graeme(at)coletoolcentre. Guest
Posted: Tue Mar 18, 2008 6:44 pm Post subject: CH701 Warpdrive |
Hi
Is any one flying a CH701 with warpdrive Prop.
I have Rotax 912extra (90-95hp)
69 inch three blade warp drive
What starting pitch?
Torque for 1/4" blade pinch bolts?
Torque for 8 mm prop to hub bolts?
Thanks in advance
Graemecns
kmccune
![](images/avatars/19685264047842535ec9ff.jpg)
Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
Posted: Wed Mar 19, 2008 3:00 am Post subject: Re: CH701 Warpdrive |
http://www.warpdriveprops.com/
Give them a call, others may be able to help with the starting point for the pitch, but you really should get torque specs from the factory.
_________________ “Always do what you are afraid to do.”
R.W. Emerson (1803-1882)
Dorothy McCune |
klr12(at)psu.edu Guest
Posted: Wed Mar 19, 2008 4:11 am Post subject: CH701 Warpdrive |
This was taken right from the Warp Drive web page
Propeller Torque Values
Propeller Bolt Torque Values--All Standard, HP and HPL hubs that use 1/4" bolts to clamp the blades in the hub should be tightened to 120 inch pounds. All Rotax bolt patterns that use 8 mm bolts to clamp the blades in the hub should be tightened to 175 inch pounds. All Standard, HP and HPL hubs that use 3/8" bolts to clamp the blades or mount the prop should be tightened to 35 foot pounds. Warp Drive propeller installations on direct-drive aircraft engines and other engines used on airboats must tighten the 5/16" clamping bolts to 200 inch pounds and tighten the 1/2" flange mounting bolts to 60 foot pounds. Torque 8mm bolts which attach the propeller hub to the engine flange to 175 inch pounds. Adherence to these torque values is imperative for reasons of safety. [b]
Posted: Wed Mar 19, 2008 2:52 pm Post subject: CH701 Warpdrive |
Thanks for the values I have read more closly and am ok with torque for my prop now.
I am going to try 17 derees to start and check it static and adjust
Graemecns
kissell
Joined: 05 Dec 2006 Posts: 18 Location: Beavercreek, Ohio
Posted: Wed Mar 19, 2008 4:35 pm Post subject: CH701 Warpdrive |
Graemecns,
I fly a 701 with the 100 hp Rotax and have found that 11 to 12 degree is about right. With 12 degree you will just go to 5800 in full power cruise and to only about 5400 in a 60 mph climb. I think you will find that 17 will be far to much.
Bob Kissell N701UB with 47 hour.
Posted: Wed Mar 19, 2008 6:41 pm Post subject: CH701 Warpdrive |
thanks
I will start at 12
Graemecns
lgold(at)quantum-associat Guest
Posted: Thu Mar 20, 2008 6:14 pm Post subject: CH701 Warpdrive |
I have a 3-blade Warpdrive on my 701 with a 100HP Rotax and found 11.2 better than 12-degrees. 12 would only give a maximum static RPM of about 5100.
[quote] From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Graeme
Sent: Wednesday, March 19, 2008 7:32 PM
Subject: Re: Re: CH701 Warpdrive
thanks
I will start at 12
Graemecns
Posted: Mon Mar 24, 2008 2:56 am Post subject: CH701 Warpdrive |
I have test run the 912 extra at 12.5 degrees I got 4800 rpm static.
I intend to change to 11 when I get som propper aircraft Quailty nuloc nuts as some of the bolt shop ones won't do 120in lbs
before Stripping.
I may have to go less pitch as I only expect 90-95hp from the motor.
Will check next weekend after ground run again.
GraemeCNS
