kevann(at)gotsky.com Guest
Posted: Fri Dec 28, 2007 8:32 am Post subject: pitot/static connectors reamer to Troy |
Hi All,
I need a couple more of those nifty quick connects for pitot and static
tubes. Anybody know where I can get some?
Troy, I'll send you the Reamer that Ralph Hallett was kind enough to
send to me.
Kevin
Ivor Phillips
Posted: Fri Dec 28, 2007 9:02 am Post subject: pitot/static connectors reamer to Troy |
Hi Kevin
If you are in the UK
They are available from
http://rswww.com/cgi-bin/bv/rswww/searchBrowseAction.do?Nr=avl%3auk&N=42
94952692&in_dim_search=1&name=SiteStandard&forwardingPage=line&R=0138262
&callingPage=/jsp/search/search.jsp&BV_SessionID=(at)(at)(at)(at)0444845083.11988607
81(at)(at)(at)(at)&BV_EngineID=ccchaddmlflkikdcefeceeldgkidhgf.0&cacheID=ukie
regards
Ivor
Ivor Phillips
Posted: Fri Dec 28, 2007 9:06 am Post subject: pitot/static connectors reamer to Troy |
Hi Kevin
I believe I have given you the wrong link,
Try
94952692&in_dim_search=1&name=SiteStandard&forwardingPage=line&R=3872634
Should be the correct size
Ivor
davedeford(at)comcast.net Guest
Posted: Fri Dec 28, 2007 10:09 am Post subject: pitot/static connectors reamer to Troy |
Quote: |
<kevann(at)gotsky.com>
Hi All,
and static
Hi Kevin,
My first stop for stuff I can't get locally or at Aircraft Spruce is
McMaster-Carr (www.mcmaster.com). Check out their Quick-Disconnect Tube
Couplings. The acetal (Delrin) parts on page 175 look good to me.
Dave DeFord
N135TD
budyerly(at)msn.com Guest
Posted: Sat Dec 29, 2007 5:58 am Post subject: pitot/static connectors reamer to Troy |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> You can order them through me or Europa. I think I have about 4 left and if memory serves they are about $5 each. Or go to the Cohler Products Company website and see all the nifty QDs available. I use both their brass and plastic QDs and they are very good. They even have multiple hookups. I have had a leak, in one for fuel and one of the small ones for static so do check them.
Bud Yerly
Custom Flight Creations
