building_partner(at)yahoo Guest
Posted: Thu Dec 20, 2007 6:42 pm Post subject: Wiring |
Total Novice here..... I'm building an RV-10 with dual Lightspeed ignition. Electronics are as follows; SL40 Radio, GTX327 Transponder, 496 GPS, PS3000 audio panel, and the Advanced Flight Systems 3500 efis.
My question are; Has anyone set up the rpm wiring between the Lightspeed and the efis?
Prior to finalizing my connections, I wanted to double check my wiring pin numbers for the wires which interconnect between equipment.... ie. 496 to efis, or sl40 to audio panel, etc
Any help will be much appreciated
Thanks, Don McDonald N14XG
