hotwheels
Posted: Sun Feb 17, 2008 12:43 pm Post subject: TurboCAD format files |
.. A major bug (in my opinion) that TurboCAD folks claim will be fixed in v15. Of course, to get that you have to buy it AGAIN. Nice customer experience, huh?
I experienced numerous program crashes, hangs and
data corruption when editing and saving AutoCAD format files using
TurboCAD v14. After numerous emails to TurboCAD customer support, they finally mentioned that editing files using native TurboCAD format is better supported (doh!). No problems since then and life is now
good!
AutoCAD format=READ ONLY
Jay
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
Posted: Sun Feb 17, 2008 1:35 pm Post subject: TurboCAD format files |
Hi Jay,
The TurboCAD I've used, versions 11 thru 14, never gave me any
difficulty saving files as AutoCAD and bringing in AutoCAD files to
TurboCAD.
This was necessary because engineering staff were using AutoCAD to model
many of the systems in 3D which was much faster
in TurboCAD as well as rendering in color. Never had any problems so
long as you saved from the version of AutoCAD represented.
I've never had hangs, crashes or corrupted data with TurboCAD in 6 years
use. It replaced ProE and AutoCAD for design work where intensive
data wasn't needed for repeat manufacturing. I think it's great
software despite IMSI having an odd marketing group.
Jay Brinkmeyer wrote:
... A major bug (in my opinion) that TurboCAD folks claim will be fixed in v15. Of course, to get that you have to buy it AGAIN. Nice customer experience, huh?
good!
Jay
hotwheels
Posted: Mon Feb 18, 2008 9:01 am Post subject: Re: TurboCAD format files |
Using v14.2, this scenario was very repeatable on my WinXP machine. Open up the seminar.dwg from AEC11.
Make a change, save (as .dwg format) and then close the file. Do this until the file gets to be ~1.5MB. At this point, opening the .dwg file takes longer and longer. Sometimes the file opens after a really long time, but usually the program just hangs forever. Now your data is "gone" and the file is corrupted... Look at the running application when this happens using Task Mgr. You will see that TurboCAD consumed memory size just keeps growing and growing as there's a memory leak. More annoying is the occasional program faults seen during cut+paste or save operations.
TurboCAD support confirmed the above as a known bug when using .dwg AutoCAD formatted files. The fix is only available in v15 - you get to buy it again (not!).
No issues where seen doing the above steps after saving the AutoCAD format seminar.dwg file as a TurboCAD format .tcw file.
Jay
nuckolls.bob(at)cox.net Guest
Posted: Mon Feb 18, 2008 5:33 pm Post subject: TurboCAD format files |
At 09:01 AM 2/18/2008 -0800, you wrote:
it again (not!).
Don't save as .dwg
If TurboCAD is your vehicle of choice, there's
no value in causing it to open work product in
one language, interpret its native language for
editing and then converting back to the source
language for storage.
Use the .dwg files as a one-time source and
let TurboCAD do what it does best after that.
