echristley(at)nc.rr.com Guest
Posted: Wed Dec 26, 2007 10:14 pm Post subject: Compass Requirements in Experimental Aircraft (updated) |
Eric Newton wrote:
| Quote: | So problem solved.
Good for you, Eric.
During the discussion, I promised to take a few pictures of my $9,
"ornamental" compass. I had taken the pictures, but never posted the
links. It turned out even better than I'd hoped.
http://ernest.isa-geek.org/Delta/Pictures/Compass.jpg
http://ernest.isa-geek.org/Delta/Pictures/CockpitFrontLeft.jpg
http://ernest.isa-geek.org/Delta/Pictures/CockpitFrontRight.jpg
Tim Olson
Posted: Thu Dec 27, 2007 10:13 am Post subject: Compass Requirements in Experimental Aircraft (updated) |
So one of the morals to the story is that magnetic base antennas
have no place in an airplane. They won't just screw with your
nearby compass but can screw with your much more sensitive EFIS
magnetometer as well. Any antenna with a magnet should be cut
apart and have it's magnet yanked...if you're going to use it
in the plane.
Eric Newton wrote:
| Quote: | Hi All,
Well its been kind of slow so I thought I would give a little update
regarding my research into whether or not a "wet" compass is required if
you have a EFIS with a remote external compass feeding a heading to it.
After much research and searching archives of all of the various
airplane groups that I belong to, I finally decided to just mount an
airpath compass on my glareshield and be done with it. I said to myself
- "no sense getting into a pissing match with the DAR over a $160
instrument, just put it in and forget it".
So I purchased the Airpath C2400 lighted compass. It arrived sometime
last week and over Christmas vacation, I finally got out to the airport
to see how it would work with my Bearhawk. I had heard that some people
were having as much as 30 degrees of installation errors in a Bearhawk
with a glareshield mounted compass.
So there I was standing beside my airplane which was pointed in a
generally northward direction. I held the compass out in front of me
and it read 358 degrees. I then reached inside and sat it on the
glareshield centered and as far back from the "V" tubes as I could. It
read "N" 360 degrees. PERFECT, only about 2 degrees off right??? WRONG!!!
I then grabbed the tail and swung it around to point the nose in a
generally south direction. Poked my head inside for a look at the
compass and . . . What's this???? It still says "N" 360 degrees!!! I
grabbed the compass out of the airplane and once again stood next to the
airplane and sure enough the compass now read 178 degrees. Put back on
the glare shield and . . . "N" 360 degrees.
So there I stood, scratching my head, thinking about what I had done to
cause what Erbman would call a "Gross Buffoonery". As I was standing
looking at things, I saw the problem. My lightening fast brain finally
figured out what I had done. When I mounted my XM satellite radio, I
didn't want to run the external antenna all the way outside so I had
simply mounted it up near the windshield right between the "V" braces.
The antenna has a strong magnet built in to allow it to stick to the
roof of your car. Of course it didn't stick to my aluminum boot cowl so
I had just double stick velcroed it in place.
The wire running from the antenna to the Xm radio on the right side of
the instrument panel was included in the main wiring harness and is well
wrapped within the bundle of wires running from the comm and intercom
system. Removing and replacing the XM satellite antenna would take a
long time laying on my back under the instrument panel cutting every tie
wrap I made.
So I decided to do what I should have done in the first place. I called
my DAR to ask him his opinion on the magnetic direction indicator in the
Dynon. I described the Dynon D100 EFIS with its remote magnetic compass
feeding heading information to the Dynon D100. He asked me again what I
was building. I said a Bearhawk. He said "That's Experimental right?"
I said "yes it is". He said "Well then, it falls under FAR part 91.205
which specifically says "Magnetic direction indicator" . He said as long
as the Dynon receives, and displays, a heading based on the Earth's
magnetic field, then it qualifies as a "magnetic heading indicator" as
required in Part 91.205 and he doesn't see why I would need an old
whiskey compass littering up my glareshield.
We talked a bit about redundency and when I told him about my battery
backup of the Dynon as well as a GPS with battery backup as well as a
handheld radio with a VOR indicator, he was more than satisfied.
So problem solved. I called Aircraft Spruce for an RMA number and as of
this morning, the compass is on its way back to Corona, CA and I'll have
a credit for it. Guess I could have saved some shipping $ by simply
calling the DAR first.
Lesson learned and shared.
Eric Newton - Long Beach, MS
BH #682- Mississippi Mudbug
BEARHAWK BUILDER'S MANUALS
http://mybearhawk.com
Posted: Wed Jan 02, 2008 5:44 pm Post subject: Compass Requirements in Experimental Aircraft (updated) |
Robert Feldtman wrote:
| Quote: | Secondly - most of us use our GPS to set our DG anyway - not the compass.
| Is that true? I am under the impression that it continues to be necessary to set the DG relative to magnetic north in order to correctly respond to vectors.
I believe that ATC gives only magnetic heading vectors (though it seems that it's time to go to true headings). It's an important issue in IFR ops but still relevant in VFR. Usually it doesn't make much of a difference but I just did 400 miles in 45knot winds at 8,000 and below it really did make a difference. (BTW, it was a glorious tailwind!)
Do many of you use the GPS to set your DG? I navigate with by GPS, follow vectors using my DG, use my compass to set my DG, and constantly try to discern the meaning of the difference between the two.
Perhaps I can simplify things a bit. Thinking it through, I could easily keep my DG set to my desired GPS course. But I would then have to remember to reset it or at least check it when getting vectors. I usually only get vectors at the beginning and end of flights. But I guess I've just learned to use my GPS as primary during point to point navigation and use my DG as primary during vectors and put up with the difference between the two.
Bill "can't wait to get that 45 knots all the time when I move to an RV10" Watson
On 12/28/07, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote: | Quote: | --> AeroElectric-List message posted by: Tim Olson <Tim(at)MyRV10.com (Tim(at)MyRV10.com) >
Another builder asked me to forward this because he's on
vacation, but wanted to join in the thread:
"But another very important issue regarding magnetism is that the steel
parts in the plane can pick up residual magnetism from permanent magnets
and it can be a real problem to sniff out and get rid of with a
magnaflux (I think he means degaussing -Tim) tool. I believe a I made
a complete posting regarding this in the RV10-list archive. But even
the helical steel coil in scat tubing is capable of causing totally
eronous compass readings. I had this occur when we re-did the
instrument panel in our glastar. I even avoid using magnetic tip tools
now that I've seen how difficult it can be to solve the residual
magnetism problem.
-bob newman
Tim Olson wrote:
> --> AeroElectric-List message posted by: Tim Olson <Tim(at)MyRV10.com (Tim(at)MyRV10.com)>
| [b]
Jim Baker
Posted: Wed Jan 02, 2008 7:13 pm Post subject: Compass Requirements in Experimental Aircraft (updated) |
X-SpamReason %%SpamReason%%:
| Quote: | I believe that ATC gives only magnetic heading vectors (though it seems that it's time to go to
true headings).
I'll second that. My current job is a contract procedures
development specialist for the FAA and the things we see with
facility Mag Var issues would make most folks cry.
A lot of the facility Mag Vars go back to the 60s, 70s and 80s.
Consider what happens when you have an NDB with a 60s Mag
Var, a nearby VORTAC with a 70s Mag Var, and an ILS with an
80s Mag Var.
ZZV ZANESVILLE VOR/DME Variation: 06W (1990)
TVT TIVERTON VOR/DME Variation: 03W (1965)
Only 32 miles from each other. If you saw how much havoc
changing just one Mag Var causes, which you really can't do
efficiently because of the ripple effect....change one, you'd better
be prepared to change a lot of them. That's why Mag Vars don't
get changed often.
Personally, I'm hoping for the pole reversal........
Jim Baker
580.788.2779
Elmore City, OK
