bertrv6(at)gmail.com Guest
Posted: Sat Dec 22, 2007 9:06 am Post subject: question on Micro Air radio |
Hi:
I posted a message on the Micro Air radio before. Some one responded
and mentioned he had some problem with the Grounding of PTT pilot
side....
I want to know for those with this unit, what other comments you have
good and bad.
I am thinking of adding another radio, and this has a price that is
not too bad..
I am bying with it the harness...
Another question is how one does to connect both radios to same antena,
I do not want to have to go thru another installation... if I can..
Appreciate your comments
Bert
rv6
Dop not archive..
| | - The Matronics RV7-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
drthomasd
Posted: Sat Dec 22, 2007 7:36 pm Post subject: Re: question on Micro Air radio |
Hi Bert,
I have the Microair radio and transponder in my Rotorway helicopter and did have a reception problem with the radio. The problem was a bad solder joint and then things were fine.
Most of the problems I was aware of were from several years ago so I decided to go with this combo. Following my issue I was told by another Rotorway owner that he knew of three ships with this radio that had unresolved reception problems. I am not sure if the radio can be blamed or not.
Check out the following link. The Xcom has more transmitting power than the Microair. I was not aware of this when I made my decision
http://www.mcp.com.au/microair/comparison/comparison.html
Soon I will be making the decision to start on an RV-10 but I don't believe I would go with the Microair.
_________________ Tom Delaney
St. Louis, MO
N427G Rotorway Exec 162F
Soon to make decision on RV-10 |
