thesumak(at)aol.com Guest
Posted: Thu Jan 31, 2008 2:46 pm Post subject: Rib flange repair |
Greetings:
While back drilling the bottom rear skin to the ribs on my right wing, I managed to drill a hole through the rib flange in the wrong location. I know that nobody on this list would make such a silly mistake, but imagine for a moment if you did. Would you leave it as an empty hole under the skin or fill it with a flush rivet. I suspect that the best solution is to put the extra rivet through the skin, but it falls crazy far from the normal rivet line and I’m vain.
Thanks for your help.
601xl
More new features than ever. Check out the new AOL Mail!
dredmoody(at)cox.net Guest
Posted: Thu Jan 31, 2008 3:01 pm Post subject: Rib flange repair |
Put a rivet in the errant hole and put in one or two more rivets around that site to satify the strength requirements of the area. If anyone notices one extra rivet, on the bottom of your wing, no less, you should run that guy out from under your airplane. I mean, what the hell is he doing under there in the first place?
Dred
agibeaut
Posted: Thu Jan 31, 2008 4:54 pm Post subject: Rib flange repair |
I won't openly admit to any errant holes in the underside of my wing, but I intend to be very diligent not to let a guy like Dred describes below, anywhere near it.
--- On Thu, 1/31/08, Edward Moody II <dredmoody(at)cox.net> wrote:
[quote] From: Edward Moody II <dredmoody(at)cox.net>
Subject: Re: Rib flange repair
Date: Thursday, January 31, 2008, 4:56 PM
Dred
Posted: Thu Jan 31, 2008 5:11 pm Post subject: Rib flange repair |
Bill,
If the hole is only in the rib flange below the skin, and it's nowhere
near the place it should have been, leave it be. You'll not need to
worry about
it for the sake of strength. It's a round hole after all and not
inclined to crack from there, being on the bottom. If you did the skin
too, then put
a rivet there and forget it. It won't be seen when the plane is
assembled anyway.
thesumak(at)aol.com wrote:
| Quote: | Greetings:
601xl
Posted: Thu Jan 31, 2008 6:20 pm Post subject: Rib flange repair |
Larry:
Thanks for your reply to my rib flange problem. I visited your site. Lots of interesting things. I'm a bike builder also. I have made several long wheel base recumbents and a few bikes that come apart for transport in small airplanes. Your short wheel base design looks great but I have a question: Do you have enough clearance between the front wheel and the pedals to allow you to pedal while turning? Thanks again for your help.
Posted: Fri Feb 01, 2008 9:23 am Post subject: Rib flange repair |
Hi Bill,
Yes, the clearance is more than adequate to turn without running heels
into the tire.
Larry
| Quote: | Larry:
<http://o.aolcdn.com/cdn.webmail.aol.com/mailtour/aol/en-us/text.htm?ncid=aolcmp00050000000003>!
