lamprey(at)infocom.co.ug Guest
Posted: Mon Jan 14, 2008 5:47 am Post subject: Rotax 912 electronic noise |
Can anyone shed light on an strange noise that emanates from my engine on startup? The engine is a basic 912UL, with about 520 hours on it. The noise is an electronic note, almost flutelike, around G in pitch. After startup, and idle at about 2200 RPM, you hear this noise through the firewall, loud enough for a passenger to comment. With increasing RPM, it doesn't increase much in pitch, just slightly, and therefore I think it must somehow be related to the alternator output, or possible the voltage regulator (Ducati); and not related to any noisy bearings in anything.
You cannot detect this noise if you stand close to the running engine, with the cowling off. It seems that the firewall acts as a resonating surface to amplify it to inside the cockpit.
The noise goes for about 5 minutes during warm-up, then quite suddenly it completely disappears, usually at about the time of taxying out. All through this startup, the engine runs smoothly, and temperatures and pressures behave normally. The big spike-protecting capacitor charges up, and after a minute or two from startup, the voltmeter shows a switch from 12 volt (not charging) to 14 volt (charging), All quite normal, and seemingly unrelated to the noise.
This noise didn't happen when the engine was new. It began after about 300 hours of engine time. It is particularly noticeable after sometime without engine operation, say 2 weeks or longer.
Any ideas on this mystery noise gratefully received!
Richard Lamprey
Europa Classic, 5Y-LRY
Nairobi, Kenya
m.j.gregory(at)talk21.com Guest
Posted: Mon Jan 14, 2008 9:42 am Post subject: Rotax 912 electronic noise |
Richard,
Anything related to the alternator output would vary with the RPM, but it wouldn't surprise me if the Ducati regulator was doing something mysterious. A vibration within the regulator attached to the firewall would allow the firewall to act as a sounding board as you suggest.
If it can be done safely, you might be able to see if the regulator is involved by getting someone to press their hand on it while the engine is running. If this damps the vibration (or the hand can feel the buzz) then this could confirm it. Alternatively, you might temporarily detach the regulator from the firewall (but make sure it is still properly grounded) and see if the resonance is still there. Ducati regulators are not known for their longevity, especially if they get hot in service (go on, tell us it's hot in Kenya!). Many regulators had been replaced after 300 hours or less.
I am not sure how normal is your delay of a minute or two before the voltage rises from 12 to 14. The regulator ought to provide full charging voltage immediately the alternator is up to speed, unless there is a discharged battery drawing a heavy current that drags the voltage down; even then, I would expect the voltage to rise slowly as the battery charges rather than jump suddenly, assuming you are not switching any major electrical loads at the time.
I defer to Gilles Thesee regarding the internal workings of the regulator and what might cause it to act in this way, if indeed it is the culprit.
Mike Gregory
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Richard Lamprey
Sent: 15 January 2008 00:44
Subject: Rotax 912 electronic noise
Richard Lamprey
Nairobi, Kenya
[quote] [b]
craigb(at)onthenet.com.au Guest
Posted: Tue Jan 15, 2008 2:50 am Post subject: Rotax 912 electronic noise |
If you are getting a sudden jump in voltage after a couple of minutes, I would have a look at the field coils and bridge rectifier in the alternator
I have seen simmilar in the past, where you would get a constant discharge until such time as there was enough residual field in the alternator
to kick it into charging. You could speed up the kick over to charging by running higher RPM from start (not ideal for reasons of wear) in this instance
it was a defective diode in the bridge rectifier. As for the noise, likely as you say, a noisy component in the reg being amped by the firewall, which shuts up
once its up to temp.
craig
[quote] --
Posted: Wed Jan 16, 2008 6:35 am Post subject: Rotax 912 electronic noise |
Thanks Craig and Mike for your inputs. I have limited knowledge of electrics, but my thoughts about the sudden jump from 12 V to 14 Volt are that after startup the vast 22,000 microfarad capacitor is soaking up voltage until it has reached full capacitance; only after full capacity is reached, the system achieves the full 14 Volts, and the sudden jump occurs. If the engine has been run in the last couple of days, the system reaches 14 Volts immediately, since the capacitor has not in the short time 'bled' its charge. The delay and jump only occur after the system has sat without running for a long while.
The same applies to the mysterious noise, ie doesnt occur after recent running... but I will apply my stethoscope to the regulator to see if thats the source.
Yes weather here is fine, lovely sunshine all day! But the politics and post election violence has been disastrous for the country (as you may have seen on TV).
Regards to all
Richard
jan.de.jong(at)xs4all.nl Guest
Posted: Wed Jan 16, 2008 1:20 pm Post subject: Rotax 912 electronic noise |
Hallo Richard,
Forget about the capacitor. At 14 volts it can only hold 14 x 0,022 =0,3
Coulombs. A 10A source charges it in 0,3 / 10= 0,03 seconds.
Your only large "capacitor" is the battery. If might support a 10A
charging current for a little while, drawing down the bus voltage, but
12V seems low.
Jan de Jong
Richard Lamprey wrote:
Quote: | Thanks Craig and Mike for your inputs. I have limited knowledge of
thats the source.
Regards to all
Richard
rampil
Posted: Wed Jan 16, 2008 2:43 pm Post subject: Re: Rotax 912 electronic noise |
Hi Richard,
I am not sure that probabilities favor the electrics hypothesis.
Most electronics without moving parts remain quite silent unless they
are in the terminal stage of releasing their electronics, steam and smoke.
Have you ruled out air, coolant, or oil flowing through some constriction?
Carbon pile voltage regulators could make noise as the carbon heated,
but I think that species went extinct in the 1960s.
Best of Luck!
ward.t(at)xtra.co.nz Guest
Posted: Wed Jan 16, 2008 3:30 pm Post subject: Rotax 912 electronic noise |
Richard,
Maybe Vacuum pump, or air driven Artificial Horizon or Directional Indicator
or electrical Turn and Slip?
Best of Luck.
Tim Ward
12 Waiwetu Street,
Fendalton,
CHRISTCHURCH 8052
NEW ZEALAND
Ph :64 03 3515166
Mob: 021 0640221
email:
