GPS recommendations/pdaGuys
herbgh
PostPosted: Tue Nov 13, 2007 3:02 pm    Post subject: GPS recommendations/pdaGuys Reply with quote
Ray all
Would be neat to adapt the satellite radio weather radar feeds to this
goodie!
Herb
On Tue, 13 Nov 2007 11:41:18 -0800 "jb92563" <jb92563(at)yahoo.com> writes:
I depends on which PDA you get.
The software will NOT run on the "Palm OS" only on the
PPC windows mobile versions, so stay away from the "Palm" brand
PDA.
If you stick with the HP iPaq, Dell Axim PDA's then you will be in
good shape and can use the PPC2003 version.
The "All" is a good bet because it will have all versions including
the PC version but it might be a huge download taking a fair amount
of time.
After you have the software downloaded you can get the "Data" or
generate it for your area if none is already available.
Ray
Riverside County, CA
http://forums.matronics.com/viewtopic.php?p=145767#145767
jb92563
PostPosted: Tue Nov 13, 2007 3:57 pm    Post subject: Re: GPS /XM Weather on PDA Reply with quote
Its already done!
Attach unit to your PDA
http://www.xmwxweather.com/weather/aviation.xmc
Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
