912ULS Oil thermostat
lgold(at)quantum-associat
PostPosted: Fri Mar 21, 2008 11:02 pm    Post subject: 912ULS Oil thermostat Reply with quote
Although it was 60 degrees Fahrenheit today, I still had to wait 15 minutes for my 100HP 912ULS oil to get to 120F+degrees so that I could take off. While waiting, it dawned on me that maybe I need to consider a bypass thermostat for the oil cooler/radiator.
There is no mention of such a bypass in the Rotax Installation Manual or in my Zenith 701 manual.
Have any of you installed oil bypass thermostats? Is this something that I should consider adding, or will it just add another point of potential failure that should be avoided?
Les
tooch(at)hughes.net
PostPosted: Sat Mar 22, 2008 3:35 am    Post subject: 912ULS Oil thermostat Reply with quote
I have an oil thermostat for my 912ULS. I have a sea plane ( Aventura II ) and my whole engine is exposed. I have had this on my engine for about 2 years now and I know 2 other guys that have them also. it keeps my oil right at around 190 f. Before my oil never got close over 140. You can buy the thermostat from Lockwood.
I was also having a problem keeping my water temps up, especially in the winter. I was taping over my radiator and this got to be a pain so I talked to some guys in Canada and they use a ball valve on the heater line so as to restrict the flow of the coolant. I call Kerry at Lockwood and asked him if that would be a problem with the water pump. He said It wouldn’t. Now I can basically dial in my water temp to what I want no matter what the temp outside is.
Les
tooch(at)hughes.net
PostPosted: Sat Mar 22, 2008 3:38 am    Post subject: 912ULS Oil thermostat Reply with quote
By the way, the oil thermostat is designed so that if it were to stop working, it would stay in the position with the oil continuing to the oil cooler.
From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Les Goldner
Sent: Saturday, March 22, 2008 3:00 AM
To: rotaxengines-list(at)matronics.com
Subject: 912ULS Oil thermostat
Les
jack.kuehn(at)gmail.com
PostPosted: Sat Mar 22, 2008 6:30 am    Post subject: 912ULS Oil thermostat Reply with quote
Yes! Get one from Lockwood, they recommend them, they work, and they
are easy to install. I installed one after about 30 hours, and warmup
is faster in all weather, and no overheating. I have 124 hours on the
engine now. It does not shut down all flow through the oil cooler, so
that if the thermostat opens up, the engine does not get a cold slug
of oil. If it fails, it fails open. Has anyone out there seen one of
these fail yet?
Jack
On Sat, Mar 22, 2008 at 12:59 AM, Les Goldner
Les
hgmckay
PostPosted: Sat Mar 22, 2008 7:11 am    Post subject: 912ULS Oil thermostat Reply with quote
Les:
I recommend the oil thermostat. It makes life simple. You can get the exact same oil thermostat from Summit Racing probably for a better price. You will need to determine what type brass ½” fittings you will need (straight, or 90 degree ells-long sweep). This will depend on how your engine/oil cooling system is set up on your plane. I would not use the sharp 90 degree fittings unless you absolutely had to because of space limitations. You can go to the Summit Online store at summitracing.com and look for part N0. PRM-1070, or Perma-Cool Remote Mount Thermostats.
Hugh McKay
912UL
Allegro 2000
Sent: Saturday, March 22, 2008 2:00 AM
Les
Roger Lee
PostPosted: Sat Mar 22, 2008 12:37 pm    Post subject: Re: 912ULS Oil thermostat Reply with quote
Hi Hugh,
The guys here are right. The thermostat made by Thermo Cool is the correct one. It is set for 180F degrees and will fail open if ever there were to be a problem. They are widely used on Rotax 912 engines. They were originally made for cars and not Rotax engines. The temp setting is the only one that they make. It will be cheaper to buy on line and not from Lockwood. The ones on line are all the same that have the same part number. The fittings are nothing special and are brass. The fittings can be purchased from a hardware store. Just look at your oil hoses and see if you need all straight fittings or if you might need a 90 degree elbow. It will help you get to operating temp a little faster , but will not help with any temp gain over the 180F. Rotax recommends oil temps of 212F, but many can't get there depending on the time of the year.
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
PostPosted: Sat Mar 22, 2008 1:07 pm    Post subject: 912ULS Oil thermostat Reply with quote
Thank you Matt, Jack, and Hugh,
I will order a thermostat today.
Les
[quote] From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of Hugh
Sent: Saturday, March 22, 2008 8:10 AM
Subject: RE: RotaxEngines-List: 912ULS Oil thermostat
Les:
Hugh McKay
912UL
Allegro 2000
Les
0[b]
Catz631(at)aol.com
PostPosted: Sun Mar 23, 2008 5:03 am    Post subject: 912ULS Oil thermostat Reply with quote
Oil thermostats can be good things.Make sure you purge your oil system after installation.I had the same problem on a Kitfox and have installed a set of shutters at the oil cooler which are operated from a control in the cockpit.It's a lot better than tape over the cooler but probably not as effective as the thermostat.
      Dick Maddux
Create a Home Theater Like the Pros. Watch the video on AOL Home.
 Filesize:  349.06 KB
 Viewed:  539 Time(s)
pwmac(at)sisna.com
PostPosted: Sun Mar 23, 2008 9:58 am    Post subject: 912ULS Oil thermostat Reply with quote
Here are several useful items for cold weather operation of the Rotax
that I have seen at various air shows
1) The much discussed oil thermostat which bypasses the cooler
2) Simple ball valves that do the same thing as (1)
3) Thermostat for the radiator. Most people use the BMW unit which is
designed to install in the Rad hoses.Custom machined housing for a
regular auto stat has also been seen.
4) Shutters on the radiator with pilot cockpit control.
5) Removable shutter for the oil cooler. Slide in custom grooves.
6) Duct tape over either or both the radiator or oil cooler.
Different solutions with the ingenuity of the builder.
Paul
