cliff(at)gesoco.com Guest
Posted: Fri Nov 16, 2007 4:13 pm Post subject: LED replacement lamps |
Just had my first batch of LED lamps arrive.
These directly replace the green & red gears lamps in the Yak-52 without
fuddling around with making something else work.
They're $15 ea (4X the cost of a standard lamp).
Yes, they're expensive...but they won't ever blow out either....
Cheers
Cliff
(Yes, I read the FAQ about advertising...
Clifford Coy
Director of Maintenance
Border Air Ltd
629 Airport Rd.
Swanton, VT 05488
802-868-2822 TEL
802-868-4465 FAX
Skype: callto:Cliff.Coy <callto:cliff.coy>
jonboede(at)hotmail.com Guest
Posted: Fri Nov 16, 2007 8:50 pm Post subject: LED replacement lamps |
I think if you're hawking your own wares, that's advertising. If you've found something you like and you mention it here, that's called "sharing".
What's the URL for the lamps you bought, Cliff?
| Quote: | Date: Fri, 16 Nov 2007 16:08:45 -0500
Subject: Yak-List: LED replacement lamps
To: yak-list(at)matronics.com
--> Yak-List message posted by: Cliff Coy <cliff(at)gesoco.com>
Cheers
Cliff
Clifford Coy
Border Air Ltd
629 Airport Rd.
Swanton, VT 05488
802-868-2822 TEL
802-868-4465 FAX
Posted: Sat Nov 17, 2007 7:40 am Post subject: LED replacement lamps |
Cliff,
Will the work in the 50? Do they have a bayonet casing?
Doc
nc69666(at)aol.com Guest
Posted: Sat Nov 17, 2007 8:09 am Post subject: LED replacement lamps |
Cliff, will they work in th CJ? Gary
napeone
Joined: 10 Jan 2006 Posts: 36 Location: Birmingham, Al.
Posted: Sun Nov 18, 2007 5:17 pm Post subject: Re: LED replacement lamps |
Cliff,
Thank you for letting us know about these hard to source items.
David H.
rkent(at)wlacrussianeng.c Guest
Posted: Mon Nov 19, 2007 12:47 am Post subject: LED replacement lamps |
Doc,
Cliff's LED's should also work for the 50 as they have a lot of the same
components such as the indicator lights for the undercarriage.
Rob Kent
Stores Manager
WLAC - Russian Engineering
www.wlacrussianeng.co.uk
Tel: +44 1628 829 165
Fax: +44 1628 825 975
Mob: +44 7866 438 293
Posted: Mon Nov 19, 2007 6:21 am Post subject: LED replacement lamps |
Rob thanks. Will contact you off list on another issue.
Doc
Ernie
Posted: Wed Nov 21, 2007 4:15 pm Post subject: Re: LED replacement lamps |
I just received my lamps. They dont work in a CJ, the bayonette part is much smaller than whats in my CJ. Apparently Yaks have different bulbs than CJ's.
Any Yak drivers need a full set of lights, just cost me $90 + shipping.
Ernie
