dashvii(at)hotmail.com Guest
Posted: Wed Feb 06, 2008 12:10 am Post subject: Lightning Weight and Balance |
Quote: | Quote: | In the past there have been requests for weight and balance data for the Lightning. Keep in mind that this is anexperimental and therefore your aircraft will depend on what you put into it. I typed up a weight and balance from thedemonstrator. I know that this will get out of order when I put it in an email, but if you want the info it shouldn't be too hard tofigure out how to get it spaced back out right. It should give you an idea of how much you can carry and where you can carry itBrian W.Aircraft Type: Arion LightningN Number: N323ALSerial Number: #0029Reference Datum: FirewallLevel Point: Across cockpit top rail longitudinally, and across cockpit Forward Limit: 26.5”Aft Limit: 36.5”<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /> Initial Weight and Balance Weight (lbs.) Arm (in.) Moment (in.lbs.)Front 199 -14.75 -2935.25Left 295 42.25 12463.75Right 301 42.25 12717.75Total 795 22245.75C.G. 27.9820755 Baggage Capacity 50lbs. max Empty Aircraft: Unuseable Fuel and Operating fluids Weight Moment (in.lbs.)Empty Weight 795 22245.75Center of Gravity 27.9820755 Forward C.G. (with 205lb. pilot and 6 gallons of useable fuel)Weight (lbs.) Arm (in.) Moment (in.lbs.)Empty Weight 795 27.9820755 22245.75Pilot & Passenger 205 44.1 9040.5Fuel 36 37.4 1346.4Baggage 0 69.76 0Total 1036 32632.65C.G. 31.4986969 Aft C.G. at Gross WeightWeight (lbs.) Arm (in.) Moment (in.lbs.)Empty Weight 795 27.9820755 22245.75Pilot & Passenger 448 44.1 19756.80Fuel 132 37.4 4936.8Baggage 50 69.76 3488Total 1425 50427.35C.G. 35.387614 |
| Helping your favorite cause is as easy as instant messaging. You IM, mail_join' target='_new'>Learn more. [quote][b]
| - The Matronics Lightning-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
Wayne(at)lpwa.net Guest
Posted: Thu Feb 07, 2008 12:51 am Post subject: Lightning Weight and Balance |
Hi Tom & Al
Would it be possible for you to email me a higher quality photo of your aircraft in flight (Arion Intro Page) and taxying. I have just ordered my kit and I’d like to print larger copies to pin up on my office wall to keep me going!
Regards & thanks
Wayne Patterson
Perth Australia
wayne(at)lpwa.net
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of Brian Whittingham
Sent: Wednesday, February 06, 2008 5:08 PM
To: lightning-list(at)matronics.com
Subject: Lightning Weight and Balance
Quote: |
Quote: | In the past there have been requests for weight and balance data for the Lightning. Keep in mind that this is anexperimental and therefore your aircraft will depend on what you put into it. I typed up a weight and balance from thedemonstrator. I know that this will get out of order when I put it in an email, but if you want the info it shouldn't be too hard tofigure out how to get it spaced back out right. It should give you an idea of how much you can carry and where you can carry itBrian W.Aircraft Type: Arion LightningN Number: N323ALSerial Number: #0029Reference Datum: FirewallLevel Point: Across cockpit top rail longitudinally, and across cockpit Forward Limit: 26.5”experimental and therefore your aircraft will depend on what you put into it. I typed up a weight and balance from the | 0 Quote: | experimental and therefore your aircraft will depend on what you put into it. I typed up a weight and balance from the | 1 Quote: | experimental and therefore your aircraft will depend on what you put into it. I typed up a weight and balance from the | 2 Quote: | experimental and therefore your aircraft will depend on what you put into it. I typed up a weight and balance from the | 3 Quote: | experimental and therefore your aircraft will depend on what you put into it. I typed up a weight and balance from the | 4 Quote: | experimental and therefore your aircraft will depend on what you put into it. I typed up a weight and balance from the | 5 Quote: | experimental and therefore your aircraft will depend on what you put into it. I typed up a weight and balance from the | 6 Quote: | experimental and therefore your aircraft will depend on what you put into it. I typed up a weight and balance from the | 7 Quote: | experimental and therefore your aircraft will depend on what you put into it. I typed up a weight and balance from the | 8 Quote: | experimental and therefore your aircraft will depend on what you put into it. I typed up a weight and balance from the | 9 Quote: | demonstrator. I know that this will get out of order when I put it in an email, but if you want the info it shouldn't be too hard to | 0 Quote: | demonstrator. I know that this will get out of order when I put it in an email, but if you want the info it shouldn't be too hard to | 1 Quote: | demonstrator. I know that this will get out of order when I put it in an email, but if you want the info it shouldn't be too hard to | 2 Quote: | demonstrator. I know that this will get out of order when I put it in an email, but if you want the info it shouldn't be too hard to | 3 Quote: | demonstrator. I know that this will get out of order when I put it in an email, but if you want the info it shouldn't be too hard to | 4 Quote: | demonstrator. I know that this will get out of order when I put it in an email, but if you want the info it shouldn't be too hard to | 5 Quote: | demonstrator. I know that this will get out of order when I put it in an email, but if you want the info it shouldn't be too hard to | 6 Quote: | demonstrator. I know that this will get out of order when I put it in an email, but if you want the info it shouldn't be too hard to | 7 Quote: | demonstrator. I know that this will get out of order when I put it in an email, but if you want the info it shouldn't be too hard to | 8 Quote: | Weight (lbs.) Arm (in.) Moment (in.lbs.)demonstrator. I know that this will get out of order when I put it in an email, but if you want the info it shouldn't be too hard to | 9 Quote: | figure out how to get it spaced back out right. It should give you an idea of how much you can carry and where you can carry it | 0 Quote: | figure out how to get it spaced back out right. It should give you an idea of how much you can carry and where you can carry it | 1 Quote: | figure out how to get it spaced back out right. It should give you an idea of how much you can carry and where you can carry it | 2 Quote: | figure out how to get it spaced back out right. It should give you an idea of how much you can carry and where you can carry it | 3 Quote: | figure out how to get it spaced back out right. It should give you an idea of how much you can carry and where you can carry it | 4 Quote: | figure out how to get it spaced back out right. It should give you an idea of how much you can carry and where you can carry it | 5 Quote: | figure out how to get it spaced back out right. It should give you an idea of how much you can carry and where you can carry it | 6 Quote: | Weight (lbs.) Arm (in.) Moment (in.lbs.)figure out how to get it spaced back out right. It should give you an idea of how much you can carry and where you can carry it | 7 Quote: | figure out how to get it spaced back out right. It should give you an idea of how much you can carry and where you can carry it | 8 Quote: | figure out how to get it spaced back out right. It should give you an idea of how much you can carry and where you can carry it | 9012 |
Helping your favorite cause is as easy as instant messaging. You IM, mail_join' target='_new'>Learn more. 3456789 Quote: | Aircraft Type: Arion Lightning | 0 Quote: | Aircraft Type: Arion Lightning | 1 Quote: | Aircraft Type: Arion Lightning | 2 Quote: | Aircraft Type: Arion Lightning | 3 Quote: | Aircraft Type: Arion Lightning | 4 Quote: | Aircraft Type: Arion Lightning | 5 Quote: | Aircraft Type: Arion Lightning | 6 Quote: | Aircraft Type: Arion Lightning | 7 Quote: | Aircraft Type: Arion Lightning | 8 Quote: | Aircraft Type: Arion Lightning | 9012
Posted: Thu Feb 07, 2008 1:04 am Post subject: Lightning Weight and Balance |
Wayne,
I've got a couple, let me find them and I'll send you an email to your personal addy. I might be the only one up in the U.S. on the board at this hour. 3a.m. here. What is your conversion to zulu there? Brian W.
Quote: | Subject: RE: Lightning Weight and Balance
Date: Thu, 7 Feb 2008 17:55:54 +0900
.ExternalClass .EC_shape {;} .ExternalClass EC_p.MsoNormal, .ExternalClass EC_li.MsoNormal, .ExternalClass EC_div.MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass a:link, .ExternalClass EC_span.MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass EC_span.MsoHyperlinkFollowed {color:blue;text-decoration:underline;} .ExternalClass p {margin-right:0mm;margin-left:0mm;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass pre {margin-bottom:.0001pt;font-size:10.0pt;font-family:'Courier New';} .ExternalClass EC_span.EmailStyle19 {font-family:Arial;color:navy;} (at)page Section1 {size:595.3pt 841.9pt;} .ExternalClass EC_div.Section1 {page:Section1;}
Hi Tom & Al
Regards & thanks
Wayne Patterson
Perth Australia
wayne(at)lpwa.net
Subject: Lightning-List: Lightning Weight and Balance
Quote: |
Quote: | In the past there have been requests for weight and balance data for the Lightning. Keep in mind that this is anexperimental and therefore your aircraft will depend on what you put into it. I typed up a weight and balance from thedemonstrator. I know that this will get out of order when I put it in an email, but if you want the info it shouldn't be too hard tofigure out how to get it spaced back out right. It should give you an idea of how much you can carry and where you can carry itBrian W.Aircraft Type: Arion LightningN Number: N323ALSerial Number: #0029Reference Datum: FirewallLevel Point: Across cockpit top rail longitudinally, and across cockpit experimental and therefore your aircraft will depend on what you put into it. I typed up a weight and balance from the | 0 Quote: | experimental and therefore your aircraft will depend on what you put into it. I typed up a weight and balance from the | 1 Quote: | experimental and therefore your aircraft will depend on what you put into it. I typed up a weight and balance from the | 2 Quote: | experimental and therefore your aircraft will depend on what you put into it. I typed up a weight and balance from the | 3 Quote: | experimental and therefore your aircraft will depend on what you put into it. I typed up a weight and balance from the | 4 Quote: | experimental and therefore your aircraft will depend on what you put into it. I typed up a weight and balance from the | 5 Quote: | experimental and therefore your aircraft will depend on what you put into it. I typed up a weight and balance from the | 6 Quote: | experimental and therefore your aircraft will depend on what you put into it. I typed up a weight and balance from the | 7 Quote: | experimental and therefore your aircraft will depend on what you put into it. I typed up a weight and balance from the | 8 Quote: | experimental and therefore your aircraft will depend on what you put into it. I typed up a weight and balance from the | 9 Quote: | demonstrator. I know that this will get out of order when I put it in an email, but if you want the info it shouldn't be too hard to | 0 Quote: | demonstrator. I know that this will get out of order when I put it in an email, but if you want the info it shouldn't be too hard to | 1 Quote: | demonstrator. I know that this will get out of order when I put it in an email, but if you want the info it shouldn't be too hard to | 2 Quote: | demonstrator. I know that this will get out of order when I put it in an email, but if you want the info it shouldn't be too hard to | 3 Quote: | demonstrator. I know that this will get out of order when I put it in an email, but if you want the info it shouldn't be too hard to | 4 Quote: | demonstrator. I know that this will get out of order when I put it in an email, but if you want the info it shouldn't be too hard to | 5 Quote: | demonstrator. I know that this will get out of order when I put it in an email, but if you want the info it shouldn't be too hard to | 6 Quote: | demonstrator. I know that this will get out of order when I put it in an email, but if you want the info it shouldn't be too hard to | 7 Quote: | demonstrator. I know that this will get out of order when I put it in an email, but if you want the info it shouldn't be too hard to | 8 Quote: | demonstrator. I know that this will get out of order when I put it in an email, but if you want the info it shouldn't be too hard to | 9 Quote: | figure out how to get it spaced back out right. It should give you an idea of how much you can carry and where you can carry it | 0 Quote: | figure out how to get it spaced back out right. It should give you an idea of how much you can carry and where you can carry it | 1 Quote: | figure out how to get it spaced back out right. It should give you an idea of how much you can carry and where you can carry it | 2 Quote: | figure out how to get it spaced back out right. It should give you an idea of how much you can carry and where you can carry it | 3 Quote: | figure out how to get it spaced back out right. It should give you an idea of how much you can carry and where you can carry it | 4 Quote: | figure out how to get it spaced back out right. It should give you an idea of how much you can carry and where you can carry it | 5 Quote: | figure out how to get it spaced back out right. It should give you an idea of how much you can carry and where you can carry it | 6 Quote: | figure out how to get it spaced back out right. It should give you an idea of how much you can carry and where you can carry it | 7 Quote: | figure out how to get it spaced back out right. It should give you an idea of how much you can carry and where you can carry it | 8 Quote: | figure out how to get it spaced back out right. It should give you an idea of how much you can carry and where you can carry it | 9012345 |
Helping your favorite cause is as easy as instant messaging. You IM, mail_join' target='_new'>Learn more. 6789 Quote: | Aircraft Type: Arion Lightning | 0 Quote: | Aircraft Type: Arion Lightning | 1 Quote: | Aircraft Type: Arion Lightning | 2 Quote: | Aircraft Type: Arion Lightning | 3 Quote: | Aircraft Type: Arion Lightning | 4 Quote: | Aircraft Type: Arion Lightning | 5 Quote: | Aircraft Type: Arion Lightning | 6
Quote: | Aircraft Type: Arion Lightning | 7 | Connect and share in new ways with Windows Live. Get it now! [quote][b]
Posted: Thu Feb 07, 2008 3:45 am Post subject: Lightning Weight and Balance |
Perth is 8 hours ahead of GMT. Getting our heads around USA time is harder – the shortest distance and timeframe crosses the date line. It is 8.40pm Thursday here at the moment.
I look forward to receiving the photos!
Regards & thanks
Wayne
Sent: Thursday, February 07, 2008 5:59 PM
Subject: RE: Lightning-List: Lightning Weight and Balance
Wayne,
Hi Tom & Al
Regards & thanks
Wayne Patterson
Perth Australia
wayne(at)lpwa.net
Connect and share in new ways with Windows Live. Get it now! Quote: | Aircraft Type: Arion Lightning | 3 Quote: | Aircraft Type: Arion Lightning | 4 Quote: | Aircraft Type: Arion Lightning | 5 Quote: | Aircraft Type: Arion Lightning | 6 Quote: | Aircraft Type: Arion Lightning | 7 Quote: | Aircraft Type: Arion Lightning | 8 Quote: | Aircraft Type: Arion Lightning | 90123456789 Quote: | Serial Number: #0029 | 0 Quote: | Serial Number: #0029 | 1 Quote: | Serial Number: #0029 | 2
Posted: Thu Feb 07, 2008 4:38 am Post subject: Lightning Weight and Balance |
Wayne,
Tried sending the photos, but got kicked back. Let me try sending one at a time. Maybe the first email was just too big. Each photo is about 3mb.
Date: Thu, 7 Feb 2008 20:48:34 +0900
.ExternalClass .EC_shape {;} .ExternalClass EC_p.MsoNormal, .ExternalClass EC_li.MsoNormal, .ExternalClass EC_div.MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass a:link, .ExternalClass EC_span.MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass EC_span.MsoHyperlinkFollowed {color:blue;text-decoration:underline;} .ExternalClass EC_span.EmailStyle19 {font-family:Arial;color:navy;} .ExternalClass EC_div.Section1 {page:Section1;} .ExternalClass EC_p.MsoNormal, .ExternalClass EC_li.MsoNormal, .ExternalClass EC_div.MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass a:link, .ExternalClass EC_span.MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass EC_span.MsoHyperlinkFollowed {color:blue;text-decoration:underline;} .ExternalClass p {margin-right:0mm;margin-left:0mm;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass pre {margin-bottom:.0001pt;font-size:10.0pt;font-family:'Courier New';} .ExternalClass EC_span.EmailStyle19 {font-family:Arial;color:navy;} (at)page Section1 {size:595.3pt 841.9pt;} .ExternalClass EC_div.Section1 {page:Section1;}
Regards & thanks
Wayne
Wayne,
Hi Tom & Al
Regards & thanks
Wayne Patterson
Perth Australia
wayne(at)lpwa.net
Connect and share in new ways with Windows Live. Get it now! Quote: | Aircraft Type: Arion Lightning | 6 Quote: | Aircraft Type: Arion Lightning | 7 Quote: | Aircraft Type: Arion Lightning | 8 Quote: | Aircraft Type: Arion Lightning | 90123456
7 | Helping your favorite cause is as easy as instant messaging. You IM, we give. Learn more. [quote][b]
Posted: Thu Feb 07, 2008 11:40 pm Post subject: Lightning Weight and Balance |
Wayne,
Should be around 1530 lcl there if I did that right. Just wanted to check and see if you got your 3 photos that I sent via email. Nothing
bounced back so I assume it worked, or I overloaded your email account and you can't log back in. Brian W.
Regards & thanks
Wayne
Wayne,
Hi Tom & Al
Regards & thanks
Wayne Patterson
Perth Australia
wayne(at)lpwa.net
7 | Climb to the top of the charts! Play the word scramble challenge with star power. Play now! [quote][b]
Posted: Fri Feb 08, 2008 5:45 pm Post subject: Lightning Weight and Balance |
Photos cam through fine thanks Brian. I can start wall-papering my office wall now!
In regards the newsletter – I’m hanging out for photos/videos of finished Lightnings being used – for local fun or for cross-country touring. Perhaps some in-flight video shot from the cockpit while over something worth seeing. My build will probably take 12 months after the kit arrives in Australia – so such photos/videos of completed aircraft doing their thing would really help me through the build!
Wayne
Sent: Friday, February 08, 2008 4:38 PM
Wayne,
Regards & thanks
Wayne
Wayne,
Hi Tom & Al
Regards & thanks
Wayne Patterson
Perth Australia
wayne(at)lpwa.net
Climb to the top of the charts! Play the word scramble challenge with star power. Play now! 3456789 Quote: | Serial Number: #0029 | 0 Quote: | Serial Number: #0029 | 1 Quote: | Serial Number: #0029 | 2 Quote: | Serial Number: #0029 | 3 Quote: | Serial Number: #0029 | 4 Quote: | Serial Number: #0029 | 5 Quote: | Serial Number: #0029 | 6 Quote: | Serial Number: #0029 | 7 Quote: | Serial Number: #0029 | 8 Quote: | Serial Number: #0029 | 9 Quote: | Reference Datum: Firewall | 0 Quote: | Reference Datum: Firewall | 1 Quote: | Reference Datum: Firewall | 2
flying(at)qdea.com Guest
Posted: Fri Feb 08, 2008 9:17 pm Post subject: Lightning Weight and Balance |
Can anyone tell me what the datum of the engine CG is, and the datum
of the bulkhead at the rear of the baggage compartment?
I'd like to move the engine forward enough to compensate for the BRS,
without compromising the 50-lb. baggage rating.
I believe that the reason that baggage is limited to 10 lbs with the
BRS is due to an aft CG condition that could be remedied by moving
the engine forward just a bit.
At the same time, it would be really nice to put the BRS behind the
baggage compartment.
Hugh Sontag
Posted: Fri Feb 08, 2008 11:15 pm Post subject: Lightning Weight and Balance |
Wayne,
I feel your pain. I only got to fly other people's planes and never owned one of my own. When my life is less hectic, then I plan to do a Lightning video. I never got a chance to make the live action video that I had planned, but instead, I think now I will make a video more of a photo slide show. I've got plenty of photos, and I've got the music that I wanted to put on the other video, now I just need the time. Brian W.
Date: Sat, 9 Feb 2008 10:04:41 +0900
.ExternalClass .EC_shape {;} .ExternalClass EC_p.MsoNormal, .ExternalClass EC_li.MsoNormal, .ExternalClass EC_div.MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass a:link, .ExternalClass EC_span.MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass EC_span.MsoHyperlinkFollowed {color:blue;text-decoration:underline;} .ExternalClass EC_span.EmailStyle19 {font-family:Arial;color:navy;} .ExternalClass EC_div.Section1 {page:Section1;} .ExternalClass EC_p.MsoNormal, .ExternalClass EC_li.MsoNormal, .ExternalClass EC_div.MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass a:link, .ExternalClass EC_span.MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass EC_span.MsoHyperlinkFollowed {color:blue;text-decoration:underline;} .ExternalClass EC_span.EmailStyle19 {font-family:Arial;color:navy;} .ExternalClass EC_div.Section1 {page:Section1;} .ExternalClass EC_p.MsoNormal, .ExternalClass EC_li.MsoNormal, .ExternalClass EC_div.MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass a:link, .ExternalClass EC_span.MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass EC_span.MsoHyperlinkFollowed {color:blue;text-decoration:underline;} .ExternalClass p {margin-right:0mm;margin-left:0mm;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass pre {margin-bottom:.0001pt;font-size:10.0pt;font-family:'Courier New';} .ExternalClass EC_span.EmailStyle19 {font-family:Arial;color:navy;} (at)page Section1 {size:595.3pt 841.9pt;} .ExternalClass EC_div.Section1 {page:Section1;}
Wayne
Wayne,
Regards & thanks
Wayne
Wayne,
Hi Tom & Al
Regards & thanks
Wayne Patterson
Perth Australia
wayne(at)lpwa.net
012345
Climb to the top of the charts! Play the word scramble challenge with star power. Play now! 6789 Quote: | Serial Number: #0029 | 0 Quote: | Serial Number: #0029 | 1 Quote: | Serial Number: #0029 | 2 Quote: | Serial Number: #0029 | 3 Quote: | Serial Number: #0029 | 4 Quote: | Serial Number: #0029 | 5 Quote: | Serial Number: #0029 | 6
Quote: | Serial Number: #0029 | 7 | Shed those extra pounds with MSN and The Biggest Loser! Learn more. [quote][b]
