fklein(at)orcasonline.com Guest
Posted: Mon Dec 17, 2007 3:38 pm Post subject: rudder cable protection |
All flying monwheelies,
I'm wondering about the advisability of protecting the rudder cables
from potential muck and moisture where they run through the wheel well
by encasing them in some kind of tubing.
Is there anyone out there who wishes they had?
Or anyone who regrets doing so, and if so, why?
Is anyone aware of any downside to doing so?
Or is this just another non-issue which might prompt the comment,
"Fred, just build the plane!" ?
Fred
A194
believed to be clean.
rlborger(at)mac.com Guest
Posted: Mon Dec 17, 2007 4:49 pm Post subject: rudder cable protection |
Fred,
I used Nyloflow tubing to cover the rudder cables from the firewall to well aft of the wheel well. Since I'm not quite flying yet, I can't comment on the efficacy of the treatment.
Good building and great flying,
Bob Borger
Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
http://www.europaowners.org/N914XL
(90%) tail kit done, wings closed, cockpit module installed, pitch system in, landing gear frame in, rudder system in, outrigger mod in, Fuselage Top on, lift/drag/flap pins in, wing incidence set, tie bar in, flap drive in, Mod 70 done. Baggage bay in. Flaps & Main Gear complete. Mod 72 complete. Instrument panel complete, except for testing. Rotax 914 installed (for the 3rd time). Airmaster Prop installed. Electrical complete, except for testing. Fuel system complete except for testing. Working in - 32 Tail, 34 Door Latches & 35 Doors, 37 Interior & Finishing. Airmaster arrived 29 Sep 05. Seat arrived from Oregon Aero. E04 interior kit has arrived and is being installed.
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
On Dec 17, 2007, at 5:36 PM, Fred Klein wrote:
Quote: | --> Europa-List message posted by: Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)>
I'm wondering about the advisability of protecting the rudder cables from potential muck and moisture where they run through the wheel well by encasing them in some kind of tubing.
Or is this just another non-issue which might prompt the comment, "Fred, just build the plane!" ?
Fred
A194
-- Please Support Your Lists This Month --
(And Get Some AWESOME FREE Gifts!)
November is the Annual List Fund Raiser. Click on
the Contribution link below to find out more about
this year's Terrific Free Incentive Gifts!
List Contribution Web Site:
--> http://www.matronics.com/contribution
Thank you for your generous support!
- The Europa-List Email Forum -
--> http://www.matronics.com/Navigator?Europa-List
- MATRONICS WEB FORUMS -
--> http://forums.matronics.com
kheindl(at)msn.com Guest
Posted: Mon Dec 17, 2007 6:34 pm Post subject: rudder cable protection |
Fred,
I and others have done same. Tube is attached to tunnel sides with P-clips. Have not had any problems and wouldn't expect any.
Karl
Subject: Re: rudder cable protection
Date: Mon, 17 Dec 2007 18:46:04 -0600
Fred,
Bob Borger
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
Fred
A194
paul.the.aviator(at)gmail Guest
Posted: Mon Dec 17, 2007 7:14 pm Post subject: rudder cable protection |
Fred,
I used Nyloflow and after 700 hours I haven't seen any down side. I
believe that is how it is done on the Long Eze's as well.
Cheers, Paul
rehn(at)rockisland.com Guest
Posted: Mon Dec 17, 2007 9:25 pm Post subject: rudder cable protection |
Fred
You keep adding stuff and you won't make it to OSH this year or next! Mine
are per factory and after 7 years may have some dirt on them but are working
fine and are easy to inspect for corrosion etc.
If it's not broke why fix it?
Jerry
josok-e(at)ukolo.fi Guest
Posted: Tue Dec 18, 2007 1:42 am Post subject: rudder cable protection |
Fred,
Even in Summer it's below freezing at high altitudes. Such a cable in a tube could contain water and freeze stuck.
Jos Okhuijsen
Visit - www.EuropaOwners.org
karelvranken(at)hotmail.c Guest
Posted: Tue Dec 18, 2007 1:47 am Post subject: rudder cable protection |
Fred,
The cable in the tubing, even partly, will not be visible for inspection.
When using teflon tubing for lubrication without oil or grease, you cannot
avoid dust and sand entering the tubes and cause more wear inside.
If you land often in mud or when ploughing your private strip, wash it
regularily and inspect condition. A mud cap can be of interest over the
wheel.
Seasons greetings.
Karel Vranken, F-PKRL
Posted: Tue Dec 18, 2007 2:32 am Post subject: rudder cable protection |
Fred, Nylaflow has worked perfectly for me x 6yrs. It's standard practice in
glider dating back to the invention of Nylaflow. Although there is an
inspection issue, my inspector (who is a professional glider repair
engineer), tells me that cable wear in the protected bits is significantly
less than in the exposed bits running over wheels or other bearing points.
Regards, David Joyce, G-XSDJ
Posted: Tue Dec 18, 2007 8:58 pm Post subject: rudder cable protection |
Thanks guys for all the thoughtful comments to my query. As I still
have questions in my mind as to the exact path f the rudder cables and
potential clearance issues, I'm going to wait until I can trial fit
them before deciding about the nylaflow conduits. Without wanting to
prolong the subject, I gather that the cable guides and rubbing strip
would be altered or omitted entirely when conduit is used.
Fred
Posted: Wed Dec 19, 2007 1:47 am Post subject: rudder cable protection |
Fred, You still keep the rubbing strip and route the Nylaflow through the
guide in the wheel well (probably reducing the friction and certainly the
wear at this point). You leave a gap as the cable goes under the little
wheels. Regards, David Joyce, G-XSDJ
