what I've got: 7.5 inches wide X 8.5 inches tall X 1.5 inches deep. These dimensions are of the actual finned area.
My radiator location looks to be about the same as your's...front of the engine. I also have an oil cooler I plan on installing, probably near the prop somewhere.
Do you think my radiator is big enough?? I appreciate your opinion. Although I have had my engine/prop running long ago, I haven't flown it yet.
Mike W.
Quote: | From: slyck(at)frontiernet.net
Subject: Re: spark plugs
Date: Sat, 5 Apr 2008 17:19:52 -0400
--> Kolb-List message posted by: robert bean <slyck(at)frontiernet.net>
near the prop you
enhancement.
saved the day.
turned the prop
bolt that wasn't
the back of the
location.
BB
> --> Kolb-List message posted by: Mike Welch <mdnanwelch7(at)hotmail.com>
> Bob,
> in case"?
> Mike Welch
> Do Not Archive
> _________________________________________________________________
> Messenger.
Pack up or back up–use SkyDrive to transfer files or keep extra copies. Learn how. [quote][b]
R. Hankins
Joined: 18 Jan 2006 Posts: 185 Location: Grants Pass, Oregon
Posted: Sun Apr 06, 2008 8:36 pm Post subject: Re: Spark Plugs |
I received a bunch of screw top B8ES plugs from Aircraft Spruce over a year ago. I got on the phone to customer service and they took them back. I wrote them an e-mail about the safety issue of solid vs screw tops and included the correct NGK stock number. I got absolutely no response. Interesting that they have chosen to add a legalese warning instead of stocking the right plugs. I hope this isn't indicative of a change of attitude for the worse at AC Spruce. Probably just standard CYA.
_________________ Roger in Oregon
1992 KXP 503 - N1782C |
GeoR38
Joined: 25 Jan 2006 Posts: 60 Location: The Villages, fl
Posted: Mon Apr 07, 2008 8:43 pm Post subject: Spark Plugs |
In a message dated 4/7/2008 12:39:21 A.M. Eastern Daylight Time, rphanks(at)grantspass.com writes:
Quote: | received a bunch of screw top B8ES plugs from Aircraft Spruce over a year ago. I got on the phone to customer service and they took them back. I wrote them an e-mail about the safety issue of solid vs screw tops and included the correct NGK stock number. I got absolutely no response. Interesting that they have chosen to add a legalese warning instead of stocking the right plugs. I hope this isn't indicative of a change of attitude for the worse at AC Spruce. Probably just standard CYA.
Roger in Oregon
the caps on the plugs are a big danger....ask me how I know....I just happened to be coming in for a landing one day (several years ago) and all of a sudden the engine felt like it was going to try to break awayfrom the firestar. Almost without looking around for a place to land which I was already doing, I killed the engine and just glidded in. Just added a lil fun to the flight . On the ground it was evident that one plug was not firing as pulling on the lead pulled it off of the plug....looking down inside the rubber boot I could see the cap still hooked into the distribution wire. at the bottom of the cap.
It happens.
George Randolph
Firestar driver (447) from The Villages, Fl
_________________ George Randolph
Firestar driver, The Villages, fl |
