George W Braly
Posted: Fri Feb 24, 2006 5:12 pm Post subject: Spam> RE: SD-20 Alt performance chart? |
Six cylinder vacuum pads that are on the same drive shaft as the
magnetos turn at 1.5 x crank RPM.
George
aadamson(at)highrf.com Guest
Posted: Fri Feb 24, 2006 5:52 pm Post subject: Spam> RE: SD-20 Alt performance chart? |
Thanks George, so for 2500 RPM indicated engine speed, the vacuum pump pad
would be turning at 5000 rpm correct? That makes a little more sense.
Alan
mprather(at)spro.net Guest
Posted: Fri Feb 24, 2006 6:43 pm Post subject: Spam> RE: SD-20 Alt performance chart? |
Err... Math in public isn't a good idea.. 2500 * 1.5 = 3750..
Matt-
<aadamson(at)highrf.com>
pad would be turning at 5000 rpm correct? That makes a little more
sense.
Alan
Bob McC
Posted: Fri Feb 24, 2006 6:56 pm Post subject: Spam> RE: SD-20 Alt performance chart? |
Alan
1.5 x 2500 = 3750 NOT 5000
Bob McC
_________________ Bob McC
Falco #908
(just starting) |
Posted: Fri Feb 24, 2006 7:50 pm Post subject: Spam> RE: SD-20 Alt performance chart? |
Now, guys... It's been a long day... Guess I can't even play the Markup vs.
Margin game on this one... OR, can you, perhaps I did the divide by .5
instead of times by 1.5...
Sorry, you are right
Alan - tail between legs and going back to sanding... I knew I should have
even questioned 5000 rpm, let alone 7500
