bhancock(at)worldwidewarb Guest
Posted: Tue Feb 05, 2008 9:59 am Post subject: Rudder Pedal mod |
On Feb 4, 2008, at 11:58 PM, Yak-List Digest Server wrote:
Quote: | Time: 01:35:13 PM PST US
Subject: Rudder Pedal Mods
Who is it in the Yak/CJ community that has the mod for the rudder
pedals for the
CJ to create more leg room. Thanks, Roger Bieberdorf
Gang,
We will post pics of the rudder pedal mod on our new web site soon. I
currently have nearly a dozen orders and will be making a production
run in our machine shop shortly. They will be milled out of billet
aluminum. If you're interested in being part of this batch. Let me
know. Again, cost is $250/set. Nets 4" of leg extension and is simple
to install.
Barry Hancock
Worldwide Warbirds, Inc.
office (909) 606-4444
cell (949) 300-5510
www.worldwidewarbirds.com
www.cj6.com
Express Mailing address:
7000 Merrill Ave, B-110, Unit J
Chino, CA 91710
Regular Mailing address:
7000 Merrill Ave., Box 91
Chino, CA 91710
The information contained in this e-mail message is intended only for
the personal and confidential use of the designated recipients. If the
reader of this message is not an intended recipient, you are hereby
notified that any review, use, dissemination, forwarding or copying of
this message is strictly prohibited. Please notify us immediately by
reply e-mail or telephone, and delete the original message and all
attachments from your system. Thank you
bu131(at)swbell.net Guest
Posted: Tue Feb 05, 2008 11:08 am Post subject: Rudder Pedal mod |
does any one know if the 55 rudder pedals are the same as the cj?
please advise
pedals for the
Gang,
to install.
Barry Hancock
cell (949) 300-5510
www.cj6.com
Chino, CA 91710
Chino, CA 91710
flushjohnson(at)charter.n Guest
Posted: Fri Feb 08, 2008 2:28 am Post subject: Rudder Pedal mod |
how about a mod for the rear peddles?
dsavarese(at)elmore.rr.co Guest
Posted: Fri Feb 08, 2008 4:39 am Post subject: Rudder Pedal mod |
Disassemble the section just behind the knob and remove the spacer. The spacer is about 3/4" long and the shaft for the knob goes through it. Removing it will then give you the same space in the rear as is in the front before any pedal modifications.
Dennis
Posted: Sat Feb 09, 2008 8:34 pm Post subject: Rudder Pedal Mod |
On Feb 8, 2008, at 11:58 PM, Yak-List Digest Server wrote:
Quote: | ________________________________ Message 1 _____________________________________
Time: 02:28:14 AM PST US
From: "Forrest Johnson" <flushjohnson(at)charter.net (flushjohnson(at)charter.net)>
Subject: Re: Re: Rudder Pedal mod
Hi Forrest,
Works the same for the front and the back. First set came off the machine last night...we will be doing destructive testing on the first few sets to ensure adequate strength....our guess is they'll fail around 1200#.
Also, I'm not an expert on the -52, but it was my understanding that the spacer in the rudder pedal on the -52 was put there to prevent the rudder from hitting the spar. Is that correct, Dennis?
Great day for flying here!
Cheers,
Barry
Barry Hancock Worldwide Warbirds, Inc.
office (714) 730-3958
cell (949) 300-5510
Posted: Sun Feb 10, 2008 6:42 am Post subject: Rudder Pedal Mod |
Barry,
Ref your question - spacer in the rudder pedal on the -52 was put there to prevent the rudder from hitting the spar. Is that correct, Dennis? I removed mine years ago and have not found the rear rudder pedal hitting the main spar at all. That may or may not hold true for all 52's. I'd suggest a person wanting to improve the rudder adjustment travel length in the rear cockpit remove the spacer and check for clearance between the rear of the rudder pedals and the main spar when fully deflected. An alternative would be to shorten the spacer and reinstall. By shortening the spacer by about 75%, the rudder adjustment will increase, but may prevent the rudder pedals from hitting the main spar.
Dennis
fougapilot
Joined: 20 Jul 2007 Posts: 89 Location: Flat on my back with minimum airspeed
Posted: Thu Feb 28, 2008 3:33 am Post subject: Re: Rudder Pedal mod |
Barry,
Being in the 6'+ club, I am interested by your Net 4".
Do you have pictures of an installed set? I have looked at your website but couldn't find any.
Dan
skidmk
Joined: 19 Nov 2007 Posts: 171 Location: Ottawa, Ontario
Posted: Thu Feb 28, 2008 5:54 am Post subject: Re: Rudder Pedal mod |
Hi Dan,,
sent you the Barry's info pac last night.
_________________ Mike "Skidmk" Bourget
Ottawa, Ontario |
fougapilot
Posted: Thu Feb 28, 2008 9:48 am Post subject: Re: Rudder Pedal mod |
Which did not include any pictures...
Hence my request with Barry.
D
skidmk
fougapilot
Posted: Fri Feb 29, 2008 4:26 am Post subject: Re: Rudder Pedal mod |
NO!!!! I will never turn to the dark side!!!!
Once you've gone Yak you wont go back!
Once you've gone Mac you wont go back!
D
Posted: Fri Feb 29, 2008 10:50 am Post subject: Rudder pedal mod |
Hi Dan,
I sent you the info with pics.
UPDATE: We had to make a slight adjustment to the prototype after test fitting in a CJ. We want to make it perfect. New design should be done today. We'll test fit, then do destructive load testing and are hopeful it will be ready to go next week...
Cheers,
Barry
Barry Hancock
cell (949) 300-5510
www.cj6.com
Chino, CA 91710
Chino, CA 91710
The information contained in this e-mail message is intended only for the personal and confidential use of the designated recipients. If the reader of this message is not an intended recipient, you are hereby notified that any review, use, dissemination, forwarding or copying of this message is strictly prohibited. Please notify us immediately by reply e-mail or telephone, and delete the original message and all attachments from your system. Thank you
On Feb 28, 2008, at 11:58 PM, Yak-List Digest Server wrote:
Time: 03:36:16 AM PST US
Subject: Re: Rudder Pedal mod
From: "fougapilot" <fougapilot(at)hotmail.com (fougapilot(at)hotmail.com)>
Barry,
find any.
Dan [b]
