Thomas.N.Gautier(at)jpl.n Guest
Posted: Mon Nov 26, 2007 10:05 am Post subject: Securing main tank drain valves |
All,
I'm coming, at last, to the end of the wings and I'm looking at
a final installation of the CAV-110 drain valve for the fuel tanks.
I ask myself "How do I make sure this little sucker never loosens
up and falls out in flight, leaving me high and dry?"
Of course I always drain a bit from the tanks on the first flight
of the day and after refueling, etc., so you would think any problem
would easy to spot before real trouble. But, a tank draining in flight
is sort of catastrophic and any loosening with fuel drips, etc. that
you fix on the ground is, at best, annoying.
So, what's the wisdom of the group? Jesse tells me to use fuel
lube and, presumably, then depend on the tapered pipe thread for
security. I thought I heard something about using some kind of
Loctite here. It's also easy enough to rivet a little tab on the skin
behind the drain valve and drill the valve hex for a safety wire.
Does anyone EVER have a problem with just tightening against
the tapered thread? Also, I'd like to hear what the pros like
John Cox think.
Nick Gautier
#40363
end of the wings
wvu(at)ameritel.net Guest
Posted: Mon Nov 26, 2007 2:36 pm Post subject: Securing main tank drain valves |
The only problem I ever had with the drain valves was that they were
excessively tight, to the point that I could not move the valves to drain
fuel from the tanks. Try installing your first drain valve. I think the
number of threads and the torque required will give you a better feel that
they won't be going anywhere soon.
Anh
N591VU-115hrs
