DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Thu Jan 31, 2008 11:50 am Post subject: Throttle Cable Friction |
I am installing the Jabiru dual throttle system in my 601XL and am trying to work some of the friction out of the system. Most of the friction is in the solid wire Aircraft Spruce throttles as there are a few bends in the system. Is there any lubricant that someone can recommend for this push-pull cable application?
_________________ David Gallagher
Cincinnati, OH area |
victorbravo(at)sbcglobal. Guest
Posted: Thu Jan 31, 2008 1:18 pm Post subject: Throttle Cable Friction |
Sorry for the dictatorial rant, but please read this: As I posted
recently, we lost a 601XL recently from our EAA chapter on the first
flight. It was sheer luck that the guy walked away. There is a high
probability that the throttle linkage bent, or "over-centered" or had a
friction problem or did not overcome the spring on the engine, or
something of some sort... which caused the engine room to not answer the
phone when the pilot needed it most.
A quick answer to your throttle friction problem is the use of a flex
cable instead of a solid wire. This will usually resolve a lot of
friction issues. BUT you have to be triple-careful, because a flex cable
will not stay as rigid in compression (pushing) as a wire.
The problem is that too little stiffness in the pushrod causes one
problem, and too much stiffness causes another. The flex cable is
fantastic in push and pull when it is inside the outer sheath, but gets
weak in pushing after it leaves the sheath. Add to this the fact you
MUST have some "cushion" in the system, meaning that the pushrod system
has to have at least 10% more free movement than is required by full
movement of the (carburetor / air control / fuel injection servo /
engine control arm) that the pushrod is moving.
The bottom line is that you have to play around with your engine
controls a LOT, make absolutely sure there is no binding or
over-centering or weakness against a spring, etc., make DAMN sure you
have that 10% or better cushion, and then you have to TEST it out
operationally before it flies. Again, sorry for the oppressive tone
here, but I'm probably saving someone's life.
Have someone sit in the cockpit and operate the throttle while you move
and bend and pull on every part of it from the instrument panel to the
engine. You are TRYING to create a failure, or sticking, or binding, or
over-centering. Hold the throttle arm on the engine and try to RESIST
the movement of the lever in the cockpit. Pull the pushrod in all
directions to see if you can make it stick. Hold the engine control
against and with the throttle movement. Twist and kink the pushrod
anywhere it can be moved and see what that does. You will probably find
that you want to tie the pushrod in more places inside the engine
compartment, and you will probably see that one or more rigid supported
"stand-off" parts are very well advised.
This test of having someone in the cockpit moving the controls and you
trying to prevent the controls from working is also necessary on every
other type of control, like the elevator, ailerons, rudder, steering,
flaps, canopy/doors, etc. This is life and death stuff here, folks, pay
attention.
Also, FORGET about using those wonderful little plastic wire ties to
hold everything on the engine. They can melt, they can crack and they
can get a little loose over time. Any flight critical tiedown inside the
engine compartment should be done with an Adel clamp (aircraft loop
clamp) or good old safety wire. Non-critical wiring and SOME of the
spark plug leads, engine instrument wires and such... sure, the plastic
ties are fine.
The Devil is in the details, as they say. These are the details in which
the Devil hides in an airplane.
DaveG601XL wrote:
David Gallagher
601 XL, tail & wings completed and
fueslage pretty well done. Working engine and electrical systems.
http://forums.matronics.com/viewtopic.php?p=161639#161639
DaveG601XL
Posted: Fri Feb 01, 2008 3:59 am Post subject: Re: Throttle Cable Friction |
VictorBravo,
You cautions are duly noted. Especially those about tie wraps. I have a fair amount of firewall wiring in the vicinity of the throttle torque tube levers. You are right in that these need to be secured by more than mere plastic straps.
goodings(at)yorku.ca Guest
Posted: Fri Feb 01, 2008 8:53 am Post subject: Throttle Cable Friction |
The CHOKE cable on Rotax 912s (mine is a 912S) is notoriously stiff. We
cured the problem with a product called "Rust-Check" which is sold in
Canada in Canadian Tire Stores. I presume it is available also in the
U.S. It is wonderful stuff: a very thin (red-coloured) oil that wicks its
way along the cable wire, frees it up and keeps it free. We apply it
fairly regularly to the cable ends. No more problems.
John Goodings, C-FGPJ, CH601HD with R912S, Carp/Ottawa, Toronto/Waterloo.
