Colin K.
Posted: Mon Dec 17, 2007 2:04 pm Post subject: Flute tubes |
How do you draw a straight line (center line) down the side of a piece of tube?
I held the tube on a flat surface and had someone help me by marking each end where it toucehd the surface, Then I drew a line between the two marks.
Is there a better way?
Colin K.
OK
| - The Matronics Lightning-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
_________________ Colin K.
OK |
jojatek86(at)yahoo.com Guest
Posted: Mon Dec 17, 2007 2:32 pm Post subject: Flute tubes |
Colin:
You can use a straight piece of structrural angle (like 1x1x1/8 Alum. angle). It will nest on the outside diameter (O.D.) of the tube and you can mark your line down the edge of the angle. The legs of the angle need to be smaller than the O.D. of the tube. If you don't have small enough angle in your kit, Home Depot or hobby stores sell some fairly small sections.
Pat Phillips
Lawrenceville, GA
Colin K.
