chris Sinfield
Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
Posted: Fri Jan 18, 2008 10:58 am Post subject: rudder position light |
simply put, you can put it where ever you want. there is no precise measurment to it. The light just needs to be in a no obtrusive location, hence anywhere. Look online at zenith's websites at the phto gallery for ideas. Suggestion on mine is just above the plane of the elevator so a plane can see it from above.
Juan
chris Sinfield
Posted: Fri Jan 18, 2008 3:01 pm Post subject: Re: rudder position light |
I didn't think there was a major issue with it but was curious as to the two different measurements from Zenith. IE Was there a cracking issue or something and that's why they changed it something ect.
Chris.
bryanmmartin
Posted: Fri Jan 18, 2008 3:12 pm Post subject: rudder position light |
You can put it anywhere you want on the trailing edge of the rudder,
it's not critical. I would suggest just behind and above the upper
rudder hinge to make it easier to route the wires to the light fixture.
On Jan 18, 2008, at 8:15 AM, chris Sinfield wrote:
Hi All
I am about to cut out the metal for my rudder position light. On the
latest plans 6-NSO-1 shows the middle of the rudder position light
to be 75 mm from the bottom of the rudder. The latest plans guide
rudder assembly page 1 shows the same position but now 160 mm from
bottom to center of the light.
Which one is it 75mm or 160mm? and why
Chris [Question]
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
rbjjr
Posted: Sat Jan 19, 2008 11:30 am Post subject: Re: rudder position light |
I recently received approval from Zenith to place the tail light lower on the rudder than called for, maybe an inch or so above the intersection of the bottom two ribs. I wanted to do this for appearances only. I just happen to think it looks better closer to the bottom. Doesn't seem to be a big deal to place it where you want.
Burke Johnson
CH701
Irvington, VA
