brian-1927(at)lloyd.com Guest
Posted: Tue Nov 13, 2007 9:11 am Post subject: carbon bonds (was: mogas vs 100LL) |
I hate it when something sticks in my head overnight. It means I am
not going to get a good night's sleep. (Yes, I do lose sleep over
stuff like this. Yes, I probably am crazy.)
The issue was the comment about higher grades of fuel having more
carbon-carbon bonds and therefore more energy. The Wikipedia article
I referenced, http://en.wikipedia.org/wiki/Octane_rating, also
alluded to that. OTOH I figured that if there was an appreciable
increase in C-C bonds there would be a shift in best stoichiometric
mixture when measured by mass ratio.
As a mental experiment I decided to trot out my old and rotten
chemistry memories to compare the two simplest organic compounds with
single and double carbon-carbon (c-c) bonds: ethane (C2H6) and ethene
(C2H4). Ethane has a single C-C bond and ethene has a double C=C
bond. Combusting ethene should release more energy than combusting an
equivalent mass of ethane. Here is what the two molecules look like:
Ethane:
H H
H-C-C-H
H H
Ethene:
H H
C=C
H H
When you have the double carbon bond you no longer have bonds for the
two extra hydrogens. This changes the combustion reaction from:
2(C2H6) + 7(O2) = 4(CO2) + 6(H2O) + energy
To:
C2H4 + 3(O2) = 2(CO2) + H2O + energy
The mass of ethane is 30gm/Mol. The mass of ethene is 28gm/Mol. The
mass of O2 is 32gm/Mol. So the oxidizer-to-fuel mass ratios for the
two reactions are:
7(32)/2(30) = 3.73 (for ethane)
3(32)/28 = 3.42 (for ethene)
This is a 9% difference in mass ratio. (I didn't include the N2 from
the atmosphere because, while it does change the individual mass
ratios, it does not effect the percentage difference at the end which
is what I was looking for.)
My gut feeling is, if "higher quality" gasoline had a lot more C=C
(double) bonds (and therefore more energy), we would have to readjust
our carburetors when we switch fuel in order to get a proper mixture.
Since we don't ...
BTW, I encourage someone to show me where I am wrong as I always am
looking to learn.
Brian Lloyd 3191 Western Drive
brian HYPHEN 1927 AT lloyd DOT com Cameron Park, CA 95682
— Antoine de Saint-Exupéry
PGP key ID: 12095C52A32A1B6C
PGP key fingerprint: 3B1D BA11 4913 3254 B6E0 CC09 1209 5C52 A32A 1B6C
l39parts(at)hotmail.com Guest
Posted: Sun Nov 18, 2007 4:42 pm Post subject: carbon bonds (was: mogas vs 100LL) |
You lose sleep over things like that? Sheesh. The amount of energy liberated, the temperature produced, and the speed of the deflagration/detonation are three independent characteristics. Nitroglycerin, for example has a very high speed of combustion, but a rather low BTU content. Acetylene has a C-C triple bond and produces the highest combustion temperature (aside from the 'observed', but unsubstanciated diatomic hydrogen combustion).
You are correct that octane is measure of anti-knock characteristics. It is not a measure of BTU content (energy). Good luck in convincing people of that though. Billions have spent on advertising to convince the public otherwise. Using a higher octane gas than an engine needs is of absolutely no value. Higher grades of gas may have more additives that do something good for the engine (or may not), but that isn't what octane measures. There is something called octane creep, wherein an engine needs a higher octane fuel as it gets older, related to the fact that it is more prone to pre-ignition due to deposits in the cylinders. Marvel Mystery Oil may help... or maybe not. I believe MMO's usefulness is in preventing varnish in the delicate little parts of the carb.
But I digress. Your points were all correct in your previous post.
Trivia: What is the 66 in Phillips 66? It is the octane rating of straight gasoline from way back in the old days when brewing gasoline was a lot simpler than it is today, before cracking of the heavy ends was possible.
| Quote: | From: brian-1927(at)lloyd.com
Subject: Yak-List: carbon bonds (was: mogas vs 100LL)
Date: Tue, 13 Nov 2007 09:09:49 -0800
To: yak-list(at)matronics.com
--> Yak-List message posted by: Brian Lloyd <brian-1927(at)lloyd.com>
Ethane:
H H
H-C-C-H
H H
Ethene:
H H
C=C
H H
To:
two reactions are:
Since we don't ...
looking to learn.
&g========================>
Share life as it happens with the new Windows Live. Share now! [quote][b]
Posted: Sun Nov 18, 2007 5:58 pm Post subject: carbon bonds (was: mogas vs 100LL) |
On Nov 18, 2007, at 4:41 PM, Ron Davis wrote:
| Quote: | You lose sleep over things like that? Sheesh.
Yeah, sometimes. Or maybe I just can't sleep and stuff like that ends
up grabbing the unused processing neurons; my brain's way of
twiddling its thumbs. Think of it as counting carbon bonds instead of
sheep.
| Quote: | The amount of energy liberated, the temperature produced, and the
characteristics.
Well, delta-T * mass implies energy to me but you are right in that
temperature is not heat.
| Quote: | Nitroglycerin, for example has a very high speed of combustion, but
Huh. And here I was going to call it Ethyne. I was forgetting that
was Acetylene.
| Quote: | You are correct that octane is measure of anti-knock
Nope.
| Quote: | There is something called octane creep, wherein an engine needs a
the carb.
OTOH, I suspect that MMO actually reduces the octane rating of the
fuel. We can certainly get away with it when burning 100LL in our low-
compression radial engines as we have huge detonation margins but
that might not be the case when running mogas.
| Quote: | But I digress. Your points were all correct in your previous post.
Thank you. I thought I was but I have been known to be wrong in the
past.
| Quote: | Trivia: What is the 66 in Phillips 66? It is the octane rating of
What comes out first is best.
