MJKTuck(at)cs.com Guest
Posted: Fri Nov 16, 2007 7:15 pm Post subject: Digital Readout Engine Gauges |
Hi Folks,
I have a row of Mitchell Engine Instruments and have often thought about
changing them to something with a digital readout. I sit and wait for
that Oil Temperature needle to point (somewhere close to) 120 deg and
think it would be neat to actually see the temperature is creeping up
and maybe be a bit more accurate.
I was looking online and found some possibilities in the custom auto
industry.
Anyone in the US tried any of these?
The Dakota Digital ones have upper limits suitable for a Rotax, the
Cyberdyne ones come up a bit short. Both have limits you can set so the
displays flash as a warning. They seem pretty neat to me.
Check out:
http://cyberdynegauges.net/temperaturegaugesproduct.php
http://www.dakotadigital.com/index.cfm/page/ptype=results/Category_ID 62/home_id=59/mode=cat/cat262.htm
Comments? Any other suggestions?
Martin Tuck
Europa N152MT
Wichita, Kansas
craigb(at)onthenet.com.au Guest
Posted: Fri Nov 16, 2007 8:23 pm Post subject: Digital Readout Engine Gauges |
doesnt say if you can get them in deg c, which i would want, and i wonder
how accurate that compass is, other than that they look ok to me
the egt is about half the price of a digital aero one, so price is good
craig
europa flugzeug fabrik
Joined: 13 Feb 2006 Posts: 65 Location: North Coast, USA
Posted: Sat Nov 17, 2007 5:20 am Post subject: Re: Digital Readout Engine Gauges |
Any engine instrumentation we buy has to be compatible with the Rotax temp and pressure senders.
Fred F
Posted: Sat Nov 17, 2007 5:58 pm Post subject: Digital Readout Engine Gauges |
From what I can see they do require their own senders but they appear
to be identical in size/thread, etc.as the Rotax ones so switching them
doesn't appear to pose a problem.
Martin
europa flugzeug fabrik wrote:
Fred F
M.Grass(at)comcast.net Guest
Posted: Sat Nov 17, 2007 8:58 pm Post subject: Digital Readout Engine Gauges |
Martin,
Be aware that only numerical displays impose additional workload to the
pilot. You would actually have to read the number and the brain has to
process the numbers and compare them mentally.
In your case, I would look for some instruments with a combined analog and
digital representation in one instrument.
Example is at
http://www.sportflyingshop.com/Instr/Stratomaster/SmartSingles/smartsingles.html .
The nice thing about digital once is that many have a monitoring feature and
will ring an alarm when certain programmed levels are exceeded.
You find also nicer looking once in the automotive and aviation industry if
you look further.
Advantage of analog representation is that you just need to have a short
look at the instrument to see that all data are in the right area. Much
quicker and less workload to the brain. This is exactly the reason why the
digital representation in a car never took of.
Michael Grass
A266 Trigear
Detroit
patkinson
Posted: Sun Nov 18, 2007 1:12 am Post subject: Digital Readout Engine Gauges |
Michael
I am probably totally biased now but I have to disagree. I can't comment
on any extra brain activity that may be required but having sat in front
of several different types of digital display over a number of years I
find them just as easy to use as analogue ones and actually prefer them.
Probably the best type of display is one that combines the two. I am sure
that it aids more accurate speed control, which is no bad thing,
particularly in low speed flight near the ground.
My car has a digital display (no analogue) and although it took a bit of
getting used to I am very comfortable with it now, and no longer feel that
an analogue display is necessary at all.
Paul Atkinson
On Sun, 18 Nov 2007 04:53:40 -0000, Michael Grass <M.Grass(at)comcast.net>
wrote:
Martin,
and digital representation in one instrument.
Example is at
and will ring an alarm when certain programmed levels are exceeded.
industry if you look further.
short look at the instrument to see that all data are in the right area.
Much quicker and less workload to the brain. This is exactly the reason
why the digital representation in a car never took of.
Michael Grass
A266 Trigear
Detroit
ami(at)mcfadyean.freeserv Guest
Posted: Sun Nov 18, 2007 2:37 am Post subject: Digital Readout Engine Gauges |
Paul,
I agree about the car thing; but in that instance a specific number is being
sought (i.e. speed, to enable mental comparison to a limiting speed).
I have to say that an analogue needle pointing to a green arc can be seen
from the corner of an eye, without need to focus, read and interpret. Much
easier in my view. Helps if the gauges aren't mounted at the bottom of the
panel, however.
The alarm facility on the digital gauges is without equal, especially as
analogue gauges probably don't get looked at very often, or not at the
precise moment needed !
Duncan McF.
Posted: Sun Nov 18, 2007 3:22 am Post subject: Digital Readout Engine Gauges |
Not sure about pilot training in the UK and US but most of the schools in
Australia
teach students to a C.L.E.A.R.O.F.F check every 15 minutes. A LOT can happen
to an engine
in 15 minutes (personal experience) and an alarm IMHO is the best way to go
as people get
tired and thus less vigilent, and you may be checking t's & p's etc, but not
actually
"seeing" them regardless of the gauge style especially on longer flights,
one option
for analogue gauges is to align them in the same way the old race cars did,
so all the needles should
point straight up or down under normal conditions, that way any needle not
vertical is instantly evident, it does however
give your panel an odd look with all your gauges at crazy angles.
craig
Mark Burton
Posted: Sun Nov 18, 2007 3:55 am Post subject: Re: Digital Readout Engine Gauges |
In that case, why not use a talking ASI? With one of those you don't have to look at the panel at all - you can keep your eyes outside which has to be a good thing from the safety point of view if you happen to find yourself low and slow.
Obviously, if you are a highly trained pilot who flies lots of hours in glass cockpits then digital readouts would probably be no problem but for your average pilot who doesn't fly so many hours, digital readouts would, perhaps, be less easy to read quickly than an old fashioned "steam" gauge. Maybe a digital ASI would not be a good thing but for the other instruments, it probably makes no difference from the safety point of view whether they are digital or analogue.
Cheers,
Mark
patkinson
Posted: Sun Nov 18, 2007 5:54 am Post subject: Digital Readout Engine Gauges |
Mark
Why not indeed. The only drawback that I can think of is that the constant
chatter might become very irritating. If you can design one that talks
when asked to, shuts up when told to, and otherwise gives the odd warning
automatically now and again you might have a winner. There's a challenge
If anything glass displays IMHO make things easier for everyone,
experienced or not. Most that I have seen combine digital and analogue and
because all the information you need is contained in a smaller area
(compared to steam gauges) scanning it is a simpler task.
Paul
On Sun, 18 Nov 2007 11:55:54 -0000, Mark Burton <markb(at)ordern.com> wrote:
| Quote: | In that case, why not use a talking ASI? With one of those you don't
Cheers,
Mark
paul.the.aviator(at)gmail Guest
Posted: Sun Nov 18, 2007 6:21 am Post subject: Digital Readout Engine Gauges |
Hi folks,
Well I would like to share my experience with using digital only
displays in my aircraft. I had the exact same concern that it would
take some level of interpretation, but I really didn't find it a
problem at all. I actually find it quite seamless. The only
exception might be when something is trending, but to be honest I
haven't had any experiences one way or the other.
At the end of the day I think it really depends on the individual on
how their brain is "wired" to receive and interpret data... we are all
different in that regard.
Cheers, Paul
Mark Burton
Posted: Sun Nov 18, 2007 6:26 am Post subject: Re: Digital Readout Engine Gauges |
Such a thing is already available - the technology is straightforward, the real challenge is getting people to buy them!
Cheers,
Mark
johnwigney(at)alltel.net Guest
Posted: Mon Nov 19, 2007 8:40 am Post subject: Digital Readout Engine Gauges |
Hi Michael,
I hope your project is progressing well. I would like to offer another opinion on digital vs. analog. When I was designing my panel, I installed a 2 1/4" analog tachometer with the rpm range markings for the 912S. I also installed a Grand Rapids EIS 2004-W, see http://www.grtavionics.com/model_2004.htm, for my engine monitoring, fuel status and annunciator requirements. I assumed that the analog gauge would be my primary reference for engine speed. Before flying the plane I had been talking with Greg Toman, the Grand Rapids Pres., and mentioned my analog tacho. His comment was "Oh, you will never use that. You will always use the EIS." My reaction was that he was incorrect since I also thought that analog readings were easier and quicker to interpret. However, I found that as soon as I started flying the plane, I never looked at the analog gauge. The EIS digits refresh very quickly and are very accurate. When I build my next panel?, it will have an EIS and no analog tacho.
Cheers, John
N262WF, mono XS, 912S, Whirlwind c/s prop
Mooresville, North Carolina
[quote]ORIGINAL MESSAGE
Subject: Re: Re: Digital Readout Engine Gauges
Martin,
Be aware that only numerical displays impose additional workload to the pilot. You would actually have to read the number and the brain has to process the numbers and compare them mentally.
Example is at http://www.sportflyingshop.com/Instr/Stratomaster/SmartSingles/smartsingles.html .
The nice thing about digital once is that many have a monitoring feature and will ring an alarm when certain programmed levels are exceeded.
you look further.
Advantage of analog representation is that you just need to have a short look at the instrument to see that all data are in the right area. Much quicker and less workload to the brain. This is exactly the reason why the digital representation in a car never took of.
Michael Grass
A266 Trigear
Detroit[b]
rowil(at)clara.net Guest
Posted: Mon Nov 19, 2007 10:25 am Post subject: Digital Readout Engine Gauges |
At 18/11/07 21:25 +1000 craig bastin wrote:
| Quote: | most of the schools in
Australia
Craig - that's new acronym on me! I can make a guess at some of it,
but would like to know the "authorised verion", please!
regards
Rowland
| Rowland Carson PFA #16532 http://home.clara.net/rowil/aviation/
| 840 hours building Europa #435 G-ROWI e-mail <rowil(at)clara.net>
Posted: Sat Nov 24, 2007 5:31 am Post subject: Digital Readout Engine Gauges |
C.L.E.A.R.O.F.F
Compass and DI aligned, flying correct heading
Location. Fix your position
Engine, T's & P's where they should be
Altitude. Correct for plan/heading, and current airspace clearance.
Radio, Correct frequency, still working.
Oxygen (pressurisation)
Fuel, contents sufficient for remaining flight time, correct tank (if
required)
Flaps both wing and cowl correct
the prelanding one ammuses most new students
BUMFFISH
Brakes, working
Undercarriage, (down and locked/Fixed)
Mixture full rich
Fuel, pump on, contents sufficent
Flaps set, both wing and cowl
Instruments (T's and P's correct)
Security, loose objects secure
Hatches and harnesses set for landing.
Short Final check
PLUFF
Pitch (full Fine)
Landing clearance (granted / runway clear)
Fuel, full rich, pump on, contents sufficent
Line up check
TWAD
Transponder, switch to alt, squark correct.
windsock. Crosswind estimate
Aimpoint, for after takeoff
DI and compass agree with runway heading.
I am sure there are other ones that work just as well, are there any others
people want to share
