BMWBikeCrz(at)aol.com Guest
Posted: Fri Feb 08, 2008 6:23 am Post subject: E-Box on firestar |
Any one Running An E-Box on a firestar
How far would the Engine have to be moved forward to make up for the added 15 pounds ?
Are "Ultra Props" any good ?
Dave pilot of the "sofa king"
Biggest Grammy Award surprises of all time on AOL Music.
(http://music.aol.com/grammys/pictures/never-won-a-grammy?NCID=aolcmp00300000002548) [quote][b]
jindoguy(at)gmail.com Guest
Posted: Fri Feb 08, 2008 8:55 am Post subject: E-Box on firestar |
Dave, Compare an Ultraprop to any other prop you've ever seen. That should answer your question.
Rick
On Feb 8, 2008 8:16 AM, <BMWBikeCrz(at)aol.com (BMWBikeCrz(at)aol.com)> wrote:
[quote]Any one Running An E-Box on a firestar
(http://music.aol.com/grammys/pictures/never-won-a-grammy?NCID=aolcmp00300000002548) [b]
Posted: Fri Feb 08, 2008 9:48 am Post subject: E-Box on firestar |
Rick:
Isn't an Ultraprop a plastic straight blade prop? No twist in the blade? Gets to a certain point in airspeed and hits a brick wall? No more speed?
My comparison is the Ultraprop is a "dog" compared to other props.
Sorry, can not remember the correct terminology for built in blade twist. Somebody help me out.
[quote]Dave, Compare an Ultraprop to any other prop you've ever seen. That should answer your question.
Rick
_________________ John Hauck
Titus, Alabama |
rowedenny(at)windstream.n Guest
Posted: Fri Feb 08, 2008 11:27 am Post subject: E-Box on firestar |
other props.
John,
The word is Helex, I think. Without the helex or twist built in, the prop has a narrower sweet spot where it performs well.
Denny
Posted: Fri Feb 08, 2008 2:24 pm Post subject: E-Box on firestar |
Yep, that would be the one.
Rick
On Feb 8, 2008 11:19 AM, John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
[quote] Rick:
| Quote: | Dave, Compare an Ultraprop to any other prop you've ever seen. That should answer your question.
Rick
WillUribe(at)aol.com Guest
Posted: Fri Feb 08, 2008 10:47 pm Post subject: E-Box on firestar |
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of BMWBikeCrz(at)aol.com
Sent: Friday, February 08, 2008 7:17 AM
Subject: Kolb-List: E-Box on firestar
Who's never won? Biggest Grammy Award surprises of all time on AOL Music.
55.15 KB |
300 Time(s) |
55.43 KB |
306 Time(s) |
50.2 KB |
317 Time(s) |
59.24 KB |
330 Time(s) |
