Thom Riddle
Posted: Mon Jan 14, 2008 2:27 pm Post subject: Re: Engine Vibration |
Hugh,
I think you are getting a run-around. Its not like Type Certificated aircraft have never had gearbox PSRUs. The Cessna 175 comes to mind. The center of rotating mass asymmetry with respect to the rotational center of the prop shaft, which what dynamic balancing is supposed to correct, has nothing to do with the fact that there is a gearbox between the prop shaft and the crankshaft, at least to my way of thinking, but I could be wrong.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Roger Lee
Posted: Mon Jan 14, 2008 2:34 pm Post subject: Re: Engine Vibration |
Hi Hugh,
I don't know why a Rotax gearbox would scare anyone away. You balance it just like any other prop. They are just uneducated. The gearbox wouldn't make any difference. The prop will balance or it won't.
You attach balance weights (washers) to the hub bolts.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Guy Buchanan
Posted: Mon Jan 14, 2008 3:22 pm Post subject: Engine Vibration |
At 02:14 PM 1/14/2008, you wrote:
| Quote: | 1. They do not balance props that have a gearbox between the engine
propeller drive.
2. There is no place on the WoodComp aluminum hub to attach balance weight.
Polite BS. I've had my Rotax 582 / Warp 3-blade dynamically balanced.
They attached weight to the spinner backing plate. You could do the
prop bolts as well.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
hgmckay
Posted: Mon Jan 14, 2008 6:41 pm Post subject: Engine Vibration |
Tom, Roger, Guy:
Thanks for your feedback! I suspected the very same thing. I am going to
continue to seek out some one to do the Dyn. Balancing. At least I'm going
to follow up with the firm that was willing to look at my plane. Thanks
again to all of you.
Hugh
Roger Lee
Posted: Tue Jan 15, 2008 7:46 am Post subject: Re: Engine Vibration |
Hi Hugh,
The Flight Design CT people are having another Fly-In May 15-18, 2008. We are going to have a prop balancing person there at the fly-in for everyone and at a reduced rate. We are in the middle of lining that up right now. We have a number of other planes fly in and spend time with us and have a lot of fun flying out to the coast and for breakfast and BBQ's. You are more than welcome to come and have a good time plus get your prop balanced.
The Fly-In is in Mcminnville, Or. Right across the street form the big air museum with the Spruce Goose. We at dinner under the Spruce Goose wing last year.
Tucson, Az.
Cell 520-349-7056 |
Mark Burton
Posted: Tue Jan 15, 2008 12:22 pm Post subject: Re: Engine Vibration |
Hi Hugh,
Speaking as someone who:
1 - manufactures dynamic prop balancing equipment
2 - owns a 912 powered aircraft (with a Woodcomp prop)
I know something about how gearboxes affect the dynamic balancing process.
The balancers I manufacture make use of the gearbox ratio to optimise the removal of engine vibration (1/2 crank) from the prop vibration signal. But it's an optimisation to get a better result, not a requirement. I don't know if other manufacturers have such a feature in their equipment.
So to say the gearbox has no effect is not quite right but, in practice, it makes little difference. You can balance a prop on a 912 as easily (or as difficult!) as on any other engine.
Anyone who balances props will tell you that there are a lot of factors that affect the quality of balance achieved. Factors such as: carb balance, ignition performance, engine mounts, airframe resonance, prop blade pitch balance, wind speed and direction, RPM used, and so on. Most of these factors will have more of an influence on the balancing process than whether the engine has a PSRU or not.
I think the people you asked are either ill informed or they really didn't want the job.
Cheers,
Mark
hgmckay
Posted: Tue Jan 15, 2008 7:05 pm Post subject: Engine Vibration |
Mark:
Thanks for your input and knowledge. From your note I assume you have
dynamically balanced your 912 and WoodComp prop together. If so, I would
like to know where and how you added mass, if mass was needed to get every
thing (engine and prop)in balance. Since the spinner and spinner flange are
fiberglass, the firm near here (H&H Propellers)
www.hhtriad.com/hhpropellers.asp that I am talking with (who hopefully will
do the job) seem to be concerned that there may be no place to add mass
except on the aluminum hub, and if that is so, where is that mass to be
added? If it is to be added at one of the six 8mm thru bolts, is it added by
using thin washers on the backside of the gearbox flange before the final
safety wiring is attached through the bolt heads?
Hugh
hgmckay
Posted: Tue Jan 15, 2008 7:14 pm Post subject: Engine Vibration |
Roger:
Thanks for the information and the invite to Oregon. I lived in Oregon
(Salem) for two years back in the 60's and loved it. However, I hope to get
my prop done closer to home at H&H Propellers
www.hhtriad.com/hhpropellers.asp and before May. North Carolina to Oregon is
a long haul in an Allegro 2000 for just a prop balance. My rear end might
not make it!! Thanks again though. I'll keep you informed as to the outcome
here in NC.
Hugh
