qb kit-front floor panels removal and gear mount
Goto page Previous  1, 2
Lew Gallagher
PostPosted: Sat Jan 05, 2008 6:28 pm    Post subject: Re: qb kit-front floor panels removal and gear mount Reply with quote
Patrick #40715,
I meant to comment on your entry earlier about stripping screws on the side panels. I also had that problem until I decided to bite the bullet and buy a cordless impact driver. I'm sure that's what they were put in with -- mass production, quick build, etc. These drivers are wonderful! I borrowed a friend's Ryobi to try it. My other cordless tools are DeWalt, so I ended up getting that one so I could use my existing batteries and charger. I no longer dread opening and closing panels with the off round nut plates. This is NOT a hammer drill. When it reaches a certain torque, it goes into impact mode. Usually it only takes a tap or two in reverse to loosen, then it functions as a regular electric screw driver. Be careful tightening as it can twist the head off if you over torque it.
Another time saver was a pneumatic pop riveter -- $20 well spent when it comes to popping the floor panels alone!
Later, - Lew
non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed !
MauleDriver(at)nc.rr.com
PostPosted: Sun Jan 06, 2008 7:07 am    Post subject: qb kit-front floor panels removal and gear mount Reply with quote
What brand and model do you use? Didn't even know they existed
(Googling now).
I use a driver with a T-handle to do this - much slower but it works.
Very useful in removing QB tanks. Pic attached.
Thanks!
Bill Watson
40605
Lew Gallagher wrote:
Patrick #40715,
Later, - Lew
non-pilot
waiting on RV-10 finishing kit
http://forums.matronics.com/viewtopic.php?p=156246#156246
 Filesize:  36.43 KB
 Viewed:  357 Time(s)
Lew Gallagher
PostPosted: Sun Jan 06, 2008 8:41 am    Post subject: Re: qb kit-front floor panels removal and gear mount Reply with quote
Bill, Nice tool, but you won't believe how these power drivers will change your life!
Here's a quick shot of the Ryobi on Ebay: http://cgi.ebay.com/Ryobi-18-Volt-Impact-Driver-New-P231_W0QQitemZ280189857137QQihZ018QQcategoryZ71297QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Here's the DeWalt like mine: http://cgi.ebay.com/DeWalt-DW056-18V-Cordless-Impact-Driver-NEW_W0QQitemZ280187210049QQihZ018QQcategoryZ42272QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
They're both similar (both probably made at same place in China) -- and the techno freaks can tell you about torq specs and blows per minute -- just get one or borrow one, you'll like it!
Later, - Lew
non-pilot
Fly off completed !
Bill Schlatterer
PostPosted: Sun Jan 06, 2008 11:22 am    Post subject: qb kit-front floor panels removal and gear mount Reply with quote
Just curious? Why would you want an impact driver for screws? Most DC
power drills have a variable setting for screws and are designed to slip at
each setting. I set mine on the lightest one, screw until it slips and go
on. Never had a screw break or bend the platenut and never had one that
would not back out easily. What do you gain with the impact driver ?
BTW, my 7 qb came with a polishing bonnet under the baggage floors Wink No
charge !
Just curious ?
Bill S
7a 80/80
Lew Gallagher
PostPosted: Sun Jan 06, 2008 4:50 pm    Post subject: Re: qb kit-front floor panels removal and gear mount Reply with quote
Bill,
I had trouble not stripping out the Phillip's heads on the side panels that were on the QB fuse -- they were really tight. I even tried the hammer impact driver on some. The advantage of these cordless impact drivers (don't think impact wrench, like lug nut wrenches) is that they end with the impact when they tighten, start with impact when they loosen. You also have no torque on the wrist like you do with the drill/screw drivers. And there's almost no chance of messing up the head of the screw.
Keep what you've got if you're happy with it!
Later, - Lew
non-pilot
Fly off completed !
Bill Schlatterer
PostPosted: Sun Jan 06, 2008 6:11 pm    Post subject: qb kit-front floor panels removal and gear mount Reply with quote
Actually, Lew, one of the parts of airplane building I like best is
collecting the tools. What's "happy with it" got to do with it! Man, if
that impact "driver" is 2% better,... Well,... I need one don't I ??? More
toys,...
Bill S Smile
coop85(at)cableone.net
PostPosted: Sun Jan 06, 2008 7:06 pm    Post subject: qb kit-front floor panels removal and gear mount Reply with quote
Bill has my vote for the "Best answer seen to date" award!
I agree 100% with your logic and follow it closely Wink
Marcus
<billschlatterer(at)sbcglobal.net>
toys,...
Bill S Smile
PostPosted: Mon Jan 07, 2008 12:51 pm    Post subject: qb kit-front floor panels removal and gear mount Reply with quote
Too late - I'm going shopping. I was just sharing what I've been doing
so far. This is pure learning experience (not to mention new tool
acquisition)
Bill,
Later, - Lew
non-pilot
http://forums.matronics.com/viewtopic.php?p=156453#156453
Page 2 of 2
