		gcrowder2
  Joined: 09 Jan 2006 Posts: 136 Location: Golden, Colorado USA
				 Posted: Wed Feb 22, 2006 7:07 am    Post subject: Fuel pumps in series can get blocked |
				I switched the pumps on my setup from series to parallel as the Ellison
 throttle body
 on my Subaru setup only requires 3 psi.  One big negative on two pumps in
 series is that if
 there is a blockage, both pumps are taken out.  In the parallel arrangement,
 if  one pump
 gets blocked, the other pump can still deliver fuel.
                                                 Glenn
 [quote]From: "Craig Ellison" <craig.ellison2(at)verizon.net>
 Reply-To: europa-list(at)matronics.com
 Subject: Re: RE: 914 Fuel System
 Date: Tue, 21 Feb 2006 17:43:31 -0800
 All,
 I too had my system set up in parellel and changed to series after talking
 to John H.  One reason I remember of the conversation was about allowing
 proper readings on the fuel pressure/MP differential gauge.
 craig ellison
 A205/N205CN
 Almost ready to fly
		Ivor Phillips
				 Posted: Wed Feb 22, 2006 7:56 am    Post subject: Fuel pumps in series can get blocked |
				Glen that is not actually the case,  If one Pump became blocked,     ( There
 are small mesh filters on the inlet)      the second pump would draw its
 fuel around the Bi-pass pipe and Non-return valve,
 But i agree i would also prefer the Parallel system,
 On the Pierburg website there no mention of running these pumps in series ,
 schematics only show parallel,        Makes you wonder!!!
  	  | Quote: | 	 		    I switched the pumps on my setup from series to parallel as the Ellison
  throttle body
  series is that if
  arrangement,
  if  one pump
 Ivor Phillips
		tonyk(at)kaon.co.nz Guest
				 Posted: Wed Feb 22, 2006 12:06 pm    Post subject: Fuel pumps in series can get blocked |
				The reason for the change to series based pumps is to bring the fuel pressure down to that specified by Rotax. If you measure the differential fuel pressure to airbox pressure as recommended then you'll find that the pressure delivered by parallel pumps is too high.
 Having said that. There are many 914's flying with parallel pumps as this is what Rotax used to show in the installation manual.
 Unless you intend retrofitting  the UMA pressure sensor there is no need to change.
 For new installations the Rotax manual now shows pumps in series with bypass valves
 Tony
		daseitz(at)cfl.rr.com Guest
				 Posted: Wed Feb 22, 2006 12:56 pm    Post subject: Fuel pumps in series can get blocked |
		europa flugzeug fabrik
  Joined: 13 Feb 2006 Posts: 65 Location: North Coast, USA
				 Posted: Thu Feb 23, 2006 8:00 pm    Post subject: Re: Fuel pumps in series can get blocked |
				 	  | tonyk(at)kaon.co.nz wrote: | 	 		  | The reason for the change to series based pumps is to bring the fuel pressure down to that specified by Rotax. If you measure the differential fuel pressure to airbox pressure as recommended then you'll find that the pressure delivered by parallel pumps is too high. |
 I have them in parallel, and it would be a rather "Rube Goldberg" arrangement to make them series.  That's because I have (all in the trigear console tunnel) a sump I made.  It's attached to the front of the floor-mounted fuel valve and has 2 outlets.
 In a parallel setup, do you think cutting back the volts on the boost/emergency pump will relieve the pressure?  I was thinking a 3.9V 10W Zener diode (if I can find 'em), parallel pair (reasonably matched in Vz) for redundancy.  I know I can test it for flow rate etc., but do you see a reason not to do this?
  	  | Quote: | 	 		  | Unless you intend retrofitting  the UMA pressure sensor there is no need to change. |
 I think that don't come out quite right.     The 914 carbs may indeed tolerate excess pressure, but to restate what a famous football coach here once said, "On any given Sunday....a carb may flood!"
 Reg,
 Fred F.
		BEBERRY(at)aol.com Guest
				 Posted: Fri Feb 24, 2006 1:12 am    Post subject: Fuel pumps in series can get blocked |
				I am really learning about fuel pumps and pressures etc (I think) and  wonder
 if anyone can comment on the problem I have with getting a smooth  running
 engine at RPM below about 3600 on my 914.  Could it be  overmuch fuel pressure
 and carb flooding with both pumps on in my parallel  system?  On the other hand
 when doing test engine ground runs I have  the pumps, filters etc in view and
 there is always only one pump fully  working as witness the amount of fuel
 flowing through the transparent  filter barrels..
 Going back to some recent discussions on filters and accumulation of  grot.
 A good while ago I removed a huge amount of stuff from my  carbs and jets,
 none of which had been trapped by the filters which were  as clean as a whistle.
 With my briefish experience of the Rotax I  find this curious.
 Patrick
		paul.mcallister
  Joined: 09 Jan 2006 Posts: 177 Location: Waukesha, WI USA
				 Posted: Fri Feb 24, 2006 6:45 am    Post subject: Fuel pumps in series can get blocked |
				Fred,
 The standard Europa design has the fuel return coming in at the bottom of
 the tank.  I made my system return the fuel into the top of the tank via a
 1/4" aluminum line.  I found in my setup with parallel pumps that I did not
 did not exceed the maximum return fuel pressure as specified by Rotax.
 Paul
		n100rh(at)sbcglobal.net Guest
				 Posted: Fri Feb 24, 2006 7:29 am    Post subject: Fuel pumps in series can get blocked |
				Paul,
 Makes perfect sense. This way you aren't returning back against the
 hydrostatic pressure of all the fuel in the tank.
 Ralph
 RK Hallett III
 Reno,NV
 Paul McAllister wrote:
  Fred,
  Paul
				 Posted: Fri Feb 24, 2006 8:27 am    Post subject: Re: Fuel pumps in series can get blocked |
				 	  | n100rh(at)sbcglobal.net wrote: | 	 		  | Makes perfect sense. This way you aren't returning back against the hydrostatic pressure of all the fuel in the tank. |
 If the return line still runs along the floor, I was assuming that the head pressure would be identical -- full tank vs. upward push in the return line.  Partial tank; we're in the hole. However, I can just about remember what my Physics 101 prof looked like!  Whatever works, though, I always say.
 Best would be the routing return line back along the fuselage side, thence to tank top.  That one I'm pretty sure of...
 Reg,
 Fred F..
		paul.mcallister
				 Posted: Fri Feb 24, 2006 9:15 am    Post subject: Fuel pumps in series can get blocked |
				Fred,
 Mine runs through the firewall along the side of the fuselage under the
 window still and into the tank. It never gets to run uphill.
 Paul
				 Posted: Fri Feb 24, 2006 9:36 am    Post subject: Fuel pumps in series can get blocked |
				Quick note on parallel vs series.
 In parallel, if 1 pump destroys itself, and some debris jams the 1 way
 valve in the pump opened, the other pump, although may be perfectly
 functional may not create enough pressure to prevent the playing of silent
 night.
 Has anyone actual had a pump 1 way fail opened?
 Like someone mentioned a Andair or similar 1 way in series with each pump
 output could help with both pumps, or one 1 way not allowing back feed
 from the aux pump back through main.
 Not going to help the excess pressure though.
 One thing I noticed on my build is that all fittings are not created
 equal. Some have smaller internal holes than other. This for certain can
 cause restriction on 914s where flow rates can be 40gph plus. I chose
 fittings or bored so restriction held to minimum.
 Paul it would be interesting to see if your lack of a too high
 differential fuel pressure with both pumps on are in fact because of not
 returning to bottom of tank, or because of lack of restriction in return
 line??
 The thicker the air, the greater the return pressure should be.
 Ron Parigoris
