Allen Fulmer
Joined: 10 Jan 2006 Posts: 79 Location: Alexander City, AL
Posted: Sat Dec 08, 2007 8:35 pm Post subject: Pitot/Static plumbing with Ny-Loc fittings? |
When plumbing ASI, ALT, AHRS, etc. with Ny-Loc fittings, do we use anything
on the pipe threads? Teflon tape, EZ-turn lubricant, etc.?
TIA,
Allen Fulmer
RV7 Avionics and wiring
Eggenfellner Subaru E6T on hand
N808AF reserved
Alexander City, AL
256-329-2001
| | - The Matronics RV7-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
_________________ RV7 QB Fuselage
Eggenfellner H6 on orde
N808AF reserved
Alexander City, AL |
andrew.phillips(at)sympat Guest
Posted: Sun Dec 09, 2007 5:29 am Post subject: Pitot/Static plumbing with Ny-Loc fittings? |
These are under very low pressure so I used just a little teflon tape
(probably could get away with nothing). Some quick release fittings that
came in a kit I bought had the tape already on them too.
Allen Fulmer wrote:
TIA,
Allen Fulmer
N808AF reserved
Alexander City, AL
256-329-2001
reichec
Posted: Sun Dec 09, 2007 6:14 am Post subject: Pitot/Static plumbing with Ny-Loc fittings? |
I just did a pitot-static inspection on a new g100 cessna 172 yesterday and
there were leaks everywhere.... check the pipe thread segment of your
connections that go into the instrument for what i will call "crappy
manufacturing" These little suckers are molded and sometimes are left with
a flash line that runs down the thread. I took out all the instruments that
were easy to get at and put teflon tape on the fittings, finally getting the
leak rate down to about 80ft/min at 1000' above my field elevation. Good
enough!
I have also heard or using DC-4 silicone lubricant instead of the EZ-turn
honey like stuff that can just lead to a mess.
Charles
