wdaniell(at)etb.net.co Guest
Posted: Mon Jan 07, 2008 12:31 pm Post subject: bonding cockpit module to hull |
Can anyone help with this?
I have a number of (what appear to be) voids in the adhesive bonding the cockpit module to the outer skin especially in the two aft joints – (the one at the rear face of the fuel tank and the one aft of that).
I have tried injecting redux but I can’t seem to make that work…any hints?
The option I thought of was to grind the whole flange down to the skin and then re-construct the join with a bid +/- 45 lay up.
Any ideas? Anyone resolve the same issue?
Will
03-Jan-08 15:52
Posted: Mon Jan 07, 2008 2:25 pm Post subject: bonding cockpit module to hull |
If this is on a Trigear, I would go with the remove and Bid option, given you will be doing a lot more glassing
for your gear sockets anyway, If you can get to any voids through the spar holes then you could glass the other side as well
just to be sure you have it. Mind the fuel tank when your grinding though.
craig
[quote] --
Posted: Mon Jan 07, 2008 5:47 pm Post subject: bonding cockpit module to hull |
Thanks, my instinct is to do this something like 4 plies staggered by about ľ in – does that sound right to you?
will
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of craig bastin
Sent: Monday, January 07, 2008 16:08
Subject: RE: bonding cockpit module to hull
craig
tonyk(at)kaon.co.nz Guest
Posted: Mon Jan 07, 2008 6:54 pm Post subject: bonding cockpit module to hull |
Quote: | > I have a number of (what appear to be) voids in the adhesive bonding the cockpit module to the outer skin especially in the two aft joints – (the one at the rear face of the fuel tank and the one aft of that).
Quote: | > I have tried injecting redux but I can’t seem to make that work…any hints?
Try injecting Redux again by first drilling two small holes, in the cockpit module glass only, at the outer ends of each of the voids. Fill a 10ml syringe with the redux and inject into one hole until it oozes out of the second. Repeat for each void.
Tony
fklein(at)orcasonline.com Guest
Posted: Mon Jan 07, 2008 7:26 pm Post subject: bonding cockpit module to hull |
William...sorry to hear of this but I believe it is a relatively common
result with a number of posts which you may be able to coax out of the
matronics archive. One aspect of the injection-solution is to provide
two holes into each void...one for the syringe, and one to allow air to
exit the void. Fortunately (for me), I cannot speak from direct
experience as this is one particular bullet I dodged.
Good luck,
Fred
– (the one at the rear face of the fuel tank and the one aft of > that).
believed to be clean.
jrgowing(at)bigpond.net.a Guest
Posted: Mon Jan 07, 2008 7:43 pm Post subject: bonding cockpit module to hull |
William
could it be that there appears to be no adhesive where the module and the fuselage are actually touching, well almost touching? and that where there is a gap filled, there is enough to black out any transparency?
That is what I thought happened with mine so long ago.
JR (Bob) Gowing UK Kit 327 in Oz
Posted: Tue Jan 08, 2008 4:27 am Post subject: bonding cockpit module to hull |
Quite right this is exactly what is happening in some places - but not in others. I tried injecting but could not make it work. Became seriously frustrated (know the feeling?)–.
So I ground down one and found that the voids are actually bubbles in the redux. So I ground down the rest of the flange and was glad that I did – a number of voids. Not I think enough to imperil the structure but enough to upset me.
So what I am left with is the rearmost flange ground down to the skin. I am going to do I do a staggered 3 ply lay up along the rear flange onto the hull.
Any thoughts on this anyone?
Another question is why this happened. If I were gluing in the cockpit module again
<![if !supportLists]>1. <![endif]>I would use Ľ bolts at the key places especially at the firewall lower bottom
<![if !supportLists]>2. <![endif]>I would support the hull in a webbing sling so that the hull could conform to the cockpit module (I made a cradle based on the profile of the cockpit module) which it must be admitted is roughly what the europa cradle suggests
Will
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Laptop JR
Sent: Monday, January 07, 2008 17:10
Subject: Re: bonding cockpit module to hull
William
Quote: |
----- Original Message -----
Sent: Tuesday, January 08, 2008 4:20 AM
Subject: bonding cockpit module to hull
Will
03-Jan-08 15:52 Quote: | http://www.matronics.com/Navigator?Europa-List | 0123456789
Date: 6/01/2008 11:57 AM |
n their emails.
Try SPAMfight 01234567890123456789
03-Jan-08 15:52
03-Jan-08 15:52
Posted: Tue Jan 08, 2008 1:00 pm Post subject: bonding cockpit module to hull |
Hi! Will
Sorry to have missed this sissue before now becxause what I have to say is too late,..... "had you held a strong light behind the two reduxed surfaces you would have seen the voids to attend to them prior to curing. I'm surprised you can't inject with a liquid redux mix .
If you have removed the flanges you must do a good job with the scuff sanding to do lay ups against.
Bob Harrison G-PTAG Happy New Year!
[quote]----Original Message----
Date: 08/01/2008 11:52
To: <europa-list(at)matronics.com>
Subj: RE: Europa-List: bonding cockpit module to hull
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]-->
Bob<?xml:namespace prefix = o />
1. I would use ÂĽ bolts at the key places especially at the firewall lower bottom
2. I would support the hull in a webbing sling so that the hull could conform to the cockpit module (I made a cradle based on the profile of the cockpit module) which it must be admitted is roughly what the europa cradle suggests
Will
William
Posted: Wed Jan 09, 2008 6:11 am Post subject: bonding cockpit module to hull |
Thanks happy new year.
I did all of that which is how I found the voids…but buggered if I could do anything with injecting even though I started with a very small drill one hole and working up through 1/8 to 3/16 for the other.Â
I have no idea why this should be so. Maybe I am doing something wrong probably being thick.
I think also that I am being “picky” nevertheless I feel more comfortable with a complete bond.  I don’t see why a lay up joint should not be as strong or stronger than a redux joint. Logically the redux joins a fiberglass structure and therefore the structure is only as strong as its weakest link which I am assuming is the (peel) strength of the fiberglass because when you test redux the fiberglass tends to fail before the redux. So a fiberglass to fiberglass bond should be as strong as a fiberglass/redux/fiberglass bond.
I hope…
Will
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of ptag.dev(at)tiscali.co.uk
Sent: Tuesday, January 08, 2008 10:19
Hi! Will
Bob Harrison G-PTAG Happy New Year! Quote: |
Subj: RE: bonding cockpit module to hull
Will
William
Will
03-Jan-08 15:52 Quote: | http://www.matronics.com/Navigator?Europa-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution |
n their emails.
Try SPAMfight 01
03-Jan-08 15:52
03-Jan-08 15:52 234567
</BLOCKQUOTE |
Get up to ÂŁ150 by recycling your old mobile - visit www.tiscali.co.uk/recycle 89 Quote: | http://www.matronics.com/Navigator?Europa-List | 0 Quote: | http://www.matronics.com/Navigator?Europa-List | 1 Quote: | http://www.matronics.com/Navigator?Europa-List | 2 Quote: | http://www.matronics.com/Navigator?Europa-List | 3 Quote: | http://www.matronics.com/Navigator?Europa-List | 4 Quote: | http://www.matronics.com/Navigator?Europa-List | 5 Quote: | http://www.matronics.com/Navigator?Europa-List | 6 Quote: | http://www.matronics.com/Navigator?Europa-List | 7 Quote: | http://www.matronics.com/Navigator?Europa-List | 8 Quote: | http://www.matronics.com/Navigator?Europa-List | 9 Quote: | http://forums.matronics.com | 0 Quote: | http://forums.matronics.com | 1 Quote: | http://forums.matronics.com | 2 Quote: | http://forums.matronics.com | 3 Quote: | http://forums.matronics.com | 4 Quote: | http://forums.matronics.com | 5 Quote: | http://forums.matronics.com | 6 Quote: | http://forums.matronics.com | 7
03-Jan-08 15:52
03-Jan-08 15:52
jan.de.jong(at)xs4all.nl Guest
Posted: Wed Jan 09, 2008 10:25 am Post subject: bonding cockpit module to hull |
Re injecting into voids: grinding the injection needle square makes it a
lot more usable.
Jan de Jong
