John Brunke
Posted: Mon Mar 24, 2008 4:42 pm Post subject: tip up pistons |
Dear Listers,
Looking for words of wisdom on installing the tip canopy pistons. It seems relatively straight foward, but I've been wrong
before.
Are the measurements in the drawings accurate?
Also, the instructions that came with the pistons mention using foam and fiberglass to increase the rigidity of the
side rails. Has anyone done this and did you notice a difference.
Thanks in advance,
John Brunke
RV7- tip up almost tipping up.
| | - The Matronics RV7-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
pilots2(at)yahoo.com Guest
Posted: Tue Mar 25, 2008 6:50 am Post subject: tip up pistons |
John,
We didnt have any problems with the piston installation by just following the directions.
The one thing I do notice is the minor flexing of the side rails when the canopy is opened and you let go if it that last 6 inches or so when the piston takes over and pushes it up. Increasing the rigidity of the side rails would be a good idea however there is not much access as there is barely enough room to get your fingers in there to place the nut for the support block so I dont see how you can get any foam and fiberglass in there.
As a note; the first set of pistons didnt last long and would not relyably hold the canopy up. The second set (from Vans) work fine.
Reuven Silberman
N7WT 7A KSEE
"J. Brunke" <jdoody727(at)comcast.net> wrote:
[quote] Dear Listers,
before.
robin1(at)mrmoisture.com Guest
Posted: Tue Mar 25, 2008 10:38 am Post subject: tip up pistons |
What a timely thread.
I believe the struts on my 6A have lost some of their lifting power at about 400 flight hours. What is that 2,500 cycles including building. As this has been a slow degradation I don’t really remember how much better they were originally but at this point I need to push the canopy all the way up to the last 12-14” to hold. Sounds like new struts for me.
Are people replacing them with the struts sold by Vans C-690 at $27.00 each or are people buying else ware?
Robin
RV-4 Sold
RV-6A 400 Hours
RV-10 Flying sooner or Later… Probably Later [quote]
