lists(at)stevet.net Guest
Posted: Fri Jan 11, 2008 8:23 am Post subject: ELT/PLB |
Well, a PLB may be less expensive, but it presumes that you are
conscious when you need to activate it. Or that you will successfully
regain consciousness before, well, you know. Steve Fausset had a
personal PLB - didn't do him any good at all. Just a thought.
On Jan 11, 2008, at 7:24 AM, Giffen Marr wrote:
I am planning on using the cheapest ELT available to meet the FAR 91
Requirements and a 406 PLB. The current cost of ELT's meeting the 406
requirements are out of sight as compared to the 121.5 units. The
other
advantage is the PLB is not much larger then a cell phone as
compared to the
ELT. Only advantage to the ELT is the battery life may be longer
then the
PLB.
Giff Marr
LIV-P/Mistral 65%
frank.hinde(at)hp.com Guest
Posted: Fri Jan 11, 2008 8:48 am Post subject: ELT/PLB |
Indeed, and you can always activate it when you know you are going down. In fact I wonder how reliable the G switches are in the case of ELT's anyway...121.5 ELTs are notoriously innefective but the 406 units will still have the same kind of G switch technology I would presume, how well do they work?
Indeed my Wife is briefed to do exactly this...if the engine quits have the PLB in your hands and be ready to activate.
As to Steve Fosset I thought he just a had a 121.5 ELT and the same thing on a fancy wristwatch I doubt if that was a full 406 unit with a 5W transmit signal (remember that 121.5's only have a 50mW signal I believe)...This is supposed to be enough power to get out from under tree cover ect.
Personally I want the satellites to have a lock on me BEFORE we hit the ground.
Frank rv7a
mprather(at)spro.net Guest
Posted: Fri Jan 11, 2008 9:33 am Post subject: ELT/PLB |
Steve Fosstet might have owned a PLB, but I don't think he was actually
wearing it the day he went down - though it was for several days
incorrectly reported that he was. Please see:
http://en.wikipedia.org/wiki/Disappearance_of_Steve_Fossett
Many times ELT's don't activate on impact. On the other hand, 98% of ELT
activations are false alarms. And when they are activated, it often takes
hours to get somebody to actually try to locate the ELT (probably because
so many activations are false alarms). If I'm in bad enough shape that I
can't manually activate my PLB, I think it's statistically unlikely that
the ELT is going to get help to me fast enough to do any good.
(The 121.5) ELT's seem most effective at giving SAR/CAP something to do,
and in helping SAR/CAP find wreckage - too late. And in providing a A/P's
with a regular supply of flashlight batteries. The requirement for
(technologically immature) ELT's in small airplanes was a political knee
jerk response.
PLB's seem like a great idea. I have much better confidence in a PLB's
ability to actually help a downed aircraft. Too bad carrying one doesn't
provide an AMOC for carrying an ELT - at least in non-commercial ops.
That it's not an AMOC probably discourages the purchase of more PLB's.
Matt-
> <GAMarr(at)Charter.Net
> other
> compared to the
> then the
> PLB.
> Giff Marr
> LIV-P/Mistral 65%
Posted: Fri Jan 11, 2008 9:34 am Post subject: ELT/PLB |
If you want satellites locked in, consider getting your amateur radio
license (ham) and then start carrying (or install) a Tiny Track (or
something similar).
http://www.byonics.com/tinytrak/
And use it to keep your position updated via APRS:
http://www.googleaprs.com/
Then people will have a way to see your flight is/was going.
I wonder if ADS-B is going to support something similar.
Matt-
<frank.hinde(at)hp.com>
do they work?
cover ect.
ground.
Frank rv7a
pwmac(at)sisna.com Guest
Posted: Fri Jan 11, 2008 10:04 am Post subject: ELT/PLB |
Get the PLB that works when it is turned them on when you leave home
and turned them off when you get back. The object is that some one
knows where you are all the time when it is on. Nice for the wife at
home. Real time monitoring is the state of the art and the cost is
minimal. An ELT only works when you crash.
Read about Spot PL device.
Paul
>other
>compared to the
>then the
>PLB.
>Giff Marr
>LIV-P/Mistral 65%
Posted: Fri Jan 11, 2008 10:14 am Post subject: ELT/PLB |
I think it is more about making sure the PLB is actually transmitting while still airborne....I believe the satalites can actually register the signal relatively quickly but may not have the actual GPS coordinates locked in.
So making an assumption that you have say 2 minutes before you hit the ground and in the worse case the PLB is destroyed (unlikely) , is that enough time time to alert SAR?..I'm thinking you may not have gotten the accurate GPS lock but a 2 square mile position (from triangulating the signal itself) is a whole lot better than no position at all.
Your thoughts?
Frank
Posted: Fri Jan 11, 2008 12:02 pm Post subject: ELT/PLB |
I can't imagine that, if I'm having a critical emergency, that Im
going to say, "OK, two minutes before crashing, I'm going to activate
my PLB". Even remembering that it needs to be activated at all is
unlikely, given the amount of adrenaline that will be pumping through
your system. What do you do if you loose a prop, or have a door open
and can barely control the airplane? "Oh, yea, don't forget to
activate the PLB".
It's your airplane, and your emergency situation to plan for, so do
what suits you. As for me, even though automatic triggering functions
aren't perfect, I'll stick with an ELT that can be triggered both ways.
Steve
On Jan 11, 2008, at 10:12 AM, Hinde, Frank George (Corvallis) wrote:
| Quote: | I think it is more about making sure the PLB is actually
position at all.
Your thoughts?
Frank
Posted: Fri Jan 11, 2008 12:30 pm Post subject: ELT/PLB |
I would certainly agree it depends upon your particular circumstances and having automatic activation is better than not having it.
As for me I tend to fly to the outer regions of the USA only when accompanied by my better half..Her sole job in an emergency is to get the antenna up and fingers poised over the "On" button. So for me I think its a reasonable plan.
I still carry the PLB for short hops...a 200mph airplane can get an awfully long way away in what seems like a short flight and for this a 406Mhz ELT would be better.
Frank
raymondj(at)frontiernet.n Guest
Posted: Fri Jan 11, 2008 1:00 pm Post subject: ELT/PLB |
Greetings Listers,
The airplane I'm building is intended for off airport operations. I
believe my most likely accident scenario is striking a an object close to
the ground. That will give me virtually no time to do anything before the
event is over. I consider the automatic activation feature manditory for my
anticipated mission profile.
Another subject I have seen almost no comment on is water operation
accidents and ELTs.
Raymond Julian
Kettle River, MN
"Hope for the best,
but prepare for the worst."
longg(at)pjm.com Guest
Posted: Fri Jan 11, 2008 2:34 pm Post subject: ELT/PLB |
On the big scale I think the government is pushing this conversion (as
they are ADS-B) to enable better tracking on each GA aircraft. In the
end they will have a dozen ways to track, charge and identify everyone.
Can't wait.
Posted: Fri Jan 11, 2008 5:34 pm Post subject: ELT/PLB |
The required 121.5Mhz ELT in the plane didn't do him any good, either.
I haven't checked lately on the price difference between PLBs & 406
ELTs. If there's a serious difference, remember we are supposed to be
homebuilt a/c experimenters. Ever looked at the G-switch on a typical
ELT? The ones I've seen are just a pivoting steel weight next to an
off-the-shelf miniature toggle switch.Get to work on that PLB.
Steve Thomas wrote:
> <GAMarr(at)Charter.Net>
> requirements are out of sight as compared to the 121.5 units. The other
> advantage is the PLB is not much larger then a cell phone as compared
> to the
> ELT. Only advantage to the ELT is the battery life may be longer then the
> PLB.
> Giff Marr
> LIV-P/Mistral 65%
fvalarm(at)rapidnet.net Guest
Posted: Fri Jan 11, 2008 7:07 pm Post subject: ELT/PLB |
"On the big scale I think the government is pushing this conversion (as they
are ADS-B) to enable better tracking on each GA aircraft. In the end they
Can't wait."
That's quite a pessimistic view. Anyone with something to hide will simply
not use whatever the technology is. I think the government desperately
needs to cut costs for searches that can easily exceed your lifetimes worth
of taxes. It may speed up the rescue process which may give you a better
chance of survival, but in the larger picture, it's about saving very large
amounts of money.
Bevan
RV7A wiring
gmcjetpilot
Posted: Sat Jan 12, 2008 10:51 am Post subject: ELT/PLB |
Good comments, I'll just add a few points.
Yes a PLB is a great adjunct while the 406Mhz Regs
are in limbo (not yet mandated). Heck a PLB is a great
thing to have for you, your wife in kids in the car, boat,
skiing, hiking. How many people get lost or stuck.
(story below)
PLB's are NOT ELT's
PLB's advertise they have the same output power, but
they don't get out as well with the small portable
antenna. Besides compromises in the antenna,
battery life is less. The antenna has no real ground
plane. It can't meet
With that said PLB's are are pretty good for the
money and I want one. With PLB limitations said, if
your airframe mounted ELT's antenna is crushed
under the plane it will not work well either. Of
course a PLB needs to be manually turned on.
The PLB is good idea even if you have a 406 ELT.
The 406ME Artex ELT is the only game in "low cost"
units for aviation at about $1000. Others are working
on units but from what I am told, the specs almost
mandate a lithium Ion battery (as Aertex has) and
you can forget cheap "D" cells. They don't cut it.
The END IS NEAR
The 243 MHz is going away, period. As many
limitations as the old ELT technology had, its going to
get even less effective. The 243 MHz Sats are going
to stop looking (so they say). Widely advertised is the
accuracy of the 406 MHz technology, almost perfect
with GPS input. No guarantees in life, but 406 is better.
There is an aviation 406 ELT that can be removed
and used with a portable antenna. The basic Artex
is the 406ME ($1000), the one with the portable
antenna is 406ME/P. They look similar, but I'm told
they case is different (probably a ground plane).
The antenna folds out almost two feet. It cost about
$200 or $300 more? If they could only add internal
GPS but than you have another GPS antenna and
the extra battery drain. Artex commercial models with
GPS interface are BIG bucks. If you have a 406 MHz
ELT it seems like a shame not to transmit ELT pos
since the capability is there. The SAR comes right to
you. Of course that is where the 121.5Mhz comes in,
that is for local DF.
The PLB for the military and marine use have portable
capability. So may be one of these PLB might be
better than general consumer types?
Steve Fossett has not been found and may never be.
The RV pilot that was lost over NM and TX boarder
was not found for months, even with ATC radar
tracking. If you want to be found or you want your
family to have a body to bury, you need a working
ELT. The 406Mhz is your best bet.
Also the Artex 406ME does not have GPS data. For
only $600-$700 you can get GPS data with a PLB. It
could save your life in a car, boat or hiking.
Story: There have been many cases where people
get lost hiking or a person just drives off the road,
survives but is not found for days. Some times they
find them alive a week later off the side of the road,
even though they where only 50 yards from the
freeway, on their normal routes from home to work or
shopping. In one tragic case the police would not pull-
up the Cel Phone ping info for several days for a
woman, despite the husband's request. Missing
person wait period rules I guess. When they did get
the Cel phone triangulation, they found the car, in
gully off the side of the road, but the woman had
expired. She was alive for a day or more. PLB might
have saved her if she could have activated it. The
police don't have to go into SAR mode for a wife that
did not come home after work. I guess that is a sales
pitch for ON-Star. FLY SAFE.
Other wise flight following AND file detailed flight planes & fly them.
George RV-7 finishing
jon(at)finleyweb.net Guest
Posted: Sat Jan 12, 2008 12:08 pm Post subject: ELT/PLB |
All,
One function of a PLB that seems to have been forgotten is the tracking mode
(see http://www.findmespot.com/). Assuming you go down and the PLB is
destroyed, your next of kin have a very good idea of your whereabouts - much
better idea than an ELT provides.
Frankly, if I crash and die, I could care less if someone finds me (I know
my family does not feel that way). What I desire out of my PLB is the
ability to tell someone exactly where I am if I have a problem and survive.
Ya - all kinds of scenario's can be debated but if you MUST have a
completely fail safe solution - don't expect to get it from a $150 device.
Jon Finley
N314JF - Q2 - Subaru EJ-22 Legacy
http://www.finleyweb.net
Mid-Valley Airpark (E98), Los Lunas, NM
gmcjetpilot
Posted: Sun Jan 13, 2008 9:37 am Post subject: ELT/PLB |
Just to clarify, 406MHz Personal Location Beacon
(PLB's), is basically a hand held ELT. You register the
owner. It's free and is the official Search and Rescue
(SAR) freq with satellites operated by Governments.
The "Personal Tracking Device" (PTD) is a for FEE
commercial service. Cost of the SPOT service is $110
year, initially. 406Mhz is free. The PTD have their own
satellite or piggy back off one. I don't know how good
their coverage is. It's fairly new. The PTD are geared
for hikers, snowmobile and other out door stuff. Yes I
agree a constant tracking device is a good idea. May
be it is a good substitute for a PLB? Who knows?
True PTD can be used to get an update on location.
Your family can go on the web I guess and look up
your position real time. PLB's is only activated for
emergency. Other wise it's off. It is also passive in that
it must be activated by the user. It gives no position
unless turned on. The PTD is on all the time, which
might be a battery issue, since they run off of two little
AA's.
Some of the PTD out there from different companies
have the ability to send a message to the PTD. At one
time they where talking about future voice capability
(like a satellite phone), but the PTD's have backed
down from that, for technical (cost?) reasons. If you
HAVE a PTD than you MUST have some one
monitor you or at least know to look for you and know you
have a PTD.
A PLB is monitored 24/7 and has world
wide coverage.
>From: "Jon Finley" <jon(at)finleyweb.net (jon(at)finleyweb.net)>
| Quote: | Subject: RE: Re: ELT/PLB
| Quote: | One function of a PLB that seems to have been
forgotten is the tracking mode (see
and the PLB is destroyed, your next of kin have a
very good idea of your whereabouts much better
i>dea than an ELT provides.
| Quote: | Frankly, if I crash and die, I could care less if
someone finds me (I know my family does not feel
that way). What I desire out of my PLB is the ability
problem and survive. Ya - all kinds of scenario's can
be debated but if you MUST have a completely fail
device.
Be a better friend, newshound, and [quote][b]
