larywil(at)comcast.net Guest
Posted: Tue Mar 11, 2008 3:19 pm Post subject: Gas tank repair & Why They Leaked in the First Place! |
Hi gang,
I would like to thank all of you who helped me with my leaky fuel
tank last month. The removal of the tank was much easier than I
anticipated. The removal of the access plate was Hell.
Now, there is still a problem to solve. The tank has a 1/16" thick
x1" wide reinforcing ring flush riveted around the 5" access hole in
the tank wall ( rib). This was the mysterious 2nd layer of metal that
I saw when I tried to remove the access plate. This ring is riveted
to the outside of the rib. The nutplates that hold the access plate
sit inside the tank, and are thru-riveted to the ring. Thus, the ring
has 33 flush-head rivets sitting on the ring's surface. BUT NOT ONE
OF THEM IS SITTING FLUSH!!! The holes were countersunk, but not very
well. Every rivet is different but all of them are sitting proud of
the ring. This is why I have always had some leakage on this tank.
The Proseal between the access plate and the ring was 99.99%
effective, but I believe there were some gaps it couldn't fill in.
Time made it worse.
So how do I smooth out these flush rivet heads. I have decided to
install the access plate with a rubberized cork gasket (that I will
fashion myself) and use Permatex Aviation Form-A-Gasket. This will
make future removal easier than the proseal. However, these Unflush
Rivets must be improved upon. HELP, HELP!! You guys have been great
so far. I hope you can continue to tolerate my inexperience.
Thanks again.
Louis
Louis I Willig
1640 Oakwood Dr.
Penn Valley, PA 19072
610 668-4964
RV-4, N180PF
190HP IO-360, C/S prop
| - The Matronics RV-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
dsvs(at)ca.rr.com Guest
Posted: Tue Mar 11, 2008 3:33 pm Post subject: Gas tank repair & Why They Leaked in the First Place! |
Get a rivet grinding bit from Avery tool. The bit is used in your counter sink cage. adjust the height to be flush with the cage and then remove the protruding portions of each rivet.
---- Louis Willig <larywil(at)comcast.net> wrote:
Quote: |
Hi gang,
Time made it worse.
Thanks again.
Louis
Louis I Willig
1640 Oakwood Dr.
610 668-4964
RV-4, N180PF
Kellym
Posted: Tue Mar 11, 2008 9:19 pm Post subject: Gas tank repair & Why They Leaked in the First Place! |
If you weren't aware, there is a non-hardening version of PRC just for
access plates. It cleans up with isopropyl alcohol and is much easier to
get loose the next time you need into a tank.
Louis Willig wrote:
Quote: |
Hi gang,
I would like to thank all of you who helped me with my leaky fuel tank
Now, there is still a problem to solve. The tank has a 1/16" thick x1"
wide reinforcing ring flush riveted around the 5" access hole in the
tank wall ( rib). This was the mysterious 2nd layer of metal that I
saw when I tried to remove the access plate. This ring is riveted to
the outside of the rib. The nutplates that hold the access plate sit
inside the tank, and are thru-riveted to the ring. Thus, the ring has
33 flush-head rivets sitting on the ring's surface. BUT NOT ONE OF
the ring. This is why I have always had some leakage on this tank. The
Proseal between the access plate and the ring was 99.99% effective,
but I believe there were some gaps it couldn't fill in. Time made it
worse.
Rivets must be improved upon. HELP, HELP!! You guys have been great so
Thanks again.
Louis
Louis I Willig
1640 Oakwood Dr.
610 668-4964
RV-4, N180PF
KCHD |
rv8iator
Posted: Wed Mar 12, 2008 5:26 am Post subject: Gas tank repair & Why They Leaked in the First Place! |
Louis...
Be aware that permatex is soluble in alcohol. If you get a tank full of fuel with ethanol in it and it sits in the tank for awhile you risk a leak.
My lesson from a bad experience with permatex!
Chris Stone
RV-8s
Newberg, OR
_________________ C. Stone (RV8iator) |
Posted: Wed Mar 12, 2008 3:22 pm Post subject: Gas tank repair & Why They Leaked in the First Place! |
That'll work. If you don't have the special bit, a small grinding wheel
will work, too.
I've used a little 1" diameter diamond wheel in a Dremel tool. Hold it
at enough of an angle to keep the shaft/nut off the surface & gently
drag the edge of the wheel across the rivet head. You can do it with the
shaft almost parallel to the surface, too. Just brace the work so it
won't move & brace your hands on the work as you move the wheel across
the rivet head.
Play with it on some scrap to get a feel for how it wants to move and/or
grab before you attack the tank.
> Hi gang,
> Time made it worse.
> Thanks again.
> Louis
> Louis I Willig
> 1640 Oakwood Dr.
