jeynon2
Joined: 25 Oct 2007 Posts: 24 Location: Southern Illinois
Posted: Sat Feb 02, 2008 4:09 pm Post subject: Gear legs |
Is there some trick to inserting the gear legs into the spar box. I've sanded the paint out of the tube, and loosened the nuts holding the spar box to the fuselage. I've also done some sanding on the gear leg. I can get it about halfway in with some difficulty, and back out with more difficulty. I assume the answer is keep sanding the gear leg until it goes in, but I thought I'd check here first.
Thanks.
John Eynon
Lightning #53
Carbondale, Illinois
| - The Matronics Lightning-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
sttwig(at)wabroadband.com Guest
Posted: Sat Feb 02, 2008 10:52 pm Post subject: Gear legs |
John,
I feel your pain. I spent a lot of time doing just as you have done. I
found that the slightest bump that you can hardly feel in the spar box
socket will bind up the legs. If you use some fine sand paper on the legs
to smooth them up and then insert them, the bumps will leave a mark on the
gear leg when you try to insert them again and then pull them out. Then you
can locate the bump and go after it. Also you need to keep sanding the gear
legs down. When you get close you can put some lubricant on the leg and it
will slide in fairly easily. Mark at Arion told me they use a moly lube on
them. You have to be able to turn the legs in the spar box socket when you
do your wheel alignment. I'm no expert. What I outlined here is what
worked for me.
Steve
Kit #48
landonp(at)bigpond.com Guest
Posted: Sun Feb 03, 2008 12:33 am Post subject: Gear legs |
Hi John
I used a Drill extention(14" one) with a scotchbrite pad wrapped opposite to
turn direction (sufficient pad to be slightly larger then gear leg tube) and
attached to female end (tied it on with lockwire ),Around this I attached a
strip of Wet and Dry 80 grit(carb)Paper.You twist this into tube (dip in
water) and use your elec drill to turn. Areas that you find as a tight spot
when you put leg in is where you concentrate effort to.This worked well for
me.
Cheers
BK
jeynon2
Posted: Sun Feb 03, 2008 2:17 pm Post subject: Re: Gear legs |
Thanks for the responses. It's reassuring to know I'm not the only one spending hours sanding his shaft.
John Eynon
Lightning #53
vettin74(at)yahoo.com Guest
Posted: Sun Feb 03, 2008 5:48 pm Post subject: Gear legs |
John,
Normally we do not have this much trouble with the legs...make sure the the hole in the bottom of the fuselage is at the correct angle to allow 1/8" gap around the leg ...they will bind and go in crooked if they touch just a bit...otherwise sanding is ok but take your time and do not go to the grinder...
nick
jeynon <jeynon2(at)verizon.net> wrote:
[quote]--> Lightning-List message posted by: "jeynon"
Is there some trick to inserting the gear legs into the spar box. I've sanded the paint out of the tube, and loosened the nuts holding the spar box to the fuselage. I've also done some sanding on the gear leg. I can get it about halfway in with some difficulty, and back out with more difficulty. I assume the answer is keep sanding the gear leg until it [quote][b]
Posted: Sun Feb 03, 2008 10:23 pm Post subject: Gear legs |
I spent a lot of time sanding both the spar box tubes and the gear legs to get them to fit and that was before the spar box was fit in the fuselage. They are a tight fit. I think that all the welding around the bottom end of the tube in the spar box distorts it a bit. If I was going to do it again, I would take the legs to a machine shop and have them put them into a lathe and remove enough to make them fit. The bottom ends are the same situation. If they are to “bottom out” in the wheel and brake weldment, a significant amount needs to be removed there, too.
Steve
Kit # 48
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of nick otterback
Sent: Sunday, February 03, 2008 5:46 PM
To: lightning-list(at)matronics.com
Subject: Re: Gear legs
John,
nick
Is there some trick to inserting the gear legs into the spar box. I've sanded the paint out of the tube, and loosened the nuts holding the spar box to the fuselage. I've also done some sanding on the gear leg. I can get it about halfway in with some difficulty, and back out with more difficulty. I assume the answer is keep sanding the gear leg until it Quote: | http://www.matronics.com/Navigator?Lightning-List | 0123456789[b]
Posted: Mon Feb 04, 2008 6:17 am Post subject: Gear legs |
Steve,
I will call teh weld shop this morning...this is not the intended fit of these parts, and has not been for the first 40 kits or so...
Nick
Steven Sundquist <sttwig(at)wabroadband.com> wrote:
[quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} I spent a lot of time sanding both the spar box tubes and the gear legs to get them to fit and that was before the spar box was fit in the fuselage. They are a tight fit. I think that all the welding around the bottom end of the tube in the spar box distorts it a bit. If I was going to do it again, I would take the legs to a machine shop and have them put them into a lathe and remove enough to make them fit. The bottom ends are the same situation. If they are to “bottom out” in the wheel and brake weldment, a significant amount needs to be removed there, too.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Steve
Kit # 48
John,
nick
[quote] --> Lightning-List message posted by: "jeynon"
Quote: | http://www.matronics.com/Navigator?Lightning-List | 012345678[quote][b]Be a better friend, newshound, and [quote][b]
Colin K.
Posted: Mon Feb 04, 2008 5:29 pm Post subject: Gear legs |
I have not fitted my spar box, engine mount or gear legs Nick, so I was able
to try fitting the gear legs to the appropriate holes today, with no impact
of them being attached to the fuselage.
First the bottom weldments: all three went on to within an inch of bottoming
with little effort, so I am guessing that when I clean off the paint, they
will go fully home.
The main gear legs go into the spar box about 2 inches with some effort
_________________ Colin K.
OK |
Posted: Tue Feb 05, 2008 6:21 am Post subject: Gear legs |
Colin,
I have discussed the matter with the weld shop and they will turn down future gearlegs some. For yours you will have to sand them as everyone else has. The weld shop has a gear leg to check these items but he believes that a combination of a new QC guy and a gear leg which was with in tolarance but slightly undersize to blame for a run of these legs.
Nick
"Colin J. Kennedy" <cjk129(at)cox.net> wrote:
[quote] I have not fitted my spar box, engine mount or gear legs Nick, so I was able to try fitting the gear legs to the appropriate holes today, with no impact of them being attached to the fuselage.
First the bottom weldments: all three went on to within an inch of bottoming with little effort, so I am guessing that when I clean off the paint, they will go fully home.
The main gear legs go into the spar box about 2 inches with some effort . The outside diameter of the top of the main gear legs is 1 3/8". As the tubes are cut off at an angle, I need to get something deeper inside to measure the inside diameter and I don't have a good tool for that. I think something more than removing the paint will have to be done, but this is the next thing I will try.
The nose gear leg will not go into the engine mount at all. The outside diameter of the top of the nose gear leg is 1 3/8". The inside diameter of the tube measures at 1 3/8" too, so no clearance. I think something more than removing the paint will have to be done, but again, this is the next thing I will try.
I am a working at a slower rate as compared to some of the other builders, so I will not take any drastic measures until you come to a conclusion.
By the way, great engine seminar this weekend! I'm sorry if I was one of the people keeping you from taking calls! I'm sure we can all work together to resolve these challenges!
Colin K.
OK
http://www.mykitlog.com/cojaken
Colin K.
Posted: Tue Feb 05, 2008 5:25 pm Post subject: Gear legs |
Thanks Nick.
I will give it a try.
Colin K.
OK
OK |
