Rquinn1(at)aol.com Guest
Posted: Wed Jan 02, 2008 2:03 pm Post subject: Vans New front forks for RV6 and 7As |
I just received my new front gear leg fork from Vans to complete the modification recommend by Vans.
The fork did not look new, in fact it appears to have been installed before. I phone Vans and was told by Joe that this is the result of the contractor's jig. Has any else noticed this?
Also I plan to make the modifications during my next annual and at that time I plan to leave the gear leg in place and rethread and cut the leg as required. Does any one have the correct thread size?
Rollie & Rod
RV6A 799RQ
El Paso Int Airport
See AOL's top rated recipes and easy ways to stay in shape for winter.
ronburnett(at)charter.net Guest
Posted: Wed Jan 02, 2008 2:33 pm Post subject: Vans New front forks for RV6 and 7As |
I thought the same thing as mine looked like it had large washer marks each side of the mounting holes. guess that is why so thanks for checking.
Ron Burnett
Rollie & Rod
RV6A 799RQ
El Paso Int Airport
(http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004)
hooverra(at)verizon.net Guest
Posted: Wed Jan 02, 2008 3:36 pm Post subject: Vans New front forks for RV6 and 7As |
I called Vans on the original fork for the same reason (It looked used).
It is discolored in the manufacturing process while it is jigged via the
axle holes.Clean it up and go forward.
Also note I ordered my new fork from VAN's and shipped the leg to
Langair ground from VA. The machined leg and fork arrived within a day
of each other. If you have proper tooling to thread the leg go for it
otherwise Harmon will do right by you.
Ralph C. Hoover
RV7A
hooverra at verizon dot net
dfm4290(at)yahoo.com Guest
Posted: Wed Jan 02, 2008 4:02 pm Post subject: Vans New front forks for RV6 and 7As |
I got the new fork for my RV-8A and thought the same
thing.
The thread I believe is a 1.25" 16 pitch.
Dale Mitchell
| Quote: | I just received my new front gear leg fork from Vans
to complete the
result of the
and cut the leg as
size?
Rollie & Rod
RV6A 799RQ
El Paso Int Airport
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
n320wt(at)yahoo.com Guest
Posted: Wed Jan 02, 2008 4:50 pm Post subject: Vans New front forks for RV6 and 7As |
Those of you changing to the new fork, keep in mind that the W-10 Tri-gear Tailwind uses the same fork you have now. From what I understand, Van's will not sell this part to Tailwind owners/builders. If you don't need or want yours anymore, how about helping out the scratch builders building Tailwinds.
BRIAN ALLEY (N320WT)
CARBON FIBER COMPOSITES
101 Caroline Circle
Hurricane, WV 25526
www.carbonfibercomposites.net
304-562-6800 home
304-395-4932 cell
How are you going to win by a nose if you don't stick out your neck? [quote][b]
bobbyhester(at)newwavecom Guest
Posted: Wed Jan 02, 2008 5:37 pm Post subject: Vans New front forks for RV6 and 7As |
Sure, I paid $154 plus shipping, send me a money order and I'll get it right out
Brian Alley wrote: [quote]Those of you changing to the new fork, keep in mind that the W-10 Tri-gear Tailwind uses the same fork you have now. From what I understand, Van's will not sell this part to Tailwind owners/builders. If you don't need or want yours anymore, how about helping out the scratch builders building Tailwinds.
101 Caroline Circle
Hurricane, WV 25526
304-562-6800 home
304-395-4932 cell
How are you going to win by a nose if you don't stick out your neck? | Quote: |
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
| [b]
pilots2(at)yahoo.com Guest
Posted: Wed Jan 02, 2008 7:00 pm Post subject: Vans New front forks for RV6 and 7As |
Brian,
Will be willing to sell you ours for $100.00 and I will pay shipping.
Reuven Silberman
Pilots2(at)yahoo.com
N7WT RV7A
Brian Alley <n320wt(at)yahoo.com> wrote:[quote] Those of you changing to the new fork, keep in mind that the W-10 Tri-gear Tailwind uses the same fork you have now. From what I understand, Van's will not sell this part to Tailwind owners/builders. If you don't need or want yours anymore, how about helping out the scratch builders building Tailwinds.
101 Caroline Circle
Hurricane, WV 25526
304-562-6800 home
304-395-4932 cell
How are you going to win by a nose if you don't stick out your neck? [quote][b] [quote][b]
mike109g6(at)insideconnec Guest
Posted: Wed Jan 02, 2008 7:18 pm Post subject: Vans New front forks for RV6 and 7As |
Brian,
Send me $154 + shipping and I'll be more than happy to send you a brand new unused fork from my 9A.
Do you know anyone building a Tailwind that needs a 0-SMOH 0-290D, all accessories, new sensenich custom made metal prop, and sensenich aluminum spinner. Look on classified adds VAF F/S 0-290D Custom for more info.
Mike Humphrey
1221 Rams Run Rd
Shepherdsville, KY
40165
502-264-2214 Cell
ronlee(at)pcisys.net Guest
Posted: Wed Jan 02, 2008 7:38 pm Post subject: Vans New front forks for RV6 and 7As |
I will sell mine for $99.99 and 1 cent shipping.
Ron Lee
[quote]Brian,
Reuven Silberman
Pilots2(at)yahoo.com (Pilots2(at)yahoo.com)
N7WT RV7A
ekells(at)sympatico.ca Guest
Posted: Thu Jan 03, 2008 7:35 pm Post subject: Vans New front forks for RV6 and 7As |
I will sell my standard "old style" nose gear fork from my RV-9A . It is off the plane and ready to go - without having a first flight or exposed to outside weather. For a flat $100.00 I will prepay packaging and surface shipping to any location within the continental U.S. or Canada.
