tdawson-townsend(at)auror Guest
Posted: Tue Feb 05, 2008 6:17 am Post subject: Slick Start |
There used to be two models of SlickStart, one for Slick magnetos and one for Bendix magnetos. Part of the model change last fall was that Slick dropped the second model, so for the future, you can only buy SlickStart for use with Slick magnetos.
Are all Slick mags impulse coupled (not retard)? Perhaps the missing P2 connection is no longer needed if only supporting Slick impulse-coupled mags.
I have Bendix retard mags, and so I either needed the discountinued SlickStart model or an old-school mechanical “vibrator”. Luckily, I managed to find what I think was the last SS1002 SlickStart module in Germany and snagged it.
TDT
Tim Dawson-Townsend
40025
tdt(at)aurora.aero (tdt(at)aurora.aero)
617-500-4812 (office)
617-905-4800 (mobile)
ron.mcgann(at)baesystems. Guest
Posted: Tue Feb 05, 2008 1:37 pm Post subject: Slick Start |
Hey Tim,
I ordered my IO-540 D4A5 (Exp) Lyco from Vans and it was supplied with a retard breaker on the left mag - same as a few others. My guess is that unless otherwise specified, the retard breaker is 'standard' on Slick Mags on Vans supplied engines.
Does anyone know of literature that discusses the pros & cons of retard vs impulse mags?
A side note - I posted a question a few weeks back about the need for a switch to select which mag to source the GRT EIS Tacho input. The Slick Start instruction manual says to not have the electronic tachometer on the same magneto as the slick start. To prevent the EIS being accidently sourced by the left mag during start, I decided to source the tacho from the right mag only and use the mark-one eardrum technique to confirm correct rev drop during mag checks on run-up.
cheers,
Ron
-187
[quote] From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dawson-Townsend,Timothy
Sent: Wednesday, 6 February 2008 12:43 AM
Subject: Slick Start
TDT
Tim Dawson-Townsend
40025
"Warning:
The information contained in this email and any attached files is
confidential to BAE Systems Australia. If you are not the intended
recipient, any use, disclosure or copying of this email or any
attachments is expressly prohibited. If you have received this email
in error, please notify us immediately. VIRUS: Every care has been
taken to ensure this email and its attachments are virus free,
however, any loss or damage incurred in using this email is not the
sender's responsibility. It is your responsibility to ensure virus
checks are completed before installing any data sent in this email to
your computer."
apilot2(at)gmail.com Guest
Posted: Tue Feb 05, 2008 4:49 pm Post subject: Slick Start |
Slick makes both retard breaker and impulse coupled mags, as well as
straight mags with no starting mechanism(for #2 mag).
I still don't figure why they stopped making the Bendix version, as
manufacturing cost has to be low, there are thousands of Bendix retard
breaker mags in use (aka famous Shower of Sparks system), and most
A&Ps won't switch to Slicks unless customer demands it, or are forced
into them with a reman engine.
On Feb 5, 2008 7:13 AM, Dawson-Townsend,Timothy
<tdawson-townsend(at)aurora.aero> wrote:
mags.
SlickStart model or an old-school mechanical "vibrator". Luckily, I managed
snagged it.
TDT
Tim Dawson-Townsend
40025
tdt(at)aurora.aero
Posted: Tue Feb 05, 2008 4:52 pm Post subject: Slick Start |
Retard breaker mags are very reliable with a proper starting vibrator,
and many Lyc engines were equipped that way as installed by Piper and
Mooney. You would have to research how the Comanche 260 was equipped,
as that is what the Vans spec engine was built for.
On Feb 5, 2008 2:31 PM, McGANN, Ron <ron.mcgann(at)baesystems.com> wrote:
Hey Tim,
impulse mags?
cheers,
Ron
-187
mags.
snagged it.
TDT
Tim Dawson-Townsend
40025
tdt(at)aurora.aero
p://www.matronics.com/Navigator?RV10-List
ics.com
.matronics.com/contribution
"Warning:
your computer."
