GLJSOJ1
Joined: 18 Aug 2007 Posts: 82 Location: Chesapeake, Virginia
Posted: Thu Feb 14, 2008 6:53 am Post subject: Dynon EFIS battery |
Short story, I let my installed battery on my Dynon go dead because I didn't put a fuse on the "keep alive" wire. I dropped a fuse in, and charged the aircraft main battery. No charge. I checked the paperwork, and checked the yellow keep alive wire, correctly wired, and pulled the harness off the back of the instrument, the No 2 pin is the keep alive pin and it has 12+ volts with the master switch off. Can anyone give me a reason it will not charge. It's not flying yet.
_________________ 601XL N676L FLYING PHASE I
CHESAPEAKE VA |
david_a_g_johnson(at)btin Guest
Posted: Thu Feb 14, 2008 9:28 am Post subject: Dynon EFIS battery |
The same thing happened to me!
It appears that if the internal battery goes completely flat, the internal
recharging circuit won't work (it thinks there's no battery to recharge).
I had to remove the battery (behind a small panel on the right-hand side)
and send it back to my supplier (I'm in the UK, so not to Dynon themselves)
who have a rig to re-charge the battery.
There was also a problem with the internal battery charging on early
versions of the software - make sure you are up to date, the latest can be
downloaded from the Dynon web-site.
Dave Johnson
601XL Jab.3300, It's looking like an aeroplane (almost!!)
Gig Giacona
Posted: Thu Feb 14, 2008 9:36 am Post subject: Re: Dynon EFIS battery |
There was a post on the Dynon support forum about this very issue recently. I think the answer was make sure you were running the newest version of the software.
601XL Under Construction
Martin Pohl
Joined: 30 Jan 2006 Posts: 118 Location: CH-8645 Jona SG, Switzerland
