Dale Ensing
Posted: Wed Feb 20, 2008 5:55 pm Post subject: Garmin396/SL40 interface |
I have been considering wiring my Garmin 396 GPS to the SL40 COM for frequency loading into the COM and wondering if it is worthwhile doing.
I do not understand what action loads the com list for an airport from the GPS to the Com. Have study both the GPS and SL40 manuals but my old brain isn't getting it. When the Com tab is selected on the airport page in the GPS, does that automatically send the list to the COM?
What am I missing?
Dale Ensing
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
rv-9a-online(at)telus.net Guest
Posted: Thu Feb 21, 2008 8:46 am Post subject: Garmin396/SL40 interface |
The 396 also sends the frequencies of the nearest airport automatically to the Com. Or if you are in a programmed route, the frequency of the next airport waypoint is sent. You can also send manually as you have noted.
Very handy.
fvalarm(at)rapidnet.net Guest
Posted: Thu Feb 21, 2008 11:00 am Post subject: Garmin396/SL40 interface |
Does anybody know if this feature also applies to the the 296?
Bevan
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Vernon Little
Sent: Thursday, February 21, 2008 8:39 AM
Subject: RE: AeroElectric-List: Garmin396/SL40 interface
Very handy.
Dale Ensing
Posted: Thu Feb 21, 2008 1:06 pm Post subject: Garmin396/SL40 interface |
No, the 296 does not have the VHF Com feature. I recently replaced my 296 with a 396 to get the XM weather.
Now I wish I had put the interface wire on the SL40 for possible future up grade of the GPS when I installed the radio. This is not going to be fun under the panel.
Dale
RV-6A
Aero Plantation
Weddington NC |
Posted: Thu Feb 21, 2008 1:13 pm Post subject: Garmin396/SL40 interface |
Actually, this is the operation of my 296. 396 is the same.
Vern
Posted: Thu Feb 21, 2008 1:41 pm Post subject: Garmin396/SL40 interface |
Thanks Vern
Bevan
Sent: Thursday, February 21, 2008 1:08 PM
Vern
Dale Ensing
Posted: Thu Feb 21, 2008 2:27 pm Post subject: Garmin396/SL40 interface |
Vern, you must have a different version of the 296 then mine. I still have my 296 and just checked the book. It says nothing about this function. Or, it this a well kept secret by Garmin?
Dale
RV-6A
Aero Plantation
Weddington NC |
aaaron(at)tvp.com.au Guest
Posted: Thu Feb 21, 2008 3:18 pm Post subject: Garmin396/SL40 interface |
I have a 296 and mine does it.
Allan
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dale Ensing
Sent: Friday, 22 February 2008 9:22 AM
Subject: Re: AeroElectric-List: Garmin396/SL40 interface
Dale
Posted: Thu Feb 21, 2008 6:02 pm Post subject: Garmin396/SL40 interface |
Two things:
1) Garmin's documentation leaves a lot to be desired. Check online for a new Pilot's Guide
2) In order to get this function to work, you need recent software and must configure the RS-232 output to NMEA/VHF Out
Of course, you need the RS-232 connected to the SL40.
Dale Ensing
Posted: Thu Feb 21, 2008 6:15 pm Post subject: Garmin396/SL40 interface |
Allan and Vern,
I am curious.....how did you guys learn of the GPS/SL49 interface function on the 296? There is nothing about it in the manual and nothing on the product info pages on the Garmin web site.
Dale
RV-6A
Aero Plantation
Weddington NC |
Dale Ensing
Posted: Thu Feb 21, 2008 6:31 pm Post subject: Garmin396/SL40 interface |
Must be the recent software as I do not have a 'NMEA / VHF out' option for the Com tabs on my 296. It is a year and a half old.
RV-6A
Aero Plantation
Weddington NC |
Posted: Thu Feb 21, 2008 7:43 pm Post subject: Garmin396/SL40 interface |
I need to go back through the manual, but I know there are two com outputs on the 296, one I use for A/P and the other for the SL40. I seem to remember that there is a wiring schematic in the 296 manual that made it pretty clear how to wire it up to the radio. I read it first in the SL40 manual - just wired it up and it worked. I would probably not have realised it unless i had read the SL40 manual first.
If you want me to dig the info out the the manuals, let me know.
Allan
Sent: Friday, 22 February 2008 1:13 PM
Allan and Vern,
Dale
Dale Ensing
Posted: Fri Feb 22, 2008 5:26 am Post subject: Garmin396/SL40 interface |
Thanks Allan,
Pleae don't spend a lot of time to go back through your manual. It is only academic for me as I am now using the 396. I do intend to sell the 296 so would like to pass along the info if the function is there.
When I go down thru the menus under the Com 1 and Com 2 tabs there is no option that indicates there is VHF out. The wiring diagram in my manual is very clear but again no indication of any VHF signal.
Dale
RV-6A
Aero Plantation
Weddington NC |
Posted: Fri Feb 22, 2008 12:24 pm Post subject: Garmin396/SL40 interface |
I think Garmin intro'd this function early last year. You need to upgrade the software if you haven't in a while.
Vern
jmcburney(at)pobox.com Guest
Posted: Sat Feb 23, 2008 3:22 pm Post subject: Garmin396/SL40 interface |
Dale,
the output you're loking for isn't a VHF signal. The GPS is sending a data
signal to the receiver to tell it what freq. to tune. Probably a serial
data port.
Blue skies and tailwinds
Jim
CH-801
DeltaHawk diesel
Augusta GA
90% done, 90% left
Posted: Sat Feb 23, 2008 4:22 pm Post subject: Garmin396/SL40 interface |
That correct.I tink you set it as garmin protocol but I'm not certain.
allan
Dale Ensing
Posted: Sun Feb 24, 2008 5:07 am Post subject: Garmin396/SL40 interface |
Yes, I know it is not literally a VHF transmission, (poor choice of word by
me) but Garmin uses that terminology in their setup page.....at least in
the 396.
I am going to load the latest Garmin software into the 296 today as Vernon
Little suggest.
BTW since I asked the original question about the value of loading the VHF
frequencies from the GPS to the Com, I have completed the wiring in my 6A.
It works and I think I am going to love it.
Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
