knowvne(at)aol.com Guest
imap8ntr(at)cox.net Guest
Posted: Wed Mar 05, 2008 1:01 pm Post subject: RotaxEngines-List Digest: 0 Msgs - 03/04/08 |
Mark
I have had a 582 with no problems. I still prefered to mix my oil. I have heard from more knowledgeable people that the oil injection is just one more thing to go wrong and fail unlike mixing the oil NEVER fails. I would certainly trust mixing oil if I was on a xc. Did a cross country of 300+ miles once and just brought some oil with me. Either figured out how much was in the gas tank and added the appropriate amount of oil or had a 5 gal jug along to mix. I have also "heard" that one has less control with oil injection because it doesnt adapt well when t he RPM changes. I fly trikes by the way and never thought of oil mixing as a pain. It was just my extra margin of safety.
Ivan
Phoenix, AZ
ElleryWeld(at)aol.com Guest
Posted: Wed Mar 05, 2008 1:14 pm Post subject: RotaxEngines-List Digest: 0 Msgs - 03/04/08 |
I prefer to mix my gas as well when I was running a 2 stroke that's just another thing to worry about failing and it was never a problem carrying extra oil buy a oil measuring cup from wicks aircraft I think it was and when you fill up at an airport know how much you pumped in and use your measuring cup to get the exact amount of oil then when the engine is running you know its getting the lubrication it needs
Ellery Test flying KITFOX & XAir and working on my Mk3Xtra
In a message dated 3/5/2008 4:02:40 P.M. Eastern Standard Time, imap8ntr(at)cox.net writes:
[quote] Mark
Ivan
Phoenix, AZ
Posted: Wed Mar 05, 2008 3:09 pm Post subject: RotaxEngines-List Digest: 0 Msgs - 03/04/08 |
Hi Guys Thanks for getting back to me on this... I can fully understand why you want to reduce any mechanical failure potential....
BUT here is a question directed at the Pre mix approach...
If premixing is viewed as safer so to maintain consistent lubrication
Isn't the motor ALSO more prone to carbon build up, Fowled plugs, and
gumming of the carburetors especially if you go on long reduced power glides???
With a consistent amount of Oil passing through the system Are you Especially
prone to these sorts of problem ???
Questions Regarding the Oil Injection systems:
As I understand it, Oil injection system do fail but they are designed to regulate
the correct amount of Oil needed ......
NOW here is where I'm lost.... This regulated Oil is based on what EXACTLY!!?
A) based only on engine RPMs
B) Throttle Position ????
I don't see the two as the same thing ???
More oil for Higher RPM and less oil for Less RPMs seems to be what we want
BUT An Engines RPM is not only increased by Throttle position it can also be
increased by diving the plane...
Hence my Question is it throttle position or RPM of motor that changes the
amount of oil being fed to the system..
If the answer is Throttle Position then this seems to be a good justification for installing a CLUCH ...
In My mind this would prevent high motor RPMs which would under lubricate the motor
when in a dive...
Would using a Clutch on the Prop be a good idea for a MOTOR that has an Oil Injection
system if in fact Oil being supplied is based only on the throttle Position???
Thanks Guys..
Mark
Posted: Wed Mar 05, 2008 4:04 pm Post subject: RotaxEngines-List Digest: 0 Msgs - 03/04/08 |
I have put a lot of time on 5 different 2 stroke engines and I never had a carbon build up problem.
as far as what regulates the oil Throttle Position and or RPM you will have to ask someone that is an expert on that I don't claim to be a 2 stroke professional even though I have a lot of time flying with them and I don't want to miss lead you on something I am not sure of
Ellery in Maine Building MK3Xtra
In a message dated 3/5/2008 6:10:46 P.M. Eastern Standard Time, knowvne(at)aol.com writes:
[quote]Hi Guys Thanks for getting back to me on this... I can fully understand why you want to reduce any mechanical failure potential....
when in a dive...
Thanks Guys..
Mark
Posted: Wed Mar 05, 2008 5:00 pm Post subject: RotaxEngines-List Digest: 0 Msgs - 03/04/08 |
Thanks Ellery
Float Flyr
Posted: Thu Mar 06, 2008 6:07 am Post subject: RotaxEngines-List Digest: 0 Msgs - 03/04/08 |
Do you put the oil in first and add the gas or the other way around.... Gas and oil are supposed to be thoroughly mixed before being used. To do that you really should either buy your gas pre mixed (marina) or mix it in a separate tank before putting it in your plane.
BTW the recommended procedure is to put the oil in a mixing container first then add the gas.
Just out of curiosity has any one actually seen an injection pump break?? I’ve seen oil filter blocked, regular checks weren’t done. I’ve seen pumps air locked they weren’t properly bled when installed.... Those engines were all inverted (plugs down).
I live in a small town where, I’m just about the only one in town who doesn’t have an oil injected snowmobile. I sold mine a few years back to go flying. Not one of the locals mix their gas.. And surprisingly, to me, none have had any problems with their injection systems. They use their sno-mo(s) under excruciating circumstances hauling loads of wood for next winter, racing and visiting their “camps” up in the woods. Thier maintenance on the oil filters is minimal. I’ve seen just about every other part either be demolished or worn out but the injector pumps never seem to quit.
Noel
From: owner-rotaxengines-list-server(at)matronics.com [mailto:owner-rotaxengines-list-server(at)matronics.com] On Behalf Of ElleryWeld(at)aol.com
Sent: Wednesday, March 05, 2008 5:42 PM
To: rotaxengines-list(at)matronics.com
Subject: Re: Re: RotaxEngines-List Digest: 0 Msgs - 03/04/08
Mark
Ivan
Phoenix, AZ
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
