kmraduls(at)pure.net Guest
Posted: Wed Mar 26, 2008 5:14 am Post subject: RV7-List Digest: 2 Msgs - 03/25/08 |
On Tue, 25 Mar 2008 23:57:41 -0700, RV7-List Digest Server wrote>
| Quote: | We didnt have any problems with the piston installation by just
following the directions.
The one thing I do notice is the minor flexing of the side rails
when the canopy is opened and you let go if it that last 6 inches or
so when the piston takes over and pushes it up. Increasing the
rigidity of the side rails would be a good idea however there is not
much access as there is barely enough room to get your fingers in
there to place the nut for the support block so I dont see how you
can get any foam and fiberglass in there.
J Brunke and others,
Use plate{anchor nuts} as the winged ears will corner out and eliminate
the need to hold on a wrench for tightning. Make a little 90 degree wire
tool to slide the plate nut over the screw whole.
Kelly Landrum
| | - The Matronics RV7-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
