s_thatcher(at)bellsouth.n Guest
Posted: Wed Feb 13, 2008 5:47 am Post subject: Flutter Once Again |
I know, it's been beat to death. But here is my last (hopefully) reflection
on what caused the last WING flutter case in Forida several month ago.
As you may recall (search archives for flutter for an exhausting display of
comments and suggestions), there were two 601XL's that experienced either
flutter or severe torsional or vertical vibrations that appeared to be on
the verge of destroying the aircraft, but were saved from that fate by luck
or pilot intervention.
The last one that was reported was in Florida and after talking with the
mechanic who was repairing the aircraft, this is what happened.
During a descending turn to the right, the entire aircraft began to shake
violently at which time the aircraft was landed at the nearest airport and
inspected (no information was provided on how they stopped the vibrations).
Damage was noted to the flap bearing material that showed the nylon had
severe elongations in and around the pinion of the flap actuator. The rudder
had severe damage.
So what caused the "flutter" to occur?
It appears that a previous hangar accident caused one of the ribs in the
rudder to be bent. The owners then repaired the rib and purchased new skin
to replace the damage. To strengthen the rib, either wood or metal (I don't
remember which) was used as a doubler on the rear portion of the rib.
It is thought that the addition of the doubler to the rib affected the mass
balance of the flying rudder, thus directly contributing to the flutter
condition (in the tail)! This was then transferred to the wings and appeared
to be coming from them. It was also thought that the pilot may have
contributed to the "flutter" by exacerbating the situation in an attempt to
stop the "flutter."
So, it appears that as long as we follow the construction methods outlined
by Zenith, we should not have any problems. If you deviate from the plans,
be sure you know the consequences of your actions. Even the slightest change
can cost you your life... especially when they occur on control surfaces.
Always call Zenith. They always will provide you with the help and expertise
you need to make that repair.
I am in no way faulting the pilot in Lantana for the repair work or actions
during the flight. Sometimes our reactions are just that and none of us are
immune from making similar mistakes. But hopefully, we all can learn from
those mistakes.
Scott Thatcher, Palm Beach Gardens, FL
601XL with Corvair, Registered as E-LSA
N601EL
daveaustin2(at)primus.ca Guest
Posted: Wed Feb 13, 2008 6:42 am Post subject: Flutter Once Again |
Scott's information on the possible cause of flutter in the 601 from Florida
pushes me to detail a rudder flutter that I experienced back some 11 years
ago which Don Chapman can attest to. The a/c is a trike.
Flying straight and level with some air induced bumps of low level, the a/c
started to vibrate at a very low frequency, maybe twice a second. I'd
describe this vibration as very concerning but not panic inducing. I
immediately reduced power, to no effect, raised the nose to reduce speed, to
no effect. Then realized it was the rudder fluttering. So I pushed hard on
the rudder pedals in an attempt to tighten the control cables and this
stopped the vibration.
On ground checking found that the rudder cables were too loose. Long
brainstorming came to the conclusion that I had adjusted the cable tension
with the nosewheel on the ground taking weight and had allowed too much
slack for when the wheel was unladen when flying. That 80 degree angled
firewall could kill you.
I jacked the nosewheel off the ground and set the cable tension to spec in
flying position and have never had the problem re-occur.
FWIW.
Dave Austin 601HDS - 912, Spitfire Mk VIII
Jeyoung65(at)aol.com Guest
Posted: Wed Feb 13, 2008 7:37 am Post subject: Flutter Once Again |
Dave, what cable tension did you use. I am building a 601HD and do not recall any cable tension called out. This sounds like a good idea for setting the tension. Jerry of GA
In a message dated 2/13/2008 9:43:54 A.M. Eastern Standard Time, daveaustin2(at)primus.ca writes:
| Quote: | --> Zenith-List message posted by: "Dave Austin" <daveaustin2(at)primus.ca>
The year's hottest artists on the red carpet at the Grammy Awards. AOL Music takes you there.
steerr(at)bellsouth.net Guest
Posted: Wed Feb 13, 2008 7:56 am Post subject: Flutter Once Again |
I didn't save the original post, so don't have the exact wording,
but... Since the firewall is slanted back, the cable tension will be
less when the plane is on the ground and the nose gear is compressed,
won't it? With the plane in the air, and the nose gear at the bottom
stop (i.e., the steering rod attachment points, and therefore the rudder
pedals, more forward), the cable tension should be higher.
Am I missing something?
Bill
Jeyoung65(at)aol.com wrote:
| Quote: | Dave, what cable tension did you use. I am building a 601HD and do not
from Florida
11 years
level, the a/c
Posted: Wed Feb 13, 2008 9:48 am Post subject: Flutter Once Again |
Bill, you are correct. But I recognized that and decided to leave some
slack with the nosewheel on the ground so that the cables would not be too
tight in flight mode. I gave a bit too much allowance. Hence the advice..
adjust the tension with the nosewheel off the ground.
Posted: Wed Feb 13, 2008 9:55 am Post subject: Flutter Once Again |
Bill,
the tension is not impacted whether on land or air, since you have control rods, (a solid itme) from rudder pedals though the fir walll the Nose whell. Stiff rudder cables are not as a concern as the Aileron and Elevator cables, which would be around 30 #. or 4 Inch #.
Tight enough to not bind the movement and still be smooth.
Juan
Posted: Wed Feb 13, 2008 10:04 am Post subject: Flutter Once Again |
Jerry,
It was a long time ago and I cannot find the specs for cable tension. I would say however, that I would not tighten to the 30 to 40 lbs as given for the elevators and ailerons as in another msg on this. If I recall I used "just snug". Very scientific!
Posted: Wed Feb 13, 2008 10:14 am Post subject: Flutter Once Again |
Ok, I'm with you. Thanks.
Bill
Dave Austin wrote:
some slack with the nosewheel on the ground so that the cables would
not be too tight in flight mode. I gave a bit too much allowance.
Hence the advice.. adjust the tension with the nosewheel off the ground.
Posted: Wed Feb 13, 2008 10:26 am Post subject: Flutter Once Again |
I respectfully disagree with your first sentence. It is PRECISELY
because there are solid rods between the rudder pedals and the nose gear
that the tension varies as the nose gear moves vertically. Note that,
due to the angle of the firewall, it isn't pure vertical movement; it
also moves horizontally. When the nose gear is at the bottom stop, the
rod attachment points are farthest forward and thus the rudder pedals
are farthest forward, thereby pulling harder on the rudder cables. When
the nose gear is off the bottom stop, as when it is on the ground, the
rod attachment points move back, thereby causing the rudder pedals to
move back, thereby causing less tension in the rudder cables.
Bill
Juan Vega wrote:
Bill,
tjs22t(at)verizon.net Guest
Posted: Wed Feb 13, 2008 11:16 am Post subject: Flutter Once Again |
>the tension is not impacted whether on land or air, since you have control rods, (a solid item) from rudder pedals though the fire wall the nose wheel.
+++ Beg to differ. When the nose gear compresses on the ground, the steering rods move backward very, very slightly (~13 degree slant of firewall). As they are a solid link as you pointed out, the rudder pedals will also move rearward a bit. Since the cables to rudder are mounted to the pedal tops, a minor lessening of tension in the cables will result. The "tension" (distance) between the pedals and nose gear will not change as it's a fixed arm, the distance/arm between the pedals and rudder horn will change as nose gear extends, as in flight, or compresses, as on the ground.
| Quote: | for the elevators and ailerons as in another msg on this.
Dave, the cable tension from page 29 of our old Construction Manual is for all control surfaces, not just aileron and elevator. I went to the manual and checked - I would not make the statement if it were not factual. As you said, "It was a long time ago and I cannot find the specs for cable tension." If it's true that Chris said 25 to 30 pounds then that should be good enough for those who have access to a tensionometer.
Respectfully
Jeff Small HDS/3300
Posted: Wed Feb 13, 2008 1:11 pm Post subject: Flutter Once Again |
Bill,
I respect your position, though I think you are over thinking it. question though, when is flutter appraent, when in the air or land, or during the transition? set the tension so as not to impede motion, thats it. Secondly if the rods go through their full movement, then someone is landing way to hard. We are not building x-15 rocket ships here, set it to feel solid, but not to impede movement, if that does not help, sorry.
Juan
planejim(at)bellsouth.net Guest
Posted: Wed Feb 13, 2008 2:14 pm Post subject: Flutter Once Again |
Hey Listers,
When building my 601HD 12 years ago I asked ZAC about this same perceived
problem ( rudder cable tension changes as nose gear moves up and down). At
that time Nick stated that it had not been reported as a problem. It turns
out that then cable tension lessens upon landing when the gear goes up and
aft. In reality the gear doesn't move all that much as seen by the marking
on the grease on the gear. I set my cable tension for "in flight" when the
gear is at the bottom of it's travel. I used about 20 to 25 lbs. tension.
No problem over the past 575 hours.
Rudder flutter could be serious and perhaps "loose" cables, along with
"unbalanded" rudder could lead to it. The "all flying" rudder on the Zenith
may be different. I'm not a engineer so I don't know.
I just know that I've had no problem with my 601HD.
Jim Hoak
bryanmmartin
Posted: Wed Feb 13, 2008 3:23 pm Post subject: Flutter Once Again |
As long as you build your plane with no "slop" in the controls, you
are not going to see any signs of flutter in a Zenith airplane within
the designed speed limits unless you've deviated from the design in a
MAJOR way. I have test flown my Zodiac to 200 MPH IAS during the phase
I test period with no evidence of flutter. I didn't calculate the TAS
for that flight but it was probably close to 210 MPH. Based on my test
flights, I felt confident setting my Vne at 180 MPH as per the info I
got from ZAC. I just tightened my turnbuckles until the cables felt
snug with no slack and called it good.
On Feb 13, 2008, at 5:09 PM, Jim Hoak wrote:
Hey Listers,
perceived problem ( rudder cable tension changes as nose gear moves
up and down). At that time Nick stated that it had not been reported
as a problem. It turns out that then cable tension lessens upon
landing when the gear goes up and aft. In reality the gear doesn't
move all that much as seen by the marking on the grease on the gear.
I set my cable tension for "in flight" when the gear is at the
with "unbalanded" rudder could lead to it. The "all flying" rudder
on the Zenith may be different. I'm not a engineer so I don't know.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Wed Feb 13, 2008 5:31 pm Post subject: Re: Flutter Once Again |
Scott,
Thanks for bringing us up to date with the FL flutter incident. I was wondering what was discovered.
I found it interesting that the holes on the nylon bearings in the flaps were elongated. When I built my flaps I was a little concerned that they were only backed up by the thin material of the rib so I added a doubler made of 0.040 to the inside of the rib. Whether doing so was a good idea remains to be seen.
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
jmcburney(at)pobox.com Guest
Posted: Thu Feb 14, 2008 8:22 am Post subject: Flutter Once Again |
Greetings, all,
When tensioning cables using the "scientific" "just snug" method, be very
careful. Loose cables are easy to see, but when you get the tension in, the
cables don't SEEM to get very tight, because the "give" of the structure
begins to come into play. A tensionometer is recommended, but if that's not
possible (Yeah, they're $$$$$), always approach the tension from the slack
side, in small steps, till JUST snug.
Re: rudder cables loosening when weight is on the nosewheel; in the 801 they
get VERY slack as the nosewheel retracts, so they must be set with it fully
extended. Zenith says this isn't a problem, though, as the bungee should
keep the nosewheel extended except during a bad pitchdown after landing or
when hitting a hard bump when taxiing. My experience flying the Zenith demo
bears this out.
Blue skies and tailwinds
Jim
CH-801
DeltaHawk diesel
Augusta GA
90% done, 90% left
Gig Giacona
Posted: Thu Feb 14, 2008 9:37 am Post subject: Re: Flutter Once Again |
Maybe I'm missing something but how would you get all that into the areas where the cable was located?
601XL Under Construction
Posted: Thu Feb 14, 2008 9:55 am Post subject: Flutter Once Again |
That was his calibration rig. The tool itself is fairly small, shown at
the top, with the three rollers. Take a look at his web site.
Bill
Gig Giacona wrote:
Posted: Thu Feb 14, 2008 11:37 am Post subject: Flutter Once Again |
That is the gauge in the calibration jig. The little device with the three
pulleys is the actual gauge. Navigate Larry's site to see the individual
pieces.
-- Craig
Gig Giacona
