n616tb(at)btsapps.com Guest
Posted: Sun Dec 02, 2007 4:17 pm Post subject: Vacuum Guage hookup |
I have a small vacuum gauge that has two smaller ports on it labeled V and
P. I assume the V is for the vacuum and the P would be the export. I
understood there was a port on some of the other gauges that would allow me
to just run a hose from it to the vacuum gauge. Does this suction gauge
need to be plumbed in series with the other gauges in order to take
advantage of the filtered air? It has smaller ports on it so would have to
find a hose that would fit between the larger ports on the gauges and the
smaller port on the suction gauge.
Any thoughts?
Vanremog(at)aol.com Guest
Posted: Sun Dec 02, 2007 5:43 pm Post subject: Vacuum Guage hookup |
In a message dated 12/2/2007 4:18:37 P.M. Pacific Standard Time, n616tb(at)btsapps.com writes:
| Quote: | I have a small vacuum gauge that has two smaller ports on it labeled V and
advantage of the filtered air? |
Actually, that would be the intuitive take on things, but it would be exactly wrong. The P stands for Pressure (in this case the negative pressure) that is seen at the intake of the vacuum pump (but before the regulator). The V stands for Vent (in this case Static) or ambient outside pressure (or aircraft ambient). Look for a Rapco schematic that I think is available on the web or in the ACS catalog and it explains the whole setup in detail.
N1GV (RV-6A, Flying 870hrs, O-360-A1A, C/S, Silicon Valley)
hottest products and top money wasters of 2007.
denis.walsh(at)comcast.ne Guest
Posted: Sun Dec 02, 2007 5:49 pm Post subject: Vacuum Guage hookup |
V is usually for vent and P is for the pressure or "suction". refer
to Aircraft spruce which used to have an excellent schematic for how
to do a suction system.
In my case I left v alone and hooked the p to one of the suction
instruments. the whole shmear is in series with the air coming
through the big filter first, then to the two instruments, then to the
regulator, then to the pump.
On Dec 2, 2007, at 5:14 , Tim Bryan wrote:
V and
allow me
gauge
have to
and the
Any thoughts?
dbris200(at)sbcglobal.net Guest
Posted: Sun Dec 02, 2007 6:28 pm Post subject: Vacuum Guage hookup |
Tim,
The gyro should have a small port which goes to the gauge. The "V" is
the "vent" and the "P" is pressure (positive or negative) so the "P"
connects to the gyro. Since there is no airflow through the gauge, there
no need to connect the "V" to anything or worry about filtered air.
Dave
Tim Bryan wrote:
Any thoughts?
Posted: Sun Dec 02, 2007 6:56 pm Post subject: Vacuum Guage hookup |
Thanks everyone for the responses. I surely would have got it backwards.
The question then is if the pressure (P) were to be negative then wouldn't
there be air flowing through the gauge? If I don't put a filter on the vent
side you say it would be OK?
[quote] --
n801bh(at)netzero.com Guest
Posted: Sun Dec 02, 2007 8:00 pm Post subject: Vacuum Guage hookup |
IIRC, The gauge has only one port on it so the air eally isn't passing through it, all it does is sense vacuum because it is a dead end circuit.
Posted: Mon Dec 03, 2007 7:27 am Post subject: Vacuum Guage hookup |
Ben,
My suction gauge has two ports on it. One labeled V and the other labeled P. Mine is a U.M.A, Inc part number 3-200-12, PMA part.
Does this make a difference?
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of n801bh(at)netzero.com
Sent: Sunday, December 02, 2007 9:54 PM
To: rv-list(at)matronics.com
Subject: RE: Vacuum Guage hookup
IIRC, The gauge has only one port on it so the air eally isn't passing through it, all it does is sense vacuum because it is a dead end circuit..
Ben do not archive
Ben Haas
N801BH
www.haaspowerair.com
-- "Tim Bryan" <n616tb(at)btsapps.com> wrote:
--> RV-List message posted by: "Tim Bryan" <n616tb(at)btsapps.com>
Posted: Mon Dec 03, 2007 8:14 am Post subject: Vacuum Guage hookup |
Tim. It has been three years since I installed mine in my experimenatl but if I remember correctly there was two versions. The one with a single port was for vacuum only. The one for dual purpose had two ports, My thoughts were there is a diaphram that drives the needle in the gauge. Vacuum is introduced into one side of the diaphram and that moves the needle the correct way. If one was using a pressure system to drive the gauges that pressure is introduced on the opposite side of the diaphram. That way one gauge could be used in both applications. If your plane is running a vacuum system my guess is to hook up to the ' V ' port...
Ben Haas
N801BH
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />Ben,
To: <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" />rv-list(at)matronics.com
Posted: Mon Dec 03, 2007 8:17 am Post subject: Vacuum Guage hookup |
Ok, I got it figured out. ACS sells a fitting that goes in the back of one of the main gauges that is a T fitting. The 3/8” side is for the suction/ vent and a T part that is ¼” to go to the suction gauge. I ordered two of these ($$) so I could T into both the vent and the suction sides of the hoses.
I found this diagram and fitting part numbers on ACS suction kit installation documents.
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tim Bryan
Sent: Monday, December 03, 2007 9:25 AM
Ben,
Ben do not archive
Ben Haas
N801BH
Posted: Mon Dec 03, 2007 8:33 am Post subject: Vacuum Guage hookup |
Thanks Ben,
Check out this picture:
http://www.aircraftspruce.com/catalog/pdf/Rapco%20Vacuum%20System%20Kit.pdf
Sent: Monday, December 03, 2007 10:12 AM
Ben Haas
N801BH
Ben,
Ben do not archive
Ben Haas
N801BH
Also this one indicates as others mentioned that “V” is for the vent and “P” is the vacuum port
http://www.aircraftspruce.com/catalog/graphics/1001100INSTALLATIONGUIDE.jpg
Ben Haas
N801BH
Ben,
Ben do not archive
Ben Haas
N801BH
