sandford(at)melbpc.org.au Guest
Posted: Fri Mar 07, 2008 4:47 pm Post subject: mod 70 clearance for balance weights |
thanks lance, up at Easter
Visit - www.EuropaOwners.org
Ivor Phillips
Posted: Sat Mar 08, 2008 2:31 am Post subject: mod 70 clearance for balance weights |
Craig
I have kept the cables as well as using turnbuckles to keep it centered
Mod 11510 allow's retaining the cables,
Ivor
I have done the replacement of the elevator mass balance arm, using
the tufnol bushes as supplied instead of the cables to control lateral
movement, but i am wondering if i have too much clearance. I packed
the bushes with thin strips of timber to give about 1mm of total
clearance
but it still thumps when moved from side to side. I have concerns about
going too tight here in case it wants to bind through a steep turn or
similar. I wonder if the cables are not a better way to go.
mikenjulie.parkin(at)btin Guest
Posted: Sat Mar 08, 2008 11:20 am Post subject: mod 70 clearance for balance weights |
Craig,
I retained my cables also. But, take care, I was villified by the pundits
etc, for suggesting that the tufnol bushes was a backward step from the
cables/turnbuckle arrangement. It was and remains, in my opinion, an ill
thought out modification which at best, lacked elegance. Talk about
throwing the baby out with the bath water!!!!
regards,
Posted: Sat Mar 08, 2008 2:05 pm Post subject: mod 70 clearance for balance weights |
thanks mike, well I had already done the tufnol runners, I did think
the cables would be better, but thought the runners would be faster
as i still have the top off. Anyway I have both now, with turnbuckles
in there as well. I guess the runners would be good if you didn't have
the turn buckles as i would think it near on impossible to get the new
cables fitted around the nylon retainer on the torque tube if you had the
top on.
regards
Craig
