elmar.hegenauer(at)telus. Guest
Posted: Mon Mar 31, 2008 8:23 am Post subject: gear collapse, no uplocks? |
I have a thought here..................
Some of the CJs (incl. mine) have no uplocks.
The gear is solely kept in the wells by the
air pressure in the actuators, what on the other
hand puts quite some stress on the bolts, studs
and brackets, especially doing aerobatics and
pulling Gs.
When I come out of a loop, I can see the red gear
lights going out and the air pressure gauge needle
climbing up until the pressure relief valve kicks in.
cheers
Elmar
jblake207(at)COMCAST.NET Guest
Posted: Mon Mar 31, 2008 3:13 pm Post subject: gear collapse, no uplocks? |
I leave my gear handle in the “UP” position during flight. I’ve been told to move to neutral. Does it matter?
Respectfully,
Jon Blake
adsavarese(at)hotmail.com Guest
Posted: Mon Mar 31, 2008 3:44 pm Post subject: gear collapse, no uplocks? |
FWIW Jon, depressurizing the landing gear actuators by putting the gear handle in neutral can cause the gear to slam when placing the gear handle into the down position. The reason being; you are depressurizing the actuators. With no pressure in the actuators, there is no "shock absorption" from the air escaping in the actuator when the gear handle is placed in neutral. As the air pressure is applied to one side of the actuator, the other side is depressurizing. Thus, the shock absorption. With no uplocks and the gear handle in neutral, the gear will have the opportunity move freely with g-loads.
The only way to prevent the gear from slamming after the gear handle is put in the neutral position is to move the gear handle back to the previous position. Then move the gear handle to the down position and the gear will not slam down.
Test this the next time you have the airplane on jacks. Raise the landing gear. Then put the gear handle in neutral. After the air exhausts, put the gear handle down. The landing gear will slam into position. Then try it with not putting the handle in neutral. ie: leave the gear handle in the up position. Move the handle down and see how smoothly the gear goes into the down and locked position.
One last comment. You will use more air from the main air tank when you depressurize the actuators by moving the gear handle to neutral.
Dennis
wlannon(at)persona.ca Guest
Posted: Mon Mar 31, 2008 6:22 pm Post subject: gear collapse, no uplocks? |
Dennis, et al;
I have no knowledge of the Yak gear procedure. The manual procedure for the CJ specifies the lever to neutral after retraction. The first step in extending the gear is "Gear Lever UP" for the reasons you have noted and is included on the cockpit placards I supply.
The 50/52 and the CJ main gear are totally different and cannot be compared in operation.
Having said all that, I expect that many CJ pilots do not use the neutral position (including yours truly most of the time!) and there are a number of CJ's with no uplocks so pressure on these must be maintained. Uplocks were removed for at time by the PLAAF (though perhaps only individual bases) during the 1970's, probably in response to uplock release failure. No one seems to know the whole story.
Moving the gear lever to neutral with the gear UP would certainly remove all the load from the adaptor fitting ( item that failed on Blitz's aircraft). Otherwise that fitting will be under continuous pressure since the actuator, in the extended position, is, by design, 3mm short of it's fully extended position.
In the DOWN position, assuming that the overcenter and the gap between the overcenter stop faces are correctly adjusted, the adaptor is also unloaded. In this case the actuator is fully retracted and the ball lock engaged. The proper gap setting ensures that the ball lock is not restricted from engagement and the adaptor fitting carries no load.
What all this seems to imply is that there is a reason for the "lever neutral" procedure. Maybe also explains why the factory hard chrome process on this part is apparently inadequate for a highly loaded item. The only load it would carry is the weight of the gear during transit.
Cheers;
Walt
ByronMFox(at)aol.com Guest
Posted: Mon Mar 31, 2008 7:32 pm Post subject: gear collapse, no uplocks? |
In a message dated 3/31/08 7:23:21 PM, wlannon(at)persona.ca writes:
| Quote: | Moving the gear lever to neutral with the gear UP would certainly remove all the load from the adaptor fitting ( item that failed on Blitz's aircraft). Otherwise that fitting will be under continuous pressure since the actuator, in the extended position, is, by design, 3mm short of it's fully extended position.
Interesting observation, Walt. Because my CJ has uplocks, I routinely placed the gear handle in the neutral after raising the gear for the first four years I owned the plane. For the last two years, however, I've just left it in the up position based on the recommendation of older and wiser CJ heads. Hmmm..... ...Blitz Fox
Create a Home Theater Like the Pros. Watch the video on AOL Home.
(http://home.aol.com/diy/home-improvement-eric-stromer?video=15&ncid=aolhom00030000000001) [quote][b]
Posted: Mon Mar 31, 2008 8:23 pm Post subject: gear collapse, no uplocks? |
Posted: Tue Apr 01, 2008 1:46 am Post subject: gear collapse, no uplocks? |
Is it possible the fracture was contributed to or accelerated by the operation of the landing gear from the neutral position due to the fact there is no back pressure in the actuator when placing the gear in the down position from the neutral position?
Dennis
cjpilot710(at)aol.com Guest
Posted: Tue Apr 01, 2008 4:29 am Post subject: gear collapse, no uplocks? |
In a message dated 4/1/2008 12:24:39 A.M. Eastern Daylight Time, wlannon(at)persona.ca writes:
I've owned my 1969 CJ for some 14+ year now. It never had up locks. It had 1088 hours on it and thousands of landings. I don't if the all the parts were original. Some 5 or 6 years ago I changed out bushings but for the exception seals that I've changed 5 or 6 times, the rest of the parts are original since I got it. I've put over 1,500 hours on my ship with out problems. There is no such thing as the perfect gear system, but the CJ's is damn close to it, as far as I'm concern. Like Walt, it'd be interesting to look at the fracture area.
Jim "Pappy" Goolsby
| Quote: | Hmmm is right. Two years operation is not much. I know of two CJ's with no up-locks in service for the past 12 years or so with no problem to date. I'm sure there are many others.
Would be interesting to view the fracture surfaces, locate the origin and maybe get some idea of progression.
Walt
Posted: Tue Apr 01, 2008 8:16 am Post subject: gear collapse, no uplocks? |
Hey Pappy;
I absolutely concur with all your comments except for the last " There is no such thing as the perfect gear system, but the CJ is damn close to it ---"
Just to stir the pot I have to say --- Yes there is and no it is not.
Getting the gear down and locked depends on having some air to blow on some goofy little air valves that may decide not to let go anyway. If they do decide to let go you still need air to be sure they get to "down and locked" If you run out of puff and still have some luck left the mains may get to overcenter AND engage the ball lock, not a hope for the nose gear.
On the other hand the perfect gear system does not need air, hydraulics (though it has that for gear UP), electrons running around in circles, motors, brushes etc. and all the other diabolical devices man has invented to have 3 in the green.
The perfect gear system is from North American Aviation 60 + years ago, it's on the Harvard/T6.
It is perfect for two reasons;
1. Moving the handle to down MECHANICALLY releases the gear.
2. GRAVITY puts it down AND locked. Hydraulic pressure catches up later.
Well maybe not exactly perfect. The early models had a tendency for the uplocks to release on their own which was not good. Later corrected with a spring bungee installation.
Cheers;
Walt
Posted: Tue Apr 01, 2008 11:59 am Post subject: gear collapse, no uplocks? |
In a message dated 3/31/08 9:24:18 PM, wlannon(at)persona.ca writes:
| Quote: | Would be interesting to view the fracture surfaces, locate the origin and maybe get some idea of progression.
Walt
My intention is to have the part analyzed by a metallurgical lab to establish if posiible what happened. Obviously, I'll share the results. ...Blitz
